03-26-2015, 21:17 | #1 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Italia
Member: 2044491 Status: Offline Thanks Meter: 18 | Samsung S4 No sim [Solved] Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM18 Mode: Emergency How to exit from Emergency mode? thanks Last edited by Octopus box; 03-27-2015 at 14:13. |
03-26-2015, 21:41 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. "Mode: Emergency" means that phone is not configured correctly for connection. Carefully perform all of the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "DM/DUM over HS-USB" value. 13. Restart phone. 14. Connect the phone directly to PC. 15. Press "Read Info" in software. |
03-27-2015, 08:48 | #6 (permalink) |
Member: 2044491 Status: Offline Thanks Meter: 18 | Android version: 4.4.2 I9505XXUGNJ8 CSC I9505YXYGNK1 The problem is that he says no sim inserted. I've tried with several sim, imei and serial are presents.. I've tried to wipe and reflash this firmware.. But still in emergency mode for my box.. And the main problem is no sim.. |
03-27-2015, 08:54 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Also read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post here full Software log with this info. | |
03-27-2015, 12:24 | #9 (permalink) | |
Member: 2044491 Status: Offline Thanks Meter: 18 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM18 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-I9505 Firmware compiled date: Fri Oct 31 22:49:52 KST 2014 PDA version: I9505XXUGNJ8 CSC version: I9505YXYGNK1 SW version: I9505XXUGNJ8 Phone IMEI: 357139059409347 Phone SN: RF1D51CXR3D Android version: 4.4.2 (KOT49H) | |
03-27-2015, 13:06 | #10 (permalink) |
Member: 2044491 Status: Offline Thanks Meter: 18 | the only strange thing is that when I enter in menu with *#9090# and select Diag config" to "USB" value, there is the *, but if I press on appear for one second error and phone restart itself.. |
03-27-2015, 13:11 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Re-flash the phone with another firmware, make Factory data reset, wipe cache partition and try to configure the phone again. |
03-27-2015, 13:16 | #12 (permalink) |
Member: 2044491 Status: Offline Thanks Meter: 18 | there are news! Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM18 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM18 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Firmware compiled date: Fri Oct 31 22:49:52 KST 2014 PDA version: I9505XXUGNJ8 CSC version: I9505YXYGNK1 SW version: I9505XXUGNJ8 Phone IMEI: 357139059409347 Phone SN: RF1D51CXR3D Android version: 4.4.2 (KOT49H) Cheking Root Can't root Android version 4.4.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed Selected firmware file: Root_GT-I9505_new.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9505 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Firmware compiled date: Fri Oct 31 22:49:52 KST 2014 PDA version: I9505XXUGNJ8 CSC version: I9505YXYGNK1 SW version: I9505XXUGNJ8 Phone IMEI: 357139059409347 Phone SN: RF1D51CXR3D Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-357139059409347-27-03-2015_13-13- 25-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: Phone IMEI: 357139-05-940934-7 SW version: Found phone on COM17 Repairing NVM for GT-I9505 phone... Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Repairing NVM for GT-I9505 phone... Writing NVM failed NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
03-27-2015, 13:35 | #13 (permalink) |
Member: 2044491 Status: Offline Thanks Meter: 18 | Now I try to write correct imei but there is logo: Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM18 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM18 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM16 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Firmware compiled date: Fri Oct 31 22:49:52 KST 2014 PDA version: I9505XXUGNJ8 CSC version: I9505YXYGNK1 SW version: I9505XXUGNJ8 Phone IMEI: 357139059409347 Phone SN: RF1D51CXR3D Android version: 4.4.2 (KOT49H) Cheking Root Can't root Android version 4.4.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed Selected firmware file: Root_GT-I9505_new.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9505 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: GT-I9505 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Firmware compiled date: Fri Oct 31 22:49:52 KST 2014 PDA version: I9505XXUGNJ8 CSC version: I9505YXYGNK1 SW version: I9505XXUGNJ8 Phone IMEI: 357139059409347 Phone SN: RF1D51CXR3D Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-357139059409347-27-03-2015_13-13- 25-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: Phone IMEI: 357139-05-940934-7 SW version: Found phone on COM17 Repairing NVM for GT-I9505 phone... Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Repairing NVM for GT-I9505 phone... Writing NVM failed NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Firmware compiled date: Fri Oct 31 22:49:52 KST 2014 PDA version: I9505XXUGNJ8 CSC version: I9505YXYGNK1 SW version: I9505XXUGNJ8 Phone IMEI: 357139059409347 Phone SN: RF1D51CXR3D Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-357139059409347-27-03-2015_13-22- 02-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! Firmware compiled date: Sep 11 2014 Firmware compiled time: 23:00:00 Firmware released date: Oct 31 2014 Firmware released time: 23:30:38 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17178 Found phone on COM18 Repairing NVM for GT-I9505 phone... Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Sep 11 2014 Firmware compiled time: 23:00:00 Firmware released date: Oct 31 2014 Firmware released time: 23:30:38 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17178 Creating NVM backup Reading NVM done! Repairing NVM for GT-I9505 phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Sep 11 2014 Firmware compiled time: 23:00:00 Firmware released date: Oct 31 2014 Firmware released time: 23:30:38 SW version: M9615A-CEFWTAZM-4.0.17178 Old IMEI: 004400-15-202000-0 New IMEI: 357377-05-170062-4 Creating NVM backup NVM reading process failed Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Sep 11 2014 Firmware compiled time: 23:00:00 Firmware released date: Oct 31 2014 Firmware released time: 23:30:38 SW version: M9615A-CEFWTAZM-4.0.17178 Old IMEI: 004400-15-202000-0 New IMEI: 357377-05-170062-4 Creating NVM backup Reading NVM done! Firmware compiled date: Fri Oct 31 22:49:52 KST 2014 PDA version: I9505XXUGNJ8 CSC version: I9505YXYGNK1 SW version: I9505XXUGNJ8 Phone IMEI: Unknown Phone SN: RF1D51CXR3D Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-27-03-2015_13-32-26-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Sep 11 2014 Firmware compiled time: 23:00:00 Firmware released date: Oct 31 2014 How could I fix this error? thanks Firmware released time: 23:30:38 SW version: M9615A-CEFWTAZM-4.0.17178 Found phone on COM18 Repairing NVM for GT-I9505 phone... Write IMEI failed |
03-27-2015, 13:38 | #14 (permalink) |
Freak Poster Join Date: Sep 2013 Location: PaKiStAn & KSA
Member: 2023768 Status: Offline Sonork: 100.1661054 Thanks Meter: 76 | write certificate your problem will be solved i have done one s4 set say no sim by write certificate |
The Following User Says Thank You to imraan ali For This Useful Post: |
03-27-2015, 13:40 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Have You written the special firmware "GT-i9505_for_Unlock_and_IMEI_repair" before repairing IMEI? Please perform all steps from the Software manual ("Help" button in the Software) to make Repair IMEI, and post here full Software log with all of them. |
