07-20-2014, 21:06 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | samsung sc-01c file needed? [Solved] Last edited by Octopus box; 07-25-2014 at 09:46. |
07-21-2014, 06:15 | #3 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
You don't get me, read well before answering what I need is the phone's flash file, where is it and again the model is not listing in the software please how will I flash the phone? | |
07-21-2014, 06:50 | #4 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
07-25-2014, 09:35 | #5 (permalink) | |
Have seen it and it has worked, thanks! flashing log below, for instruction on how to flash it click on the manual button on Octopus software when selected the model! Welcome to Octoplus/Octopus Box Samsung software version 1.6.0 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. Selected firmware file: SC01COMLI1_SC01CDCMLI1_Japan_Android_2.3.6.oct Please switch your phone to the download mode and connect it to a PC. To put SC-01C device into download mode you have to perform the following steps: 1. Power off device. 2. Press and hold "Volume - " + "Power" buttons. Found phone on Firmware write started. Writing IBL+PBL section... IBL+PBL section has been written successfully. Writing SBL section... SBL section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing FACTORYFS section... FACTORYFS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Firmware writing successfully completed. | |
