01-06-2017, 11:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Samsung sm-g900t 6.0.1 unlock success but ask code Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM38 Selected model: SM-G900T Mode: Normal Phone model: SM-G900T Firmware compiled date: Mar 17 2016 Firmware compiled time: 23:00:00 Firmware released date: Nov 17 2016 Firmware released time: 13:05:39 Phone IMEI: 353683-06-171961-9 SW version: MPSS.DI.2.0.1.c2-00195-M8974AAAAANRZM-1.48511.1 Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM38 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: Mar 17 2016 Firmware compiled time: 23:00:00 Firmware released date: Nov 17 2016 Firmware released time: 13:05:39 SW Version: MPSS.DI.2.0.1.c2-00195-M8974AAAAANRZM-1.48511.1 Detected phone model: SM-G900T Firmware compiled date: Thu Nov 17 14:02:17 KST 2016 PDA version: G900TUVS1GPK3 CSC version: G900TTMB1GPK3 SW version: G900TUVS1GPK3 Phone SN: R38F80ADXEF Android version: 6.0.1 (MMB29M) Sales code: TMB Country: USA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Security patch level: 2016-11-01 Codename: kltetmo Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-G900T-06-01-2017_15-58-27 file Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.4.7 Software version. PLS HELP |
01-06-2017, 11:32 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. As You can see from Software log, your phone has one of the latest firmwares: Quote:
Note: downgrading of phone firmware can damage your device. You can try to do this only on your own risk. | |
01-06-2017, 18:14 | #4 (permalink) | |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
Then upgrade again if you want. Downgrade is safety | |
01-06-2017, 19:36 | #6 (permalink) | |
https://www.androidfilehost.com/?fid=24391638059059508 | |
The Following User Says Thank You to Alexandroid For This Useful Post: |
01-06-2017, 21:16 | #8 (permalink) |
Freak Poster Join Date: Apr 2016
Member: 2554552 Status: Offline Thanks Meter: 21 | https://drive.google.com/file/d/0Bz0...ew?usp=sharing HERE IS THE PK3 MODEM.TAR FLASH WITH ODIN IN AP. |
The Following 2 Users Say Thank You to skyletusa For This Useful Post: |
01-07-2017, 14:09 | #9 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
----------------------------------------------------------------------------------- To connect SGH-I727 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090# or *#0808#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-I727 Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM13 Phone connection failed Selected action can’t be performed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM13 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM13 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- To connect SM-G900H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G900H Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. Can't kill external ADB references. Please, close all programs that use ADB server. Detected phone model: SM-G900T Firmware compiled date: Thu Nov 17 14:02:17 KST 2016 PDA version: G900TUVS1GPK3 CSC version: G900TTMB1GPK3 SW version: G900TUVS1GPK3 Phone SN: R38F80ADXEF Android version: 6.0.1 (MMB29M) Sales code: TMB Country: USA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Codename: kltetmo Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G900H Can't kill external ADB references. Please, close all programs that use ADB server. Warning: Selected model (SM-G900H) differs from the detected one (SM-G900T)! If you want select (SM-G900T) as (SM-G900H) model, please check "manual select". Phone unlocking failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- To connect SM-G900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: Mar 17 2016 Firmware compiled time: 23:00:00 Firmware released date: Nov 17 2016 Firmware released time: 13:05:39 SW Version: MPSS.DI.2.0.1.c2-00195-M8974AAAAANRZM-1.48511.1 Detected phone model: SM-G900T Firmware compiled date: Thu Nov 17 14:02:17 KST 2016 PDA version: G900TUVS1GPK3 CSC version: G900TTMB1GPK3 SW version: G900TUVS1GPK3 Phone SN: R38F80ADXEF Android version: 6.0.1 (MMB29M) Sales code: TMB Country: USA HW platform: msm8974 HW Chip: MSM8974PRO HW Modem: MSM8974PRO Security patch level: 2016-11-01 Codename: kltetmo Checking Root: Phone is not Rooted. Unlocking phone... Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM13 Selected model: SM-G900T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM38 Mode: Normal Phone model: SM-G900T Firmware compiled date: Mar 17 2016 Firmware compiled time: 23:00:00 Firmware released date: Nov 17 2016 Firmware released time: 13:05:39 Phone IMEI: 353683-06-171961-9 SW version: MPSS.DI.2.0.1.c2-00195-M8974AAAAANRZM-1.48511.1 Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM38 Selected model: SM-G900T Reading info... Mode: Normal Firmware compiled date: Mar 17 2016 Firmware compiled time: 23:00:00 Firmware released date: Nov 17 2016 Firmware released time: 13:05:39 SW Version: MPSS.DI.2.0.1.c2-00195-M8974AAAAANRZM-1.48511.1 Unlocking phone... Fast Unlock method is not supported for current security settings in your phone! Try to downgrade firmware! Phone unlocking failed Performed by 2.4.7 Software version. after write modem same problem | |
01-07-2017, 16:37 | #10 (permalink) | |
Member: 2554552 Status: Offline Thanks Meter: 21 | Quote:
then reflash pk3 modem for the phone to get the baseband back in normal Sent from my SM-N920T using Tapatalk | |
01-07-2017, 17:03 | #11 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Ethiopia || united State
Member: 1770631 Status: Offline Sonork: id Thanks Meter: 89 | bro just ..here solution search & find 5.1.1 modem md5 file and delete the .md5 extension and extract the tar file wz 7zip extract modem only and flash it with odin in cp tab direct unlock it wii be successful am not in office i can't share the file .. |
01-07-2017, 18:19 | #12 (permalink) | |
https://www.androidfilehost.com/?fid=24545065934258544 Make hard reset Fast unlock and upgrade again only if you want 6.0.1 If you dont want to downgrade the hole firmware just downgrade modem to OL1 the flash original modem again OL1 5.1.1 Modem https://www.androidfilehost.com/?fid=24391638059059508 | |
The Following 5 Users Say Thank You to Alexandroid For This Useful Post: |
05-16-2017, 13:28 | #13 (permalink) | |
Insane Poster Join Date: Jul 2006 Location: Thailand Age: 45
Member: 309375 Status: Offline Thanks Meter: 15 | Quote:
it work for me thank you | |
The Following User Says Thank You to khunv For This Useful Post: |
10-27-2017, 22:00 | #14 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | Quote:
