03-15-2016, 05:29 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: CHHIBRAMAU KANNAOJ UP.{INDIA} Age: 33
Member: 1535468 Status: Offline Sonork: 100.161922 Thanks Meter: 310 | samsung j7f not fkash [Solved] ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: J700FXXU1AOI1_J700FOJV1AOI1 _XSG_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... Writing Firmware Failed Last edited by Octopus box; 03-16-2016 at 11:23. |
03-15-2016, 11:14 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Try to reflash the phone with "J700FXXU1APA2_J700FOJK1APA1_ILO_Android_5.1.1 " firmware from the Support Area. Post here result and full Software log of the operation. |
