04-12-2017, 09:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | samsung sm g610f frp problem Welcome to Octoplus/Octopus Box Samsung software version 2.5.0 ----------------------------------------------------------------------------------- To connect SM-G750H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Selected firmware file: COMBINATION_ODD_FA60_G610FDDU1API2 _ODDFA60_G610FDDU1API2_CL9139094_QB10968271.oct Selected firmware file: COMBINATION_ODD_FA60_G610FDDU1API2 _ODDFA60_G610FDDU1API2_CL9139094_QB10968271.oct Please put the phone into Download Mode and connect USB cable. To put SM-G610F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.5.0 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-G610F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.5.0 Software version. after that phone say install aplication then no response then restart any other ways? Last edited by Octopus box; 04-12-2017 at 09:29. |
04-12-2017, 09:22 | #2 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: delhi
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | frp solution tested by me Quote:
only boot n sboot file thn u r adb on now u can frp reset | |
04-12-2017, 09:30 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. If phone doesn't boot into normal mode after writing of Combination firmware, or its boot.img - it is not compatible with current firmware of the phone. You should try to use different combination firmware. |
04-12-2017, 09:34 | #5 (permalink) |
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | i will try flash with g610fxxu1apk1 its work with combination file from support COMBINATION_ODD_FA60_G610FDDU1API2_ODDFA60_G610FDD U1API2_CL9139094_QB10968271 |
04-13-2017, 11:06 | #6 (permalink) |
Insane Poster Join Date: Dec 2009 Location: Serbia
Member: 1175250 Status: Offline Thanks Meter: 10 | I flash with comb file from octopus support. Welcome to Octoplus/Octopus Box Samsung software version 2.5.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM160 Selected model: SM-G610F Searching for a phone (waiting for ADB device)... Reading info... Detected phone model: SM-G610F Firmware compiled date: Tue Sep 20 20:14:13 KST 2016 PDA version: FA60_G610FDDU1API2 CSC version: unknown SW version: G610FDDU1API2 Phone SN: R28HC1K3D8H Android version: 6.0.1 (MMB29K) Sales code: unknown Country: unknown HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2016-08-01 Codename: on7xeltedd Resetting FRP lock.. FRP lock is successfully reseted! Goto "Menu->Settings->Backup and reset" and make "Factory data reset" Performed by 2.5.1 Software version. I tried solution 1.to make factory reset from menu,but Frp is still ON 2.I flash comb file from support i and i DID NOT make hard reset and i flash stock file(only PDA),phone boot normaly,but ADB is not activated 3.Comb file and I flash stock firmware 4 files ,phone boot normaly but ADB is not activated Any solution? |
04-13-2017, 11:18 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You wrote fill Combination firmware there's no need to make "Reset FRP". Here are two methods, of how to reset FPR using Combination firmware (to enable ADB): I.
II.
You can write "boot.img", Combination firmware or to downgrade phone's firmware version only on your own risk! These methods should be used separately. You can't combine steps from both. |
04-13-2017, 14:02 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If You were able to make Factory Reset from phone Settings after the operation - FRP lock should be gone. Please repeat "Reset FRP" operation and carefully follow all of the Software prompts. |
04-13-2017, 14:12 | #15 (permalink) |
Member: 1175250 Status: Offline Thanks Meter: 10 | I do not know if we understand each other. Only when i can to make factory reset,is when i put combin firmware in the phone.In that case box do the FRP reset,i make the factory reset from the menu.When i flash with stock firmware(i tryed 10 different)FRP is always ON I tryed solution which you provide me in the post num 7,thanks |
