10-17-2015, 20:58 | #1 (permalink) |
Major Poster Join Date: Dec 2013 Location: Zvezdara,Belgrade, Serbia
Member: 2087554 Status: Offline Thanks Meter: 8 | Samsung SC-05G not unlock with octopus INFO : 17.10.2015 19:13:40 > Selected port: COM8 INFO : 17.10.2015 19:13:40 > Selected model: SC-05G INFO : 17.10.2015 19:13:41 > Detected phone model: SC-05G INFO : 17.10.2015 19:13:41 > Firmware compiled date: Fri Sep 4 13:53:43 KST 2015 INFO : 17.10.2015 19:13:42 > PDA version: SC05GOMU1AOI1 INFO : 17.10.2015 19:13:42 > CSC version: SC05GDCM1AOI1 INFO : 17.10.2015 19:13:43 > SW version: SC05GOMU1AOI1 INFO : 17.10.2015 19:13:44 > Phone IMEI: Unknown INFO : 17.10.2015 19:13:44 > Phone SN: R38G40NF4AZ INFO : 17.10.2015 19:13:44 > Android version: 5.0.2 (LRX22G) INFO : 17.10.2015 19:13:44 > Checking Root: INFO : 17.10.2015 19:13:45 > Phone is Rooted. INFO : 17.10.2015 19:13:45 > Unlocking phone... INFO : 17.10.2015 19:14:02 > Phone is successfully unlocked WARN : 17.10.2015 19:14:02 > To finish the operation, please restart the phone via phone's PHONE NOT UNLOCK |
10-19-2015, 09:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What exactly You mean by "not unlock"? Please explain the problem in more details. Also, please install latest Software version, remove SD and SIM cards from the phone, then repeat "Unlock" operation. Check whether phone obtains previously unsupported SIM cards. Post here result and full Software log of performed operation. |
10-20-2015, 08:04 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ho Chi Minh Age: 43
Member: 129163 Status: Offline Thanks Meter: 67 | Welcome to Octoplus/Octopus Box Samsung software version 2.0.8 Platform: Samsung Android Selected port: COM1 Selected model: SC-05G Detected phone model: SC-05G Firmware compiled date: Sat Apr 18 11:30:05 KST 2015 PDA version: SC05GOMU1AOD2 CSC version: SC05GDCM1AOD2 SW version: SC05GOMU1AOD2 Phone IMEI: Unknown Phone SN: R38G400W4EE Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Phone still ask unlock code |
10-20-2015, 09:48 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please make Factory Reset and reflash the phone. Repeat "Unlock" operation after writing of a firmware. Post here result and full Software logs of performed operations. |
10-20-2015, 11:51 | #5 (permalink) |
Member: 129163 Status: Offline Thanks Meter: 67 | Welcome to Octoplus/Octopus Box Samsung software version 2.0.8 ----------------------------------------------------------------------------------- To connect SC-05G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-05G Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SC-05G Firmware compiled date: Sun May 3 21:26:35 KST 2015 PDA version: SC05GOMU1AOE1 CSC version: SC05GDCM1AOE1 SW version: SC05GOMU1AOE1 Phone IMEI: Unknown Phone SN: R38G400W4EE Android version: 5.0.2 (LRX22G) Updating DIAG confing... DIAG confing is succesfully enabled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-05G Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-05G Detected phone model: SC-05G Firmware compiled date: Sun May 3 21:26:35 KST 2015 PDA version: SC05GOMU1AOE1 CSC version: SC05GDCM1AOE1 SW version: SC05GOMU1AOE1 Phone IMEI: Unknown Phone SN: R38G400W4EE Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Unlocking phone... Phone is successfully unlocked same phone still locked |
10-20-2015, 12:44 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please upload *.log and *.logx files of "Unlock" operation and post here download link. We will check where can be the problem. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
09-21-2016, 17:35 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If you cannot Unlock or Reset MSL on a Qualcomm phone, you need to check phone's firmware release date. If firmware was released after 01.10.2015, then you can try to downgrade phone?s firmware (write older, by release date, version of firmware). |
02-20-2017, 14:59 | #9 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: wazirabad gujranwala pakistan Age: 30
Member: 2158722 Status: Offline Sonork: 1668812 Thanks Meter: 39 | same problem with me how to solve it? Quote:
i am confusssed | |
