04-22-2013, 09:54 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Canada Toronto
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | samsung s5220 not unlock [Solved] Welcome to Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect GT-S7562 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. Selected firmware file: S5220XXLAB_OXELAA (1).oct ----------------------------------------------------------------------------------- Platform: Samsung Infineon Selected model: GT-S5220 Selected port: COM363 Baud rate: 115200 Phone must be OFF, and battary must be fully charged Please, connect the UART cable, Reconnect the battery, press Power button Connecting... Phone found. Sending loaders... Sending preloader... Preloader send successfully Sending mainloader... Mainloader send successfully Writing firmware... Erasing Full Flash... Full Flash erase successfully. Writing "S5220XXLAB_psi"... Writing "S5220XXLAB_psi" done! Writing "S5220XXLAB_slb"... Writing "S5220XXLAB_slb" done! Writing "S5220XXLAB_BSY part 0"... Writing "S5220XXLAB_BSY" done! Writing "S5220XXLAB_BSY part 1"... Writing "S5220XXLAB_BSY" done! Writing "S5220XXLAB_CDS"... Writing "S5220XXLAB_CDS" done! Writing "S5220OXELAA_CSC"... Writing "S5220OXELAA_CSC" done! Firmware Write successfully. ----------------------------------------------------------------------------------- Platform: Samsung Infineon Selected model: GT-S5220 Selected port: COM363 Phone must be ON. Searching for a phone. Please wait... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Infineon Selected model: GT-S5220 Selected port: COM363 Phone must be ON. Searching for a phone. Please wait... Found phone on COM363 Reading info... UniqueNumber : 29340000033854 SW Version : S5220XXLAB Phone IMEI A: 355371050473293 Deactivating MSL... MSL deactivate successfully Unlocking phone... Phone is successfully unlocked Please insert card into phone, if phone is locked, then type #0111* 00000000# Last edited by Octopus box; 04-22-2013 at 13:18. |
04-22-2013, 10:20 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. What do You mean "not working for me"? Quote:
04-22-2013, 12:16 | #5 (permalink) |
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | Welcome to Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect SGH-T999 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "USB" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Infineon Selected model: GT-S5220 Selected port: COM363 Phone must be ON. Searching for a phone. Please wait... Found phone on COM363 Reading codes... Reading info... UniqueNumber : 29340000033854 SW Version : S5220XXLAB Reading info failed. ----------------------------------------------------------------------------------- Platform: Samsung Infineon Selected model: GT-S5220 Selected port: COM363 Phone must be ON. Searching for a phone. Please wait... Found phone on COM363 Reading codes... Reading info... UniqueNumber : 29340000033854 SW Version : S5220XXLAB Phone IMEI A: 355371050473293 Deactivating MSL... MSL deactivate successfully Reading codes... Calculating codes. Please wait... PCK :#0141*00000000# NCK :#0111*00000000# SCK :#0121*00000000# SPCK :#0133*00000000# MCK :#0199*00000000# Insert SIM card and type codes. Reading codes successfully completed. NOTWORKING FOR ME!!! |
04-22-2013, 13:13 | #9 (permalink) |
Member: 593920 Status: Offline Sonork: XXXXXX Thanks Meter: 73 | Phone unlock enter sim and press unlock .......thanks octopus team!!! |
The Following User Says Thank You to pak555 For This Useful Post: |
