11-19-2017, 14:59 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | Samsung module stuck not flashing To put SM-N9200 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... Writing firmware Canceled Performed by 2.6.1 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-N9200 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... Writing firmware Canceled Performed by 2.6.1 Software version. Selected AP file: H:\flash firmware\Samsung\Android\ROOTkits\twrp- 3.1.1-0-nobleltezt n9200 n9208.img.tar Please put the phone into Download Mode and connect USB cable. To put SM-N9200 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RECOVERY section... Writing firmware Canceled Performed by 2.6.1 Software version. HELP ME TEAM OCTOPLUS IS NT FLASHING ANY FIRMWARE IT JUST STUCK ON FLASHING NT MOVING..I TRIED .oct files it fails and also custom firmwares like twrp....Official firmware is flashing ok...please fix Last edited by Octopus box; 11-20-2017 at 06:59. |
11-19-2017, 15:09 | #2 (permalink) |
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | Welcome to Octoplus/Octopus Box Samsung software version 2.6.1 ----------------------------------------------------------------------------------- To connect SM-N9200 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: combination_fa51_n9200zcu2apa1_cl6799239 _qb7957078.oct Please put the phone into Download Mode and connect USB cable. To put SM-N9200 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... Writing Firmware Failed Performed by 2.6.1 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-N9200 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... Writing Firmware Failed Performed by 2.6.1 Software version. |
11-19-2017, 17:14 | #3 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro did u install crom service to enable custom recovery ? Quote:
11-20-2017, 17:57 | #5 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro if the phone is with the octopus then u should succeed with odin but neither by odin then crom didnt work or new security blocking custom recovery oem is enabled? Sent from my Le X829 using Tapatalk |
11-20-2017, 18:41 | #6 (permalink) |
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | You don't understand.. Flashing with Odin works but flashing with octopus fails. I have combination firmware in .oct format i want to flash it but its not flashing. The software just freeze not doing anything.. I tried other mobile same thing but if i choose .tar it flashes ok |
11-21-2017, 06:33 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please contact us to Skype, we will check remotely, where can be the problem. Our contacts You can find in our profile. |
