04-16-2014, 10:35 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. As You can see from this Software log, modem part is damaged in your device: Quote:
At first, try to find and re-flash the device with different firmwares and check whether modem is correct (not Unknown) and only then (when phone's modem part will be correct) try to perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. | |
04-16-2014, 15:04 | #3 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jul 2011 Location: Dubai U.A.E Age: 36
Member: 1619775 Status: Offline Sonork: 100.1603044 Thanks Meter: 302 | Quote:
04-16-2014, 15:08 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to write different 4.0.4 and 4.1.2 firmwares from the SUpport Area. If after of writing these firmwares the problem is the same - check phone's HW. |
04-16-2014, 16:01 | #5 (permalink) | |
Plz Give Me Screenshot the file support Aria i try to download the file | |
04-20-2014, 10:40 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | If after of writing all firmwares from the Support Area, phone's baseband is still unknown, most likely, this is HW problem (problem is with phone's flash chip). |
04-22-2014, 06:59 | #9 (permalink) | |
Flash After this Working i make flash then this problem plz tell me any solution i many time try but no luck | |
04-22-2014, 07:15 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to find and write other firmwares. No other solution. If after of writing all firmwares which You have, phone's baseband is still unknown, most likely, this is HW problem (problem is with phone's flash chip). If You have the same working device, You can try to read full flash from it by using Jtag tool and then write this full flash into your device. |
