03-23-2016, 16:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | samsung N910F but show N910P in download mode but in odin mode show N910p i think someone flashed it with N910p firmware. now i try to flash N910F firmware by odin.but show failed. so i need to ask team what's the difference between N910p and N910F? i think N910P=Sprint carrier and N910F =international carrier. phone receive for network issue now it is unknown baseband and imei null . so pls guide me to fix the issue |
03-23-2016, 17:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. The main difference between SM-N910P and SM-N910F is that they have different range of supported Cellular Network types (more information here: Comparison: SM-N910P vs. SM-N910F). This most likely means that modem firmware of these models is different. Also, this is most likely the reason of Unknown baseband and null IMEI. First of all we recommend to find out exact model of the phone (it is better to disassemble the phone and model on PCB). Only then try to write a correct firmware. |
03-23-2016, 17:26 | #3 (permalink) | |
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
anyway without open pcb? customer not agree to disassemble his phone | |
03-23-2016, 17:58 | #5 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | ..::Gsmideazone::.., bro of course, replace a sticker back the phone is very easy, can seller for more high price one N910F (International Version LTE), compared with one lol N910P, (Sprint NOT Gsm Net), that his price is a lot more chip. Reflash with Sprint FW and turn back to him first that him want one N910F. You customer is been cheated!!! BR allumts |
03-23-2016, 18:36 | #6 (permalink) | |
my customer said when he buy he seen in phone about N910P but in phone sticker seen N910F. the back sticker imei and phone imei was same. phone was working 100% with gsm sim in my country then he make reset and stuck on hang on logo now i after flash with N910p phone all is ok expect network. so i think may he is wrong to see the model. after that i flash N910F firmware but it is failed now again flash N910P to get phone alive but this time missing baseband and imei . so now looking good efs to repair baseband then may be need qcn for network | |
03-23-2016, 19:08 | #7 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Bro, not manage More this phone for N910F it's SPRINT 100%. You are confirmed that after reset Lost Network, becouse for sure was been Unlocked and enabled with one APP and Not from Definitive solution. Not are sure that you can repair this only with one good EFS...if find my appoint i send you. Qcn can use only after you have enabled to Gsm Net you know very good that's CDMA from Factory... anyway let me know if have find solution Br allumts |
The Following User Says Thank You to allumts For This Useful Post: |
03-23-2016, 19:27 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to reflash the phone with "N910PVPU4COJ6_N910PSPT4COJ6_SPR_Android_5.1.1 " firmware from the Support Area, then check phone's IMEI and baseband. |
The Following 4 Users Say Thank You to Octopus box For This Useful Post: |
03-24-2016, 13:53 | #9 (permalink) | |
after flash this firmware now phone alive with imei and baseband. now can you help me to fix network issue ? | |
03-24-2016, 15:46 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please perform "Unlock"/"Domestic Unlock" operation, then try to do the next: 1. Dial *#0011# and in the service menu do the following. 2. Click "Menu" then "Key input" then input Q then press "Ok". 3. Click "Menu" then "Back". 4. Click "Menu" then "Key input" then input 0000 then click "Ok". After these steps Hidden menu should open. In Hidden menu, depending on available options, try to do the following: I.
II.
After these actions go to Settings -> Mobile Networks and Set Network Mode to Automatic, or GSM. |
03-24-2016, 21:33 | #11 (permalink) | |
phone is rooted but show not rooted Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-N910P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-N910P Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM52 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM52 Selected model: SM-N910P Detected phone model: SM-N910P Firmware compiled date: Thu Oct 22 08:51:50 KST 2015 PDA version: N910PVPU4COJ6 CSC version: N910PSPT4COJ6 SW version: N910PVPU4COJ6 Phone SN: W2014101515 Android version: 5.1.1 (LMY47X) Checking Root: Phone is not Rooted. Installing service app... Unlocking phone... Finalizing... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM52 Selected model: SM-N910P ADB server killed. Detected phone model: SM-N910P Firmware compiled date: Thu Oct 22 08:51:50 KST 2015 PDA version: N910PVPU4COJ6 CSC version: N910PSPT4COJ6 SW version: N910PVPU4COJ6 Phone SN: W2014101515 Android version: 5.1.1 (LMY47X) Checking Root: Phone is not Rooted. Installing service app... Unlocking phone... Finalizing... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM52 Selected model: SM-N910P Can't kill external ADB references. Please, close all programs that use ADB server. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Can't detect android kernel version. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM52 Selected model: SM-N910P ADB server killed. Detected phone model: SM-N910P Firmware compiled date: Thu Oct 22 08:51:50 KST 2015 PDA version: N910PVPU4COJ6 CSC version: N910PSPT4COJ6 SW version: N910PVPU4COJ6 Phone SN: W2014101515 Android version: 5.1.1 (LMY47X) Checking Root: Phone is not Rooted. Installing service app... Unlocking phone... Finalizing... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. also after follow ur way no hidden menu is come. help pls | |
03-24-2016, 22:18 | #12 (permalink) |
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | phone is rooted now also said unlock success ---------------- Platform: Samsung Android Selected port: COM52 Selected model: SM-N910P Detected phone model: SM-N910P Firmware compiled date: Thu Oct 22 08:51:50 KST 2015 PDA version: N910PVPU4COJ6 CSC version: N910PSPT4COJ6 SW version: N910PVPU4COJ6 Phone SN: W2014101515 Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-N910P-25-03-2016_03-09-53 file Installing service app... Unlocking phone... Finalizing... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM52 Selected model: SM-N910P Detected phone model: SM-N910P Firmware compiled date: Thu Oct 22 08:51:50 KST 2015 PDA version: N910PVPU4COJ6 CSC version: N910PSPT4COJ6 SW version: N910PVPU4COJ6 Phone SN: W2014101515 Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-N910P-25-03-2016_03-14-03 file Installing service app... Unlocking phone... Finalizing... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. still now not come hidden menu what to do next ? |
03-24-2016, 23:15 | #13 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Bro, but you why are using this Old Sw version and also Card isn't Updatate to Last FW. If install last 2.2.2 need of update Card Fw and can be you solve all you problem. A) from first Log i see Rooted. B) For Hidden menu, just Wipe Factory reset and Cache will gave you other time Hidden menu, if no, must need of rewrite Fw and enable other time Hidden menu. Br allumts |
03-25-2016, 06:24 | #14 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: World of technology
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | Quote:
this is just a refurbished model from china..u can get phones like dat which have been either refurbished or stolen in host countries and sold with custom firmware that make it look like international model. i have encountered many phones like that. in ur case definately a sprint model with some custom firmware to make it look like international one. | |
03-25-2016, 07:50 | #15 (permalink) | |
Freak Poster Join Date: Sep 2015 Location: HERE
Member: 2457641 Status: Offline Thanks Meter: 153 | Quote:
