05-23-2017, 18:11 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: ...:::cAtCh mE iF U cAn:::...
Member: 2570477 Status: Offline Thanks Meter: 427 | Samsung J320H cert write failed [Solved] Selected port: COM1 Selected model: SM-J320H Selected file: C:\Users\GSM-Flasher\Downloads\SM-J320H__R51H71J790J_7-2-2017_10-14-17.cert Select Certificate2... Selected file: C:\Users\GSM-Flasher\Downloads\SM-J320H__R51H71J790J_7-2-2017_10-14-17.cert Detected phone model: SM-J320H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: J320HXXU1ANIJ CSC version: J320HOJV1ANJ1 SW version: G530HXXU1ANIJ Phone IMEI: 353697060119399 Phone SN: R31F501H9NP Android version: 4.4.4 (KTU84P) Sales code: XSG Country: UAE HW platform: msm8916 HW Chip: MSM8216 HW Modem: MSM8216 SIM 1 status: ready Codename: fortuna3gxx Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate1... Cannot find CRC data! Writing Certificate failed Performed by 2.5.4 Software version. Last edited by Octopus box; 05-24-2017 at 11:03. |
05-24-2017, 07:23 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. We will check what causes the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
05-24-2017, 08:28 | #3 (permalink) |
Member: 2570477 Status: Offline Thanks Meter: 427 | logs is here Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\23-05-2017_21-18-08.log" created (5/23/2017 9:18:13 PM). INFO : 5/23/2017 9:18:35 PM > Set up system language English (file: English.ini) INFO : 5/23/2017 9:18:35 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.5.4 INFO : 5/23/2017 9:18:48 PM > ----------------------------------------------------------------------------------- INFO : 5/23/2017 9:18:48 PM > To connect SCL24 phone you have to perform the following steps: INFO : 5/23/2017 9:18:48 PM > 1. Disconnect USB cable from phone. INFO : 5/23/2017 9:18:48 PM > 2. Go to Menu->Settings->More->About Device. INFO : 5/23/2017 9:18:48 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 5/23/2017 9:18:48 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 5/23/2017 9:18:48 PM > 5. Turn on "USB Debugging" option. INFO : 5/23/2017 9:18:48 PM > 6. Go to dial window. INFO : 5/23/2017 9:18:48 PM > 7. Enter "*#0808#" number. INFO : 5/23/2017 9:18:48 PM > 8. Select "DM+Modem+ADB". INFO : 5/23/2017 9:18:48 PM > 9. Press Home button. INFO : 5/23/2017 9:18:48 PM > 10. Restart phone. INFO : 5/23/2017 9:18:48 PM > 11. Press "Read Info" in software. INFO : 5/23/2017 9:24:14 PM > ----------------------------------------------------------------------------------- INFO : 5/23/2017 9:24:14 PM > To connect SCL24 phone you have to perform the following steps: INFO : 5/23/2017 9:24:14 PM > 1. Disconnect USB cable from phone. INFO : 5/23/2017 9:24:14 PM > 2. Go to Menu->Settings->More->About Device. INFO : 5/23/2017 9:24:14 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 5/23/2017 9:24:14 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 5/23/2017 9:24:14 PM > 5. Turn on "USB Debugging" option. INFO : 5/23/2017 9:24:14 PM > 6. Go to dial window. INFO : 5/23/2017 9:24:14 PM > 7. Enter "*#0808#" number. INFO : 5/23/2017 9:24:14 PM > 8. Select "DM+Modem+ADB". INFO : 5/23/2017 9:24:14 PM > 9. Press Home button. INFO : 5/23/2017 9:24:14 PM > 10. Restart phone. INFO : 5/23/2017 9:24:14 PM > 11. Press "Read Info" in software. INFO : 5/23/2017 9:24:24 PM > ----------------------------------------------------------------------------------- INFO : 5/23/2017 9:24:24 PM > To connect GT-N5100 phone you have to perform the following steps: INFO : 5/23/2017 9:24:24 PM > 1. Disconnect USB cable from phone. INFO : 5/23/2017 9:24:24 PM > 2. Go to Menu->Settings->More->About Device. INFO : 5/23/2017 9:24:24 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 5/23/2017 9:24:24 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 5/23/2017 9:24:24 PM > 5. Turn on "USB Debugging" option. INFO : 5/23/2017 9:37:19 PM > ----------------------------------------------------------------------------------- INFO : 5/23/2017 9:37:20 PM > Platform: Samsung Android INFO : 5/23/2017 9:37:20 PM > Selected port: COM1 INFO : 5/23/2017 9:37:20 PM > Selected model: SM-J320H INFO : 5/23/2017 9:37:43 PM > Selected file: C:\Users\GSM-Flasher\Downloads\SM-J320H__R51H71J790J_7-2-2017_10-14-17.cert INFO : 5/23/2017 9:37:43 PM > Select Certificate2... INFO : 5/23/2017 9:37:46 PM > Selected file: C:\Users\GSM-Flasher\Downloads\SM-J320H__R51H71J790J_7-2-2017_10-14-17.cert WARN : 5/23/2017 9:37:48 PM > Please, press "OK" button on the phone to allow USB debugging.. INFO : 5/23/2017 9:37:52 PM > Detected phone model: SM-J320H INFO : 5/23/2017 9:37:52 PM > Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 INFO : 5/23/2017 9:37:52 PM > PDA version: J320HXXU1ANIJ INFO : 5/23/2017 9:37:52 PM > CSC version: J320HOJV1ANJ1 INFO : 5/23/2017 9:37:52 PM > SW version: G530HXXU1ANIJ INFO : 5/23/2017 9:37:52 PM > Phone IMEI: 353697060119399 INFO : 5/23/2017 9:37:52 PM > Phone SN: R31F501H9NP INFO : 5/23/2017 9:37:52 PM > Android version: 4.4.4 (KTU84P) INFO : 5/23/2017 9:37:52 PM > Sales code: XSG INFO : 5/23/2017 9:37:52 PM > Country: UAE INFO : 5/23/2017 9:37:52 PM > HW platform: msm8916 INFO : 5/23/2017 9:37:52 PM > HW Chip: MSM8216 INFO : 5/23/2017 9:37:52 PM > HW Modem: MSM8216 INFO : 5/23/2017 9:37:52 PM > SIM 1 status: absent INFO : 5/23/2017 9:37:52 PM > Codename: fortuna3gxx INFO : 5/23/2017 9:37:52 PM > Checking Root: INFO : 5/23/2017 9:37:53 PM > Phone is Rooted. INFO : 5/23/2017 9:37:53 PM > Checking Certificate file... INFO : 5/23/2017 9:37:53 PM > Certificate file successfully checked INFO : 5/23/2017 9:37:53 PM > Writing Certificate1... ERROR : 5/23/2017 9:37:59 PM > Cannot find CRC data! ERROR : 5/23/2017 9:37:59 PM > Writing Certificate failed INFO : 5/23/2017 9:37:59 PM > Performed by 2.5.4 Software version. |
05-24-2017, 10:06 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We have prepared test Software version for You. Please download and install "install_octoplus_octopus_Samsung_2.5.4.1" from "Samsung/TEST SOFTWARE" folder of the Support Area. Repeat the operation with test Software and post here the result. Last edited by Octopus box; 05-24-2017 at 10:43. |
05-24-2017, 10:49 | #6 (permalink) |
Member: 2570477 Status: Offline Thanks Meter: 427 | Thank u team Once Again working exe. U r the best team In the whole world . Platform: Samsung Android Selected port: COM1 Selected model: SM-J320H Selected file: C:\Users\GSM-Flasher\Downloads\SM-J320H__R51H71J790J_7-2-2017_10-14-17.cert Select Certificate2... Selected file: C:\Users\GSM-Flasher\Downloads\SM-J320H__R51H71J790J_7-2-2017_10-14-17.cert Detected phone model: SM-J320H Firmware compiled date: Tue Sep 23 10:51:50 KST 2014 PDA version: J320HXXU1ANIJ CSC version: J320HOJV1ANJ1 SW version: G530HXXU1ANIJ Phone IMEI: 353697060119399 Phone SN: R31F501H9NP Android version: 4.4.4 (KTU84P) Sales code: XSG Country: UAE HW platform: msm8916 HW Chip: MSM8216 HW Modem: MSM8216 SIM 1 status: absent Codename: fortuna3gxx Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate1... Checking Certificate file... Certificate file successfully checked Writing Certificate2... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes Performed by 2.5.4 Software version. |
The Following User Says Thank You to Mubashir999 For This Useful Post: |
