07-20-2013, 07:41 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 838176 Status: Offline Thanks Meter: 57 | samsung S4 M919 unlock successfully To connect SGH-M919 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to dial window. 9. Enter "*#9090#" number. 10. Select "[4] DM over UART(*)". 11. Restart phone. 12. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 Phone IMEI: 355537-05-325698-0 SW Version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 Phone IMEI: 355537-05-325698-0 SW Version: M9615A-CEFWTAZM-4.0.17062 Reading phone unlock codes. It can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked NCK unlock code: *#7465625*638*63097951# NSCK unlock code: *#7465625*782*00000000# SPCK unlock code: *#7465625*77*00000000# |
09-19-2013, 06:52 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ operative001 To connect SGH-M919 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to dial window. 9. Enter "*#9090#" number. 10. Select "[4] DM over UART(*)". 11. Restart phone. 12. Press "Read Info" in software. Please carefully perform all of these steps and post the result here. |
11-09-2013, 23:07 | #10 (permalink) |
Crazy Poster Join Date: Jan 2008
Member: 678472 Status: Offline Thanks Meter: 2 | i need you help !! for SGH-M919 emergency mode First dial *#0808# and select: DM - MODEM - ADB , its ok i select then *#9090# select: DM OVER UART[*] dont work i see in black all and no detect the phone |
11-10-2013, 08:31 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If phone's firmware doesn't allow to select any option in menu "*#9090#", try to connect the phone via Micro USB cable. Also try to re-flash the phone with another firmware and try to connect it via Samsung Micro UART and Micro USB cables again; maybe, "*#9090#" items will be available after of writing another firmware. |
