05-11-2016, 14:50 | #1 (permalink) |
Insane Poster Join Date: Jan 2015 Location: on the moon
Member: 2328492 Status: Offline Thanks Meter: 12 | samsung s6 edge swisscom problem repair imei |
05-11-2016, 15:07 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please remove SIM card from the phone and repeat "Write Cert" operation. Post here result and full Software log of the operation. Also, make sure to use the latest Software version. |
05-11-2016, 21:04 | #3 (permalink) |
Member: 2328492 Status: Offline Thanks Meter: 12 | Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G925F Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925F Firmware compiled date: Fri Oct 2 16:16:37 KST 2015 PDA version: G925FXXU3QOJ4 CSC version: G925FSWV3QOI1 SW version: G925FXXU3COI9 Phone SN: R58G413QHXP Android version: 5.1.1 (LMY47X) Country: Switzerland HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zeroltexx Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G925F Selected file: C:\Users\MAX\Desktop\Nuova cartella (2)\cert-sm-g925f_359522060518883_rf8g50kwdyh.cert Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G925F Firmware compiled date: Fri Oct 2 16:16:37 KST 2015 PDA version: G925FXXU3QOJ4 CSC version: G925FSWV3QOI1 SW version: G925FXXU3COI9 Phone SN: R58G413QHXP Android version: 5.1.1 (LMY47X) Country: Switzerland HW platform: exynos5 HW Chip: exynos7420 HW Modem: SHANNON333 Codename: zeroltexx Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G925F-Unknown11-05-2016_14-48-37-.asec file Checking Certificate file... Certificate file successfully checked Deactivating MSL... Executing exploit... Exploit has been executed successfully Performed by 2.2.5 software version ----------------------------------------------------------------------------------- |
The Following User Says Thank You to maxdanapoli For This Useful Post: |
05-11-2016, 21:49 | #4 (permalink) |
Member: 2328492 Status: Offline Thanks Meter: 12 | dropbox link to this there are two photos that can perhaps be useful to better understand the problem. I apologize for my very bad English link: https://www.dropbox.com/sh/g0psms0bg...rmYuaT7wa?dl=0 |
05-12-2016, 10:34 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to do the next: 1. Reflash the phone. 2. Root the phone with CF Auto Root. 3. Repeat "Write Cert operation. Post here result and full Software log of your actions. |
05-14-2016, 21:39 | #6 (permalink) | |
Member: 2328492 Status: Offline Thanks Meter: 12 | Quote:
I noticed that even after Reflash the phone IMEI remained corrupt and when I go to write certificate does not change anything. I did not post the log because it is identical to the first one I posted. what else can you advise to do to try to solve this problem ?? thank you | |
05-16-2016, 10:21 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to do the next: 1. Perform "Read EFS" operation. 2. Perform "Repair EFS" operation. 3. Repeat "Write Cert" operation. Post here result and full Software logs of performed operations. |
