05-27-2017, 14:26 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: ...:::cAtCh mE iF U cAn:::...
Member: 2570477 Status: Offline Thanks Meter: 427 | Samsung Note 4 dead with flash on Octopus INFO : 5/27/2017 5:41:44 PM > 2. Go to Menu->Settings->More->About Device. INFO : 5/27/2017 5:41:44 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 5/27/2017 5:41:44 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 5/27/2017 5:41:44 PM > 5. Turn on "USB Debugging" option. INFO : 5/27/2017 5:41:44 PM > 6. Go to dial window. INFO : 5/27/2017 5:41:44 PM > 7. Enter "*#0808#" number. INFO : 5/27/2017 5:41:44 PM > 8. Select "DM+Modem+ADB". INFO : 5/27/2017 5:41:44 PM > 9. Press Home button. INFO : 5/27/2017 5:41:44 PM > 10. Restart phone. INFO : 5/27/2017 5:41:44 PM > 11. Press "Read Info" in software. INFO : 5/27/2017 5:42:04 PM > Selected firmware file: N910TUVU2EPJ2_N910TTMB2EPJ2_TMB_Android_6.0.1.oct WARN : 5/27/2017 5:42:07 PM > Please put the phone into Download Mode and connect USB cable. WARN : 5/27/2017 5:42:07 PM > To put SM-N910T into Download Mode, You have to perform the following steps: WARN : 5/27/2017 5:42:07 PM > 1. Reconnect the battery. WARN : 5/27/2017 5:42:07 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 5/27/2017 5:42:07 PM > 3. When phone turns on, press "Volume+" key. INFO : 5/27/2017 5:42:07 PM > Found phone on WARN : 5/27/2017 5:42:07 PM > Advanced mode! INFO : 5/27/2017 5:42:15 PM > Firmware write started. INFO : 5/27/2017 5:42:15 PM > Writing SBL1 section... INFO : 5/27/2017 5:42:17 PM > SBL1 section has been written successfully. INFO : 5/27/2017 5:42:17 PM > Writing RPM section... INFO : 5/27/2017 5:42:19 PM > RPM section has been written successfully. INFO : 5/27/2017 5:42:19 PM > Writing TZ section... INFO : 5/27/2017 5:42:21 PM > TZ section has been written successfully. INFO : 5/27/2017 5:42:21 PM > Writing DBI section... INFO : 5/27/2017 5:42:24 PM > DBI section has been written successfully. INFO : 5/27/2017 5:42:24 PM > Writing APNHLOS section... INFO : 5/27/2017 5:42:27 PM > APNHLOS section has been written successfully. INFO : 5/27/2017 5:42:27 PM > Writing RECOVERY section... INFO : 5/27/2017 5:42:30 PM > RECOVERY section has been written successfully. INFO : 5/27/2017 5:42:30 PM > Writing SYSTEM section... ERROR : 5/27/2017 6:11:03 PM > Writing Firmware Failed INFO : 5/27/2017 6:11:03 PM > Performed by 2.5.4 Software version. Last edited by Octopus box; 05-29-2017 at 07:59. |
05-27-2017, 16:48 | #3 (permalink) |
Member: 2570477 Status: Offline Thanks Meter: 427 | No sir.. phone Does'nt go to download mode .. phone Condition Is totally dead Know PLease some One Help Me To Fix This problem .. Last edited by Octopus box; 05-29-2017 at 07:47. |
05-29-2017, 07:48 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. What was initial state of the phone? Why did You decide to reflash it? |
05-29-2017, 12:23 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Unfortunately if phone doesn't enter download mode, it can't be repaired with Octoplus/Octopus Samsung Software. You need to repair phone boot loaders via eMMC. |
05-29-2017, 15:52 | #10 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Can use any Box that support EMMC direct repair, Medusa PRO, itc... For Pinout just use search button in forum. | |
