05-08-2015, 17:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | Samsung SM-A500F emergency calls only here is logs Platform: Samsung Android Selected port: COM299 Selected model: SM-A500F Detected phone model: SM-A500F Firmware compiled date: Fri Dec 5 19:02:02 KST 2014 PDA version: A500FXXU1ANL1 CSC version: A500FSKZ1ANL1 SW version: A500FXXU1ANK4 Phone IMEI: Unknown Phone SN: RF8G105M6PD Android version: 4.4.4 (KTU84P) Reading info... Mode: Normal Firmware compiled date: Nov 28 2014 Firmware compiled time: 03:00:00 Firmware released date: Nov 29 2014 Firmware released time: 11:48:57 SW Version: MPSS.DPM.1.0.c7.1-00056-M8916EAAAANVZM-1.9904.1 Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-A500F-08-05-2015_21-19-20-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-A500F-08-05-2015_21-19-20-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Nov 28 2014 Firmware compiled time: 03:00:00 Firmware released date: Nov 29 2014 Firmware released time: 11:48:57 SW Version: MPSS.DPM.1.0.c7.1-00056-M8916EAAAANVZM-1.9904.1 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM299 Selected model: SM-A500F Selected file: C:\Documents and Settings\MAHAD\My Documents \Downloads\Cert-SM-A500F_356317062038144.cert Select Certificate2... Selected file: C:\Documents and Settings\MAHAD\My Documents \Downloads\Cert-SM-A500F_356316062038146.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM8 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Platform: Samsung Android Selected port: COM299 Selected model: SM-A500F Reading info... Mode: Normal Firmware compiled date: Nov 28 2014 Firmware compiled time: 03:00:00 Firmware released date: Nov 29 2014 Firmware released time: 11:48:57 SW Version: MPSS.DPM.1.0.c7.1-00056-M8916EAAAANVZM-1.9904.1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes |
The Following User Says Thank You to shh_903 For This Useful Post: |
05-08-2015, 18:01 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to write QCN from the Support Area, restart the phone, wait 2-5 minutes and try to select Network manually. |
05-09-2015, 09:23 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Check, whether IMEI of Certificate file, which You wrote, is not in "black" list of network provider. If IMEI is "Ok" - read out QCN of correctly working SM-A500F and write it into your phone. Otherwise, try to find and write another Cert file. |
05-09-2015, 21:48 | #5 (permalink) | |
Member: 392149 Status: Offline Thanks Meter: 199 | Quote:
here is logs Platform: Samsung Android Selected port: COM323 Selected model: SM-A500F Reading info... Mode: Normal Firmware compiled date: Nov 28 2014 Firmware compiled time: 03:00:00 Firmware released date: Nov 29 2014 Firmware released time: 11:48:57 SW Version: MPSS.DPM.1.0.c7.1-00056-M8916EAAAANVZM-1.9904.1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes | |
05-11-2015, 10:33 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | After writing a QCN file from correctly working phone there should not be any problems with network. Try to do the next: 1. Write first Security backup back into the phone. 2. Reflash the phone. 3. Perform "Read QCN" operation. 4. Perform "Wipe Security" operation. 5. Perform "Write Cert" operation. 6. Write QCN backup created on step 3 back into the phone/Write QCN backup from another, correctly working SM-A500F, restart the phone, wait 2-5 minutes and try to select network manually. (optional). Post here full Software log of all performed operations. |
03-13-2016, 03:32 | #7 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Jeddah, Saudi Arabia
Member: 1911337 Status: Offline Thanks Meter: 38 | Quote:
I wrote readed qcn file from working phone but nothing new Can u help for that? Regards | |
03-13-2016, 05:37 | #8 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Sweden/Stockholm
Member: 1736454 Status: Offline Thanks Meter: 82 | Salomalekum Abdullah Shafiq! You must first 1-wipe efs octopus 2-write cet via usb, if this does not work write qcn file I have done many times always worked Cert-SM-A500F_356316062038146.cert Cert-SM-A500F_356317062038144.cert A500F_mpss.dpm.1.0.c7.1-00045-m8916eaaaanvzm-1.7069.1.7297.1.qcn posted file here:https://yadi.sk/d/So7H_gA9q86kG |
The Following 5 Users Say Thank You to jonpulat For This Useful Post: |
03-14-2016, 03:27 | #10 (permalink) | |
Finally my problem solved by your given steps. But I can feel that signals are low when simcard inserted any solution for that or its ok? Regards Abdullah Shafique | |
The Following User Says Thank You to Abdullah Shafiq For This Useful Post: |
03-14-2016, 05:25 | #11 (permalink) |
Member: 1736454 Status: Offline Thanks Meter: 82 | so bro...first do repair nvm and check signal! if problem not sloved ..... second repair other qcn check signal! |
The Following User Says Thank You to jonpulat For This Useful Post: |
