Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 03-16-2013, 11:28   #1 (permalink)
Member: 1288857
Thanks Meter: 11
Samsung SC-03E (Docomo Galaxy S III) Easy to Unlock "READ CODE" only
Samsung SC-03E (Docomo Galaxy S III) Unlock Done
Procedure : I
To connect SC-03E phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "UART" radio button to "MODEM" value
8. Go to "Qualcomm USB Settings"
9. Select "RNDIS+DM+MODEM".
10. Close window.
11. Go to dial window.
12. Press "Read Info" in software.
Procedure : II
1. Enter "*#7284#" number.
2. Set "USB" radio button to "PDA" value.
3. select (check) "Manual select" option and try again with each COM port
READ CODE DONE
DONE
The Following 3 Users Say Thank You to lanmmt For This Useful Post:
Old 03-27-2013, 11:50   #2 (permalink)
Member: 1856590
Thanks Meter: 3
Welcome to Octopus Box Samsung software version 1.8.3
7. Set "UART" radio button to "MODEM" value.
8. Go to "Qualcomm USB Settings".
10. Close window.
Platform: Samsung Android
Selected port: COM148
Selected model: SC-03E
Mode: Normal
Phone model: ACEFWMAZ
Warning: Selected model (SC-03E) differs from the detected one
(ACEFWMAZ)!
Firmware compiled date: Nov 20 2012
Firmware compiled time: 00:00:00
Firmware released date: Feb 8 2013
Firmware released time: 08:46:08
Phone IMEI: 353986-05-024742-1
SW Version: M9615A-CEFWMAZM-2.0.146012
Unlocking phone...
Phone is successfully unlocked
Please, restart the phone to apply changes
The Following 2 Users Say Thank You to no1tkt For This Useful Post:
Old 04-15-2013, 08:10   #3 (permalink)
Member: 215177
Thanks Meter: 18
samsung sc-03 unlocking
it is right way to read code for sc-03 by octopus
9. Select "DM+MODEM+ADB"and tab OK.
10.Next type *#9090# on phone
11.Salect DM/DUN over HSIC
12.wait for phone to resrart
13. select (check) "Manual select" option and try again with each COM port
Old 05-29-2013, 08:54   #4 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 210
Samsung SC-03E cant unlock
Samsung SC-03E (Docomo Galaxy S III) ,
when key in *#9090# or *#7284*
nothing happen, how to unlock it ?
I tried with uart or usb don't detect
I needed help please
Old 05-29-2013, 09:04   #5 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,975
Try to re-flash your phone and repeat the operation.
Old 05-29-2013, 10:17   #6 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 210
I have re-flash ready but still the same, I have 2 phnones the same problem
Old 05-29-2013, 10:40   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Currently we don't know another way how to connect your device. Try to search and write different firmwares and try again...
Old 05-29-2013, 17:40   #8 (permalink)
ZiDanRO's Avatar
Member: 1722871
Thanks Meter: 117
Bro, do a factory reset and when you configure your phone DON'T use Docomo Launcher, USE the TW Launcher. That is why your codes don't work.
No need to flash.
Also check you IMEI, if you don't have IMEI then this is another motive to not work *#9090#
Old 10-10-2013, 13:15   #9 (permalink)
Member: 1354455
Sonork: 100.1637595
Thanks Meter: 54
how to repair Unknown baseband and also IMEI repair.
*#9090# code not working, only blank screen.
how to fix it.
Old 10-10-2013, 15:30   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Most likely, phopne's EFS is damaged. Octopus/Octoplus Software currently doesn't support Repair EFS for this device.
Old 10-16-2014, 17:38   #11 (permalink)
jawed_ali's Avatar
Member: 724704
Sonork: 100.1605390
Thanks Meter: 91
Many time try imei rep but its say phone emergency how to solve my phone is rooted any buddy help me
Old 10-16-2014, 17:56   #12 (permalink)
Member: 1146942
Sonork: 100.1587278
This means the phone is not connected correctly and doesn't answer to Software requests (CMDs). To connect the phone, carefully perform all steps from the first post above:
10. Close window.
Old 10-16-2014, 18:18   #13 (permalink)
Cheater -Don't Deal with him-
Member: 1965371
Thanks Meter: 447
change ypur keypad to samsung keypad
Old 10-17-2014, 10:11   #14 (permalink)
jawed_ali's Avatar
Member: 724704
Sonork: 100.1605390
Thanks Meter: 91
i am all ready chk all cmd even i try all its same problem
i need remortly help hoe can i do this 3 days itry but not done
Old 10-17-2014, 10:38   #15 (permalink)
Member: 1146942
Sonork: 100.1587278
What is the IMEI in your device, what is the phone's baseband exactly? Try to re-flash the phone and then connect again. Post here full Software log.
Page generated in 0.67469 seconds with 7 queries
