06-29-2013, 16:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: uk
Member: 973412 Status: Offline Thanks Meter: 117 | samsung s7562 flash done ----------------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-S7562 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. Selected firmware file: S7562XXALK1_S7562QTOALL1_ATO_Android_4.0.4.oct Please switch your phone to the download mode and connect it to a PC. To put GT-S7562 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing APPS section... APPS section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing FAT section... FAT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. |
The Following 2 Users Say Thank You to wasibutt For This Useful Post: |
