04-23-2014, 08:30 | #1 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 319956 Status: Offline Thanks Meter: 124 | samsung n900w8 restart here is log Platform: Samsung Android INFO : 4/22/2014 8:55:22 PM > Selected port: COM27 INFO : 4/22/2014 8:55:22 PM > Selected model: SM-N900W8 INFO : 4/22/2014 8:55:22 PM > Mode: Normal INFO : 4/22/2014 8:55:22 PM > Phone model: SM-N900W8 INFO : 4/22/2014 8:55:22 PM > Firmware compiled date: Oct 23 2013 INFO : 4/22/2014 8:55:22 PM > Firmware compiled time: 13:53:06 INFO : 4/22/2014 8:55:22 PM > Firmware released date: Oct 23 2013 INFO : 4/22/2014 8:55:22 PM > Firmware released time: 13:53:06 INFO : 4/22/2014 8:55:22 PM > Phone IMEI: 357507-05-000009-3 INFO : 4/22/2014 8:55:22 PM > SW version: SET_BY_CM INFO : 4/22/2014 8:55:22 PM > Repairing 3G/4G... INFO : 4/22/2014 8:55:44 PM > 3G/4G repair successfully WARN : 4/22/2014 8:55:44 PM > To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) please tell me how to solve this problem |
04-23-2014, 08:35 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We have prepared and sent test Software version to your PM. Please do the next: 1. Install this Software version. 2. Re-flash the phone. 3. Make Factory data reset. 4. Perform the Unlock or Repair 3G/4G operation. 5. Write here the result. |
04-23-2014, 10:12 | #6 (permalink) |
Member: 319956 Status: Offline Thanks Meter: 124 | i flash it with octopus and do factory reset but still in reboot loop here is flashing log :- Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\23-04-2014_13-48-07.log" created (23-Apr-14 1:48:10 PM). ERROR : 23-Apr-14 1:48:10 PM > Access violation at address 008E905C in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 23-Apr-14 1:48:11 PM > Set up system language English (file: English.ini) INFO : 23-Apr-14 1:48:11 PM > Welcome to Octoplus/Octopus Box Samsung software version 1.5.4 INFO : 23-Apr-14 1:48:11 PM > ----------------------------------------------------------------------------------- INFO : 23-Apr-14 1:48:11 PM > To connect SC-01C phone you have to perform the following steps: INFO : 23-Apr-14 1:48:11 PM > 1. Disconnect USB cable from phone. INFO : 23-Apr-14 1:48:11 PM > 2. Go to Menu->Settings->Applications->Development. INFO : 23-Apr-14 1:48:11 PM > 3. Turn on "USB Debugging" option. INFO : 23-Apr-14 1:48:11 PM > 4. When the message appears press "Yes". INFO : 23-Apr-14 1:48:11 PM > 5. Connect USB cable to the phone. INFO : 23-Apr-14 1:48:11 PM > 6. Press "Read Info" in software. INFO : 23-Apr-14 1:48:23 PM > ----------------------------------------------------------------------------------- INFO : 23-Apr-14 1:48:23 PM > To connect SM-N900W8 phone you have to perform the following steps: INFO : 23-Apr-14 1:48:23 PM > 1. Disconnect USB cable from phone. INFO : 23-Apr-14 1:48:23 PM > 2. Go to Menu->Settings->More->About Device. INFO : 23-Apr-14 1:48:23 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 23-Apr-14 1:48:23 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 23-Apr-14 1:48:23 PM > 5. Turn on "USB Debugging" option. INFO : 23-Apr-14 1:48:23 PM > 6. Go to dial window. INFO : 23-Apr-14 1:48:23 PM > 7. Enter "*#0808#" number. INFO : 23-Apr-14 1:48:23 PM > 8. Select "DM+Modem+ADB". INFO : 23-Apr-14 1:48:23 PM > 9. Press Home button. INFO : 23-Apr-14 1:48:23 PM > 10. Go to dial window. INFO : 23-Apr-14 1:48:23 PM > 11. Enter "*#9090#" number. INFO : 23-Apr-14 1:48:23 PM > 12. Set "Diag config" to "USB" value. INFO : 23-Apr-14 1:48:23 PM > 13. Restart phone. INFO : 23-Apr-14 1:48:23 PM > 14. Press "Read Info" in software. INFO : 23-Apr-14 1:49:21 PM > Firmware conversion started for phone INFO : 23-Apr-14 1:49:21 PM > Firmware conversion started for SM-N900W8 phone INFO : 23-Apr-14 1:55:47 PM > Firmware converted successfully INFO : 23-Apr-14 1:58:01 PM > Selected firmware file: N900W8VLUBMJ4_N900W8OYABMJ4_N900W8VLUBMJ4_HOME.oct WARN : 23-Apr-14 2:01:02 PM > Please switch your phone to the download mode and connect it to a PC. WARN : 23-Apr-14 2:01:02 PM > To put SM-N900W8 phone into download mode you have to perform the following steps: WARN : 23-Apr-14 2:01:02 PM > 1. Reconnect phone battery. WARN : 23-Apr-14 2:01:02 PM > 2. Press and hold "Volume - " + "Home" + "Power" buttons. WARN : 23-Apr-14 2:01:02 PM > 3. When phone turns on press "Volume+" button. INFO : 23-Apr-14 2:01:05 PM > Found phone on INFO : 23-Apr-14 2:01:05 PM > Firmware write started. INFO : 23-Apr-14 2:01:05 PM > Writing SBL1 section... INFO : 23-Apr-14 2:01:07 PM > SBL1 section has been written successfully. INFO : 23-Apr-14 2:01:07 PM > Writing ABOOT section... INFO : 23-Apr-14 2:01:10 PM > ABOOT section has been written successfully. INFO : 23-Apr-14 2:01:10 PM > Writing RPM section... INFO : 23-Apr-14 2:01:12 PM > RPM section has been written successfully. INFO : 23-Apr-14 2:01:12 PM > Writing TZ section... INFO : 23-Apr-14 2:01:15 PM > TZ section has been written successfully. INFO : 23-Apr-14 2:01:15 PM > Writing DBI section... INFO : 23-Apr-14 2:01:17 PM > DBI section has been written successfully. INFO : 23-Apr-14 2:01:17 PM > Writing APNHLOS section... INFO : 23-Apr-14 2:01:19 PM > APNHLOS section has been written successfully. INFO : 23-Apr-14 2:01:19 PM > Writing BOOT section... INFO : 23-Apr-14 2:01:23 PM > BOOT section has been written successfully. INFO : 23-Apr-14 2:01:23 PM > Writing RECOVERY section... INFO : 23-Apr-14 2:01:27 PM > RECOVERY section has been written successfully. INFO : 23-Apr-14 2:01:27 PM > Writing SYSTEM section... INFO : 23-Apr-14 2:06:44 PM > SYSTEM section has been written successfully. INFO : 23-Apr-14 2:06:44 PM > Writing MODEM section... INFO : 23-Apr-14 2:06:54 PM > MODEM section has been written successfully. INFO : 23-Apr-14 2:06:54 PM > Writing CACHE section... INFO : 23-Apr-14 2:07:17 PM > CACHE section has been written successfully. INFO : 23-Apr-14 2:07:17 PM > Firmware writing successfully completed. |
