06-12-2019, 14:48 | #1 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 2011612 Status: Offline Thanks Meter: 19 | G935L android 7.0 U2 stock bootloader needed [Answered] Envoyé de mon SM-A600F en utilisant Tapatalk |
06-12-2019, 15:01 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | ello. Problem with reset of FRP lock can occur if phone has one of the latest firmwares. Samsung disabled ability to remove FRP lock in latest firmwares. There are few methods, of how to reset FPR on phones with latest firmwares: I. Try to write SBoot file of older firmware. Repeat "Reset FRP/Reactivation/EE" operation. II. Write "boot.img" partition from appropriate Combination firmware via "Advanced mode" option (select Combination firmware, un-check partitions except "boot.img"). Perform "Reset FRP" operation in Software. 74957382 III. Write Full Combination Firmware. Go to "Developer Options" in phone Settings. Check "Enable OEM unlock" option. Make Factory Data Reset. Reflash the phone with full stock (orignal) firmware. Note: "boot.img" from Combinataion firmwares can be not compatible with current phone's firmware. In such case phone will stuck on logo, or will be rebooting after writing of such boot. In this case to restore the phone to it's initial condition You need to reflash it with different full stock (original) firmwares (or try to write only boot of such firmwares). Note: You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! If neither of these methods helps, or necessary files are missing, You can use Factory Reset FRP Service. |
06-12-2019, 15:26 | #3 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
ENG SBOOT G935LKLU2ARI1* Download: ENG SBOOT G935LKLU2ARI1 (ANGLE360.TECH) | |
06-12-2019, 15:48 | #4 (permalink) | |
Member: 2011612 Status: Offline Thanks Meter: 19 | Quote:
Envoyé de mon SM-A600F en utilisant Tapatalk | |
06-12-2019, 15:59 | #5 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | try to download it from this link, it links you to the download link However to me the link that I posted to you from pc opens me from mediafire and I can easily download it https://angle360.tech/?page_id=236 Look: https://i.postimg.cc/sxY6mNjS/screenshot-315.png Last edited by amleto90; 06-12-2019 at 16:05. |
The Following User Says Thank You to amleto90 For This Useful Post: |
06-12-2019, 16:04 | #6 (permalink) | |
06-12-2019, 16:09 | #7 (permalink) | |
It depends on what firmware you have installed on your phone if it is compatible with sboot binary 2 for g935L why don't you use the combination for g935l binary 2 install it and then with the ufs memory method via uart cable with octopus you can read the file and then write the stock firmware in 4 files selecting ap, bl, cp, home_csc Look and read post: http://forum.gsmhosting.com/vbb/f777...lable-2528581/ Last edited by amleto90; 06-12-2019 at 16:16. | |
06-12-2019, 16:16 | #8 (permalink) | |
