03-02-2017, 05:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Mandaue City, Cebu
Member: 1986646 Status: Offline Thanks Meter: 100 | Samsung S5 SM-G900i 5.0 imei repair / emergency only repair using octopus Welcome to Octoplus/Octopus Box Samsung software version 2.4.8 ----------------------------------------------------------------------------------- To connect SM-G900I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Root your phone manually. download file and flash via odin https://download.chainfire.eu/728/CF...zt-smg900i.zip To Repair IMEI, go to octopus support download the CERTIFICATE File Connect powered-on phone to PC via Micro USB cable. Install necessary driver. Click "Repair Security/Wipe Security" button. Click "Write Cert" button. Follow software instructions (prompts). Note: After performing this steps, your device will be unlocked and IMEI will be changed to the one from Certificate file. Last edited by Octopus box; 03-02-2017 at 07:35. |
