06-23-2014, 09:19 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1130961 Status: Offline Thanks Meter: 1 | Samsung S3 mini G730W8 Cant make calls 3g/LTE [Solved] I did IMEi Repair, NVM repair, I used original NVM backed up during the unlock Any Help Last edited by Octopus box; 12-20-2014 at 08:39. |
06-23-2014, 09:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to re-flash the phone and then make Repair NVM. To finish the Repair NVM operation, please restart the phone via phone's menu (via "Power ON" key, don't disconnect the battery, this is important). Also, look here: http://forum.gsmhosting.com/vbb/f684.../#post10280587, http://forum.gsmhosting.com/vbb/f684.../#post10286914, http://forum.gsmhosting.com/vbb/f684.../#post10136718. |
06-23-2014, 09:30 | #3 (permalink) | |
Member: 1130961 Status: Offline Thanks Meter: 1 | Quote:
Reflash with Octopus firmware, or with Odin? | |
06-24-2014, 14:57 | #5 (permalink) |
Member: 1130961 Status: Offline Thanks Meter: 1 | Platform: Samsung Android Selected port: COM47 Selected model: SM-G730W8 Mode: Normal Phone model: SM-G730W8 Firmware compiled date: Oct 22 2013 Firmware compiled time: 06:00:00 Firmware released date: Nov 8 2013 Firmware released time: 19:22:48 Phone IMEI: 357749-05-058208-0 SW version: M8930B-AAAATAZM-5.0.060151 Creating NVM backup Reading NVM done! Repairing NVM for SM-G730W8 phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) **** But still didn't work |
11-03-2014, 05:37 | #6 (permalink) | |
Junior Member Join Date: Oct 2014 Location: Montreal, CAN Age: 32
Member: 2272339 Status: Offline Thanks Meter: 0 | I've got the same problem here with a Samsung S3 Mini SM-G730W8, after successfully repairing the IMEI and unlocking the phone; I've lost calling under 3G/LTE (BELL,Telus) but text messages and network data work fine. Tryed to flash the phone and repairing NVM with Quote:
11-03-2014, 08:17 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ maddriver13 Hello. Try to do the next: 1. Install the latest Software version (Software). 2. Write the first Security backup, that has been created by Software before performing the Repair IMEI operation. This will return the phone to the initial state, in which the phone was before. 3. Read QCN from the phone. 4. Make Repair IMEI again. 5. Write QCN. 6. Write here the result. |
12-20-2014, 05:36 | #9 (permalink) |
Member: 2272339 Status: Offline Thanks Meter: 0 | For better results make read EFS and Read QCN to perform a backup later I unlocked it after that; I repair the imei finally repair the nvm note your phone should be rooted |
