04-25-2015, 07:38 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 838176 Status: Offline Thanks Meter: 57 | samsung sm-A700FD unlock probelem log file Welcome to Octoplus/Octopus Box Samsung software version 1.9.3 ----------------------------------------------------------------------------------- To connect GT-N7000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-A700FD phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-A700FD Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM119 Mode: Normal Phone model: SM-A700FD Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 12 2015 Firmware released time: 20:48:28 Phone IMEI: 358637-06-014715-1 SW version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM119 Selected model: SM-A700FD Reading info... Mode: Normal Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 12 2015 Firmware released time: 20:48:28 SW Version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 Detected phone model: SM-A700FD Firmware compiled date: Wed Jan 14 01:17:40 KST 2015 PDA version: A700FDXXU1AOA8 CSC version: A700FDOJV1AOA2 SW version: A700FDXXU1AOA2 Phone IMEI: 358637060147151 Phone SN: RF8G11M93RK Android version: 4.4.4 (KTU84P) Checking Root: Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ------------------------------------------------------------------------- |
05-18-2015, 14:10 | #5 (permalink) |
Freak Poster Join Date: Jan 2011 Location: bangladesh
Member: 1483660 Status: Offline Sonork: 100.1601918 Thanks Meter: 155 | help pls Welcome to Octoplus/Octopus Box Samsung software version 1.9.5 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-A700FD phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A700FD Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM6 Phone connection failed Connecting to phone on COM7 Mode: Normal Phone model: SM-A700FD Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 9 2015 Firmware released time: 16:49:57 Phone IMEI: 358637-06-266331-2 SW version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-A700FD Reading info... Mode: Normal Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 9 2015 Firmware released time: 16:49:57 SW Version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-A700FD Firmware compiled date: Thu Jan 15 23:02:50 KST 2015 PDA version: A700FDXXU1AOAB CSC version: A700FDOLB1AOA4 SW version: A700FDXXU1AOA1 Phone IMEI: 358637062663312 Phone SN: RF8G311TSAT Android version: 4.4.4 (KTU84P) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-A700FD Mode: Normal Phone model: SM-A700FD Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 9 2015 Firmware released time: 16:49:57 Phone IMEI: 358637-06-266331-2 SW version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-A700FD Reading info... Mode: Normal Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 9 2015 Firmware released time: 16:49:57 SW Version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 Detected phone model: SM-A700FD Firmware compiled date: Thu Jan 15 23:02:50 KST 2015 PDA version: A700FDXXU1AOAB CSC version: A700FDOLB1AOA4 SW version: A700FDXXU1AOA1 Phone IMEI: 358637062663312 Phone SN: RF8G311TSAT Android version: 4.4.4 (KTU84P) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-A700FD Mode: Normal Phone model: SM-A700FD Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 9 2015 Firmware released time: 16:49:57 Phone IMEI: 358637-06-266331-2 SW version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SM-A700FD Reading info... Mode: Normal Firmware compiled date: Dec 23 2014 Firmware compiled time: 05:00:00 Firmware released date: Jan 9 2015 Firmware released time: 16:49:57 SW Version: MPSS.DPM.2.0.c5-00030-M8936FAAAANUZM- 1.11349.1.11526.1.11611.1 Detected phone model: SM-A700FD Firmware compiled date: Thu Jan 15 23:02:50 KST 2015 PDA version: A700FDXXU1AOAB CSC version: A700FDOLB1AOA4 SW version: A700FDXXU1AOA1 Phone IMEI: 358638062xxxxxxx Phone SN: RF8G311TSAT Android version: 4.4.4 (KTU84P) Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) but not unlock i can try 00000000 unlock successfully but same need help any solicitation thanks to all gsm friends |
05-18-2015, 14:41 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If after "Unlock" phone still requests Unlock code, then currently only two ways, how to Unlock the phone - find and write IMEI Certificate or buy unlocking code by IMEI. |
