06-07-2016, 13:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | samsung sm-g900k diag mode problem i have problem in to activate diag mode on samsung sm-g900k with android 5.0 lollipop.i have check different combinations... ##3424#_____*#0808#____*#7284#_____*#9090#_____##3 66633# all the above codes are checked but nt working.....phone have imei problem Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.7 ----------------------------------------------------------------------------------- To connect SM-G900K phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM94 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM5 Phone connection failed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Reading info, please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900K Firmware compiled date: Thu Dec 4 00:01:35 KST 2014 PDA version: G900KKTU1BNL2 CSC version: G900KKTC1BNL2 SW version: G900KKTU1BNKH Phone SN: 00000000000 Android version: 5.0 (LRX21T) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K ADB server killed. Detected phone model: SM-G900K Firmware compiled date: Thu Dec 4 00:01:35 KST 2014 PDA version: G900KKTU1BNL2 CSC version: G900KKTC1BNL2 SW version: G900KKTU1BNKH Phone SN: 00000000000 Android version: 5.0 (LRX21T) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Reading info... Phone was not found on the selected port! Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Detected phone model: SM-G900K Firmware compiled date: Thu Dec 4 00:01:35 KST 2014 PDA version: G900KKTU1BNL2 CSC version: G900KKTC1BNL2 SW version: G900KKTU1BNKH Phone SN: 00000000000 Android version: 5.0 (LRX21T) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Updating DIAG confing... DIAG confing is succesfully enabled. Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS \SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\cert-sm-g900f_ 353110060712502_r58f0sft2t.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM5 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Writing Certificate failed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G900K Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS \SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\SM-G900F_ 353110060712452_R58F0SFT2T.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM5 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Writing Certificate failed Performed by 2.2.7 software version |
06-08-2016, 06:01 | #4 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.7 ----------------------------------------------------------------------------------- To connect SM-G900K phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Reading info, please wait... Detected phone model: SM-G900K Firmware compiled date: Thu Dec 4 00:01:35 KST 2014 PDA version: G900KKTU1BNL2 CSC version: G900KKTC1BNL2 SW version: G900KKTU1BNKH Phone SN: 00000000000 Android version: 5.0 (LRX21T) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Reading info... Phone was not found on the selected port! Operation was failed! Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Reading info... Phone was not found on the selected port! Operation was failed! Performed by 2.2.7 software version | |
06-08-2016, 12:18 | #9 (permalink) | |
Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.7 ----------------------------------------------------------------------------------- To connect SM-G900K phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM94 Phone connection failed No diagnostic ports found! Connecting to phone on COM5 Phone connection failed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-G900K Firmware compiled date: Thu Dec 4 00:01:35 KST 2014 PDA version: G900KKTU1BNL2 CSC version: G900KKTC1BNL2 SW version: G900KKTU1BNKH Phone SN: 00000000000 Android version: 5.0 (LRX21T) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Updating DIAG confing... DIAG confing is succesfully enabled. Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Reading info... Phone was not found on the selected port! Operation was failed! Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Reading info... Phone was not found on the selected port! Operation was failed! Performed by 2.2.7 software version | |
06-08-2016, 13:08 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Try to perform "Read Info" operation from "Main" tab of the Software on different COM ports, with enabled "Manual select" option. Post here full Software log of performed operations. |
06-09-2016, 06:26 | #11 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | how i can perform full log info if i have no diag port in device manger.i alreday told the phone not accepted diag menu codes........... |
06-11-2016, 07:03 | #14 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | @SUPPORT PLEASE CHECK THE FOLLOWING LOGS Code: Log file "E:\Backup Data\TORNADO\TOOL_BOXs\Octoplus\Octoplus_samsung_portable\LOG\11-06-2016_10-39-26.log" created (6/11/2016 10:39:29 AM). INFO : 6/11/2016 10:39:36 AM > Set up system language English (file: English.ini) INFO : 6/11/2016 10:39:36 AM > Welcome to Octoplus/Octopus Box Samsung software version 2.2.7 INFO : 6/11/2016 10:39:41 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:39:41 AM > To connect SM-G530H phone you have to perform the following steps: INFO : 6/11/2016 10:39:41 AM > 1. Disconnect USB cable from phone. INFO : 6/11/2016 10:39:41 AM > 2. Go to Menu->Settings->More->About Device. INFO : 6/11/2016 10:39:41 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/11/2016 10:39:41 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/11/2016 10:39:41 AM > 5. Turn on "USB Debugging" option. INFO : 6/11/2016 10:39:41 AM > 6. Go to dial window. INFO : 6/11/2016 10:39:41 AM > 7. Enter "*#0808#" number. INFO : 6/11/2016 10:39:41 AM > 8. Select "DM+Modem+ADB". INFO : 6/11/2016 10:39:41 AM > 9. Press Home button. INFO : 6/11/2016 10:39:41 AM > 10. Restart phone. INFO : 6/11/2016 10:39:41 AM > 11. Press "Read Info" in software. INFO : 6/11/2016 10:39:46 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:39:46 AM > To connect SM-G900K phone you have to perform the following steps: INFO : 6/11/2016 10:39:46 AM > 1. Disconnect USB cable from phone. INFO : 6/11/2016 10:39:46 AM > 2. Go to Menu->Settings->More->About Device. INFO : 6/11/2016 10:39:46 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/11/2016 10:39:46 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/11/2016 10:39:46 AM > 5. Turn on "USB Debugging" option. INFO : 6/11/2016 10:39:46 AM > 6. Go to dial window. INFO : 6/11/2016 10:39:46 AM > 7. Enter "*#0808#" number. INFO : 6/11/2016 10:39:46 AM > 8. Select "DM+Modem+ADB". INFO : 6/11/2016 10:39:46 AM > 9. Press Home button. INFO : 6/11/2016 10:39:46 AM > 10. Restart phone. INFO : 6/11/2016 10:39:46 AM > 11. Press "Read Info" in software. INFO : 6/11/2016 10:39:50 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:39:50 AM > Platform: Samsung Android INFO : 6/11/2016 10:39:50 AM > Selected port: COM14 INFO : 6/11/2016 10:39:50 AM > Selected model: SM-G900K INFO : 6/11/2016 10:39:50 AM > Port is busy INFO : 6/11/2016 10:39:54 AM > Phone was not found on the selected port! INFO : 6/11/2016 10:39:54 AM > Searching for USB diagnostic port... INFO : 6/11/2016 10:39:54 AM > Connecting to phone on COM92 INFO : 6/11/2016 10:39:54 AM > Mode: Normal INFO : 6/11/2016 10:39:54 AM > Phone model: SM-G900K INFO : 6/11/2016 10:39:54 AM > Firmware compiled date: Mar 06 2014 INFO : 6/11/2016 10:39:54 AM > Firmware compiled time: 15:00:00 INFO : 6/11/2016 10:39:54 AM > Firmware released date: Apr 22 2014 INFO : 6/11/2016 10:39:54 AM > Firmware released time: 18:19:42 INFO : 6/11/2016 10:39:54 AM > Phone IMEI: 000000-00-000000-0 INFO : 6/11/2016 10:39:54 AM > SW version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 INFO : 6/11/2016 10:39:54 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:40:00 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:40:01 AM > Platform: Samsung Android INFO : 6/11/2016 10:40:01 AM > Selected port: COM92 INFO : 6/11/2016 10:40:01 AM > Selected model: SM-G900K INFO : 6/11/2016 10:40:01 AM > Reading info... INFO : 6/11/2016 10:40:01 AM > Mode: Normal INFO : 6/11/2016 10:40:01 AM > Firmware compiled date: Mar 06 2014 INFO : 6/11/2016 10:40:01 AM > Firmware compiled time: 15:00:00 INFO : 6/11/2016 10:40:01 AM > Firmware released date: Apr 22 2014 INFO : 6/11/2016 10:40:01 AM > Firmware released time: 18:19:42 INFO : 6/11/2016 10:40:01 AM > SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 INFO : 6/11/2016 10:40:01 AM > Reseting MSL... WARN : 6/11/2016 10:40:01 AM > MSL reset successfully. INFO : 6/11/2016 10:40:01 AM > Please, restart the phone to apply changes INFO : 6/11/2016 10:40:01 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:40:03 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:40:04 AM > Platform: Samsung Android INFO : 6/11/2016 10:40:04 AM > Selected port: COM92 INFO : 6/11/2016 10:40:04 AM > Selected model: SM-G900K INFO : 6/11/2016 10:40:04 AM > Reading info... INFO : 6/11/2016 10:40:04 AM > Mode: Normal INFO : 6/11/2016 10:40:04 AM > Firmware compiled date: Mar 06 2014 INFO : 6/11/2016 10:40:04 AM > Firmware compiled time: 15:00:00 INFO : 6/11/2016 10:40:04 AM > Firmware released date: Apr 22 2014 INFO : 6/11/2016 10:40:04 AM > Firmware released time: 18:19:42 INFO : 6/11/2016 10:40:04 AM > SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 INFO : 6/11/2016 10:40:04 AM > Reseting MSL... WARN : 6/11/2016 10:40:07 AM > MSL reset successfully. INFO : 6/11/2016 10:40:07 AM > Please, restart the phone to apply changes INFO : 6/11/2016 10:40:08 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:40:18 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:40:19 AM > Platform: Samsung Android INFO : 6/11/2016 10:40:19 AM > Selected port: COM92 INFO : 6/11/2016 10:40:19 AM > Selected model: SM-G900K INFO : 6/11/2016 10:40:34 AM > Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS\SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\SM-G900F_35255806745641_0478.cert WARN : 6/11/2016 10:40:35 AM > Perform the following steps: WARN : 6/11/2016 10:40:35 AM > 1. Connect phone via UART cable to the Box. WARN : 6/11/2016 10:40:35 AM > 2. Note: phone screen must be active INFO : 6/11/2016 10:40:35 AM > Connecting to phone, please wait... INFO : 6/11/2016 10:40:40 AM > Found phone on COM5 INFO : 6/11/2016 10:40:40 AM > Phone connected successfully INFO : 6/11/2016 10:40:40 AM > Checking Certificate file... INFO : 6/11/2016 10:40:43 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:40:51 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:40:52 AM > Platform: Samsung Android INFO : 6/11/2016 10:40:52 AM > Selected port: COM5 INFO : 6/11/2016 10:40:52 AM > Selected model: SM-G900K INFO : 6/11/2016 10:41:03 AM > Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS\SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\SM-G900F_352558067456393_00000000000.cert WARN : 6/11/2016 10:41:05 AM > Perform the following steps: WARN : 6/11/2016 10:41:05 AM > 1. Connect phone via UART cable to the Box. WARN : 6/11/2016 10:41:05 AM > 2. Note: phone screen must be active INFO : 6/11/2016 10:41:05 AM > Connecting to phone, please wait... INFO : 6/11/2016 10:41:10 AM > Found phone on COM5 INFO : 6/11/2016 10:41:10 AM > Phone connected successfully INFO : 6/11/2016 10:41:10 AM > Checking Certificate file... INFO : 6/11/2016 10:41:10 AM > Certificate file successfully checked INFO : 6/11/2016 10:41:10 AM > Writing new phone IMEI... ERROR : 6/11/2016 10:41:27 AM > Writing Certificate failed INFO : 6/11/2016 10:41:27 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:41:33 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:41:34 AM > Platform: Samsung Android INFO : 6/11/2016 10:41:34 AM > Selected port: COM5 INFO : 6/11/2016 10:41:34 AM > Selected model: SM-G900K INFO : 6/11/2016 10:41:44 AM > Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS\SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\SM-G900F_CERT_353110060701687.cert WARN : 6/11/2016 10:41:45 AM > Perform the following steps: WARN : 6/11/2016 10:41:45 AM > 1. Connect phone via UART cable to the Box. WARN : 6/11/2016 10:41:45 AM > 2. Note: phone screen must be active INFO : 6/11/2016 10:41:45 AM > Connecting to phone, please wait... INFO : 6/11/2016 10:41:50 AM > Found phone on COM5 INFO : 6/11/2016 10:41:50 AM > Phone connected successfully INFO : 6/11/2016 10:41:51 AM > Checking Certificate file... INFO : 6/11/2016 10:41:51 AM > Certificate file successfully checked INFO : 6/11/2016 10:41:51 AM > Writing new phone IMEI... ERROR : 6/11/2016 10:42:07 AM > Writing Certificate failed INFO : 6/11/2016 10:42:07 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:42:34 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:42:35 AM > Platform: Samsung Android INFO : 6/11/2016 10:42:35 AM > Selected port: COM5 INFO : 6/11/2016 10:42:35 AM > Selected model: SM-G900K INFO : 6/11/2016 10:42:38 AM > Detected phone model: SM-G900K INFO : 6/11/2016 10:42:38 AM > Firmware compiled date: Fri May 30 15:32:09 KST 2014 INFO : 6/11/2016 10:42:38 AM > PDA version: G900KKTU1ANE8 INFO : 6/11/2016 10:42:38 AM > CSC version: G900KKTC1ANE8 INFO : 6/11/2016 10:42:38 AM > SW version: G900KKTU1AND8 INFO : 6/11/2016 10:42:38 AM > Phone IMEI: 000000000000000 INFO : 6/11/2016 10:42:38 AM > Phone SN: 00000000000 INFO : 6/11/2016 10:42:38 AM > Android version: 4.4.2 (KOT49H) INFO : 6/11/2016 10:42:38 AM > Country: KOREA INFO : 6/11/2016 10:42:38 AM > HW platform: msm8974 INFO : 6/11/2016 10:42:38 AM > HW Chip: MSM8974PRO INFO : 6/11/2016 10:42:38 AM > HW Modem: MSM8974PRO INFO : 6/11/2016 10:42:38 AM > Codename: kltektt INFO : 6/11/2016 10:42:38 AM > Reading info... INFO : 6/11/2016 10:42:38 AM > Mode: Normal INFO : 6/11/2016 10:42:38 AM > Firmware compiled date: Mar 06 2014 INFO : 6/11/2016 10:42:38 AM > Firmware compiled time: 15:00:00 INFO : 6/11/2016 10:42:39 AM > Firmware released date: Apr 22 2014 INFO : 6/11/2016 10:42:39 AM > Firmware released time: 18:19:42 INFO : 6/11/2016 10:42:39 AM > SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 INFO : 6/11/2016 10:42:39 AM > Checking Root: INFO : 6/11/2016 10:42:39 AM > Phone is Rooted. INFO : 6/11/2016 10:42:39 AM > Reading security backup, please wait... INFO : 6/11/2016 10:43:53 AM > Backup saved as E:\Backup Data\TORNADO\TOOL_BOXs\Octoplus\Octoplus_samsung_portable\BACKUP\Security-SM-G900K-000000000000000-11-06-2016_10-42-39-.asec file INFO : 6/11/2016 10:43:53 AM > Wiping EFS... Code: Log file "E:\Backup Data\TORNADO\TOOL_BOXs\Octoplus\Octoplus_samsung_portable\LOG\11-06-2016_10-44-58.log" created (6/11/2016 10:45:01 AM). INFO : 6/11/2016 10:45:08 AM > Set up system language English (file: English.ini) INFO : 6/11/2016 10:45:08 AM > Welcome to Octoplus/Octopus Box Samsung software version 2.2.7 INFO : 6/11/2016 10:45:13 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:45:13 AM > To connect SM-G530H phone you have to perform the following steps: INFO : 6/11/2016 10:45:13 AM > 1. Disconnect USB cable from phone. INFO : 6/11/2016 10:45:13 AM > 2. Go to Menu->Settings->More->About Device. INFO : 6/11/2016 10:45:13 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/11/2016 10:45:13 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/11/2016 10:45:13 AM > 5. Turn on "USB Debugging" option. INFO : 6/11/2016 10:45:13 AM > 6. Go to dial window. INFO : 6/11/2016 10:45:13 AM > 7. Enter "*#0808#" number. INFO : 6/11/2016 10:45:13 AM > 8. Select "DM+Modem+ADB". INFO : 6/11/2016 10:45:13 AM > 9. Press Home button. INFO : 6/11/2016 10:45:13 AM > 10. Restart phone. INFO : 6/11/2016 10:45:13 AM > 11. Press "Read Info" in software. INFO : 6/11/2016 10:45:34 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:45:34 AM > To connect SM-G900K phone you have to perform the following steps: INFO : 6/11/2016 10:45:34 AM > 1. Disconnect USB cable from phone. INFO : 6/11/2016 10:45:34 AM > 2. Go to Menu->Settings->More->About Device. INFO : 6/11/2016 10:45:34 AM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 6/11/2016 10:45:34 AM > 4. Go to Menu->Settings->More->Developer options. INFO : 6/11/2016 10:45:34 AM > 5. Turn on "USB Debugging" option. INFO : 6/11/2016 10:45:34 AM > 6. Go to dial window. INFO : 6/11/2016 10:45:34 AM > 7. Enter "*#0808#" number. INFO : 6/11/2016 10:45:34 AM > 8. Select "DM+Modem+ADB". INFO : 6/11/2016 10:45:34 AM > 9. Press Home button. INFO : 6/11/2016 10:45:34 AM > 10. Restart phone. INFO : 6/11/2016 10:45:34 AM > 11. Press "Read Info" in software. INFO : 6/11/2016 10:45:38 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:45:39 AM > Platform: Samsung Android INFO : 6/11/2016 10:45:39 AM > Selected port: COM14 INFO : 6/11/2016 10:45:39 AM > Selected model: SM-G900K INFO : 6/11/2016 10:45:45 AM > Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS\SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\SM-G900F_35255806745642_0478.cert INFO : 6/11/2016 10:45:47 AM > Detected phone model: SM-G900K INFO : 6/11/2016 10:45:47 AM > Firmware compiled date: Fri May 30 15:32:09 KST 2014 INFO : 6/11/2016 10:45:47 AM > PDA version: G900KKTU1ANE8 INFO : 6/11/2016 10:45:47 AM > CSC version: G900KKTC1ANE8 INFO : 6/11/2016 10:45:47 AM > SW version: G900KKTU1AND8 INFO : 6/11/2016 10:45:48 AM > Phone IMEI: 000000000000000 INFO : 6/11/2016 10:45:48 AM > Phone SN: 00000000000 INFO : 6/11/2016 10:45:48 AM > Android version: 4.4.2 (KOT49H) INFO : 6/11/2016 10:45:48 AM > Country: KOREA INFO : 6/11/2016 10:45:48 AM > HW platform: msm8974 INFO : 6/11/2016 10:45:48 AM > HW Chip: MSM8974PRO INFO : 6/11/2016 10:45:48 AM > HW Modem: MSM8974PRO INFO : 6/11/2016 10:45:48 AM > Codename: kltektt INFO : 6/11/2016 10:45:48 AM > Checking Root: INFO : 6/11/2016 10:45:48 AM > Phone is Rooted. INFO : 6/11/2016 10:45:49 AM > Checking Certificate file... INFO : 6/11/2016 10:45:49 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:45:51 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:45:52 AM > Platform: Samsung Android INFO : 6/11/2016 10:45:52 AM > Selected port: COM14 INFO : 6/11/2016 10:45:52 AM > Selected model: SM-G900K INFO : 6/11/2016 10:46:01 AM > Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS\SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\SM-G900F_352558067456393_00000000000.cert INFO : 6/11/2016 10:46:02 AM > Detected phone model: SM-G900K INFO : 6/11/2016 10:46:02 AM > Firmware compiled date: Fri May 30 15:32:09 KST 2014 INFO : 6/11/2016 10:46:02 AM > PDA version: G900KKTU1ANE8 INFO : 6/11/2016 10:46:02 AM > CSC version: G900KKTC1ANE8 INFO : 6/11/2016 10:46:02 AM > SW version: G900KKTU1AND8 INFO : 6/11/2016 10:46:03 AM > Phone IMEI: 000000000000000 INFO : 6/11/2016 10:46:03 AM > Phone SN: 00000000000 INFO : 6/11/2016 10:46:03 AM > Android version: 4.4.2 (KOT49H) INFO : 6/11/2016 10:46:03 AM > Country: KOREA INFO : 6/11/2016 10:46:03 AM > HW platform: msm8974 INFO : 6/11/2016 10:46:03 AM > HW Chip: MSM8974PRO INFO : 6/11/2016 10:46:03 AM > HW Modem: MSM8974PRO INFO : 6/11/2016 10:46:03 AM > Codename: kltektt INFO : 6/11/2016 10:46:03 AM > Checking Root: INFO : 6/11/2016 10:46:04 AM > Phone is Rooted. INFO : 6/11/2016 10:46:04 AM > Checking Certificate file... INFO : 6/11/2016 10:46:04 AM > Certificate file successfully checked INFO : 6/11/2016 10:46:04 AM > Writing Certificate... INFO : 6/11/2016 10:46:04 AM > Writing new phone IMEI... ERROR : 6/11/2016 10:46:35 AM > Writing Certificate failed INFO : 6/11/2016 10:46:35 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:48:16 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:48:17 AM > Platform: Samsung Android INFO : 6/11/2016 10:48:17 AM > Selected port: COM14 INFO : 6/11/2016 10:48:17 AM > Selected model: SM-G900K ERROR : 6/11/2016 10:48:25 AM > File corrupted! ERROR : 6/11/2016 10:48:25 AM > Writing security failed. INFO : 6/11/2016 10:48:25 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:48:31 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:48:32 AM > Platform: Samsung Android INFO : 6/11/2016 10:48:32 AM > Selected port: COM14 INFO : 6/11/2016 10:48:32 AM > Selected model: SM-G900K WARN : 6/11/2016 10:48:32 AM > To put SM-G900K into Download Mode, You have to perform the following steps: WARN : 6/11/2016 10:48:32 AM > 1. Reconnect the battery. WARN : 6/11/2016 10:48:32 AM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 6/11/2016 10:48:32 AM > 3. When phone turns on, press "Volume+" key. INFO : 6/11/2016 10:48:35 AM > Searching for a phone. Please wait... INFO : 6/11/2016 10:49:01 AM > Phone found. INFO : 6/11/2016 10:49:01 AM > Repairing EFS... INFO : 6/11/2016 10:49:07 AM > EFS Repair successfully INFO : 6/11/2016 10:49:08 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:50:06 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:50:07 AM > Platform: Samsung Android INFO : 6/11/2016 10:50:07 AM > Selected port: COM14 INFO : 6/11/2016 10:50:07 AM > Selected model: SM-G900K INFO : 6/11/2016 10:50:09 AM > Detected phone model: SM-G900K INFO : 6/11/2016 10:50:09 AM > Firmware compiled date: Fri May 30 15:32:09 KST 2014 INFO : 6/11/2016 10:50:09 AM > PDA version: G900KKTU1ANE8 INFO : 6/11/2016 10:50:09 AM > CSC version: G900KKTC1ANE8 INFO : 6/11/2016 10:50:09 AM > SW version: G900KKTU1AND8 INFO : 6/11/2016 10:50:09 AM > Phone IMEI: 000000000000000 INFO : 6/11/2016 10:50:09 AM > Android version: 4.4.2 (KOT49H) INFO : 6/11/2016 10:50:09 AM > Country: KOREA INFO : 6/11/2016 10:50:09 AM > HW platform: msm8974 INFO : 6/11/2016 10:50:09 AM > HW Chip: MSM8974PRO INFO : 6/11/2016 10:50:09 AM > HW Modem: MSM8974PRO INFO : 6/11/2016 10:50:09 AM > Codename: kltektt INFO : 6/11/2016 10:50:09 AM > Reading info... INFO : 6/11/2016 10:50:09 AM > Mode: Normal INFO : 6/11/2016 10:50:09 AM > Firmware compiled date: Mar 06 2014 INFO : 6/11/2016 10:50:09 AM > Firmware compiled time: 15:00:00 INFO : 6/11/2016 10:50:09 AM > Firmware released date: Apr 22 2014 INFO : 6/11/2016 10:50:09 AM > Firmware released time: 18:19:42 INFO : 6/11/2016 10:50:09 AM > SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 INFO : 6/11/2016 10:50:09 AM > Checking Root: INFO : 6/11/2016 10:50:10 AM > Phone is Rooted. INFO : 6/11/2016 10:50:10 AM > Reading security backup, please wait... INFO : 6/11/2016 10:51:25 AM > Backup saved as E:\Backup Data\TORNADO\TOOL_BOXs\Octoplus\Octoplus_samsung_portable\BACKUP\Security-SM-G900K-000000000000000-11-06-2016_10-50-10-.asec file INFO : 6/11/2016 10:51:25 AM > Wiping EFS... INFO : 6/11/2016 10:52:16 AM > EFS wipe successfully WARN : 6/11/2016 10:52:17 AM > Phone will restart now. Please don't disconnect cable! INFO : 6/11/2016 10:52:17 AM > Searching for a phone. Please wait... INFO : 6/11/2016 10:52:47 AM > Reading info... INFO : 6/11/2016 10:52:47 AM > Mode: Normal INFO : 6/11/2016 10:52:47 AM > Firmware compiled date: Mar 06 2014 INFO : 6/11/2016 10:52:47 AM > Firmware compiled time: 15:00:00 INFO : 6/11/2016 10:52:47 AM > Firmware released date: Apr 22 2014 INFO : 6/11/2016 10:52:47 AM > Firmware released time: 18:19:42 INFO : 6/11/2016 10:52:47 AM > SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 INFO : 6/11/2016 10:52:47 AM > Wipe security successfully complete. WARN : 6/11/2016 10:52:47 AM > Phone will restart now. Please don't disconnect cable! INFO : 6/11/2016 10:52:51 AM > Performed by 2.2.7 software version INFO : 6/11/2016 10:57:33 AM > ----------------------------------------------------------------------------------- INFO : 6/11/2016 10:57:34 AM > Platform: Samsung Android INFO : 6/11/2016 10:57:34 AM > Selected port: COM14 INFO : 6/11/2016 10:57:34 AM > Selected model: SM-G900K INFO : 6/11/2016 10:58:14 AM > Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS\SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\cert-sm-g900f_353110060712502_r58f0sft2t.cert INFO : 6/11/2016 10:58:16 AM > Detected phone model: SM-G900K INFO : 6/11/2016 10:58:16 AM > Firmware compiled date: Fri May 30 15:32:09 KST 2014 INFO : 6/11/2016 10:58:16 AM > PDA version: G900KKTU1ANE8 INFO : 6/11/2016 10:58:16 AM > CSC version: G900KKTC1ANE8 INFO : 6/11/2016 10:58:16 AM > SW version: G900KKTU1AND8 INFO : 6/11/2016 10:58:17 AM > Phone IMEI: 000000000000000 INFO : 6/11/2016 10:58:17 AM > Android version: 4.4.2 (KOT49H) INFO : 6/11/2016 10:58:17 AM > Country: KOREA INFO : 6/11/2016 10:58:17 AM > HW platform: msm8974 INFO : 6/11/2016 10:58:17 AM > HW Chip: MSM8974PRO INFO : 6/11/2016 10:58:17 AM > HW Modem: MSM8974PRO INFO : 6/11/2016 10:58:17 AM > Codename: kltektt INFO : 6/11/2016 10:58:17 AM > Checking Root: INFO : 6/11/2016 10:58:18 AM > Phone is Rooted. INFO : 6/11/2016 10:58:18 AM > Checking Certificate file... INFO : 6/11/2016 10:58:18 AM > Certificate file successfully checked INFO : 6/11/2016 10:58:18 AM > Writing Certificate... INFO : 6/11/2016 10:58:18 AM > Writing new phone IMEI... ERROR : 6/11/2016 10:58:49 AM > Writing Certificate failed INFO : 6/11/2016 10:58:52 AM > Performed by 2.2.7 software version |
06-11-2016, 07:05 | #15 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | also check these please Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.7 ----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G900K phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS \SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\SM-G900F_ 35255806745642_0478.cert Detected phone model: SM-G900K Firmware compiled date: Fri May 30 15:32:09 KST 2014 PDA version: G900KKTU1ANE8 CSC version: G900KKTC1ANE8 SW version: G900KKTU1AND8 Phone IMEI: 000000000000000 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Checking Root: Phone is Rooted. Checking Certificate file... Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS \SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\SM-G900F_ 352558067456393_00000000000.cert Detected phone model: SM-G900K Firmware compiled date: Fri May 30 15:32:09 KST 2014 PDA version: G900KKTU1ANE8 CSC version: G900KKTC1ANE8 SW version: G900KKTU1AND8 Phone IMEI: 000000000000000 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K File corrupted! Writing security failed. Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K To put SM-G900K into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Repairing EFS... EFS Repair successfully Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Detected phone model: SM-G900K Firmware compiled date: Fri May 30 15:32:09 KST 2014 PDA version: G900KKTU1ANE8 CSC version: G900KKTC1ANE8 SW version: G900KKTU1AND8 Phone IMEI: 000000000000000 Android version: 4.4.2 (KOT49H) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Reading info... Mode: Normal Firmware compiled date: Mar 06 2014 Firmware compiled time: 15:00:00 Firmware released date: Apr 22 2014 Firmware released time: 18:19:42 SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as E:\Backup Data\TORNADO\TOOL_BOXs\Octoplus \Octoplus_samsung_portable\BACKUP\Security-SM-G900K- 000000000000000-11-06-2016_10-50-10-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Mar 06 2014 Firmware compiled time: 15:00:00 Firmware released date: Apr 22 2014 Firmware released time: 18:19:42 SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS \SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\cert-sm-g900f_ 353110060712502_r58f0sft2t.cert Detected phone model: SM-G900K Firmware compiled date: Fri May 30 15:32:09 KST 2014 PDA version: G900KKTU1ANE8 CSC version: G900KKTC1ANE8 SW version: G900KKTU1AND8 Phone IMEI: 000000000000000 Android version: 4.4.2 (KOT49H) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Reading info... Mode: Normal Firmware compiled date: Mar 06 2014 Firmware compiled time: 15:00:00 Firmware released date: Apr 22 2014 Firmware released time: 18:19:42 SW Version: MPSS.DI.2.0.1.c2-00027-M8974AAAAANRZM-1 Reseting MSL... MSL reset successfully. Please, restart the phone to apply changes Performed by 2.2.7 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM14 Selected model: SM-G900K Selected file: E:\Backup Data\TORNADO\PRODUCTS\GSM_PRODUCTS \SAMSAUNG\CERT & QCN & EFS\ONLY CERT FILES\cert-sm-g900f_ 353110060712502_r58f0sft2t.cert Detected phone model: SM-G900K Firmware compiled date: Fri May 30 15:32:09 KST 2014 PDA version: G900KKTU1ANE8 CSC version: G900KKTC1ANE8 SW version: G900KKTU1AND8 Phone IMEI: 000000000000000 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) Country: KOREA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltektt Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Writing new phone IMEI... Writing Certificate failed Performed by 2.2.7 software version |
