05-13-2018, 12:08 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: karachi
Member: 1686673 Status: Offline Thanks Meter: 53 | Samsung SM-G920T after Write Cett file IIMEI problem [Solved] I have Samsung S6 G920T After Write New Imei show only searching i read Ahmed zitoon reply untitled.JPG Code: step i forget it , after Repair Security write cert cert-sm-g920t_359362060124295_r58g31hj5qm.cert from octopus support finally press unlock , br, ahmedzitoon 20180513_155708.jpg Last edited by Octopus box; 05-13-2018 at 15:26. |
05-13-2018, 12:46 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
In case you have not tried to write other cert to see if the code is correct and not unknown Post the results of the software logs to see the operation you did Last edited by amleto90; 05-13-2018 at 12:52. | |
05-13-2018, 14:17 | #3 (permalink) | |
Member: 1686673 Status: Offline Thanks Meter: 53 | Quote:
Searching problem Solve Show network but Call not ok outgoing in not work How to Solve this problem | |
05-13-2018, 14:32 | #4 (permalink) | |
Have you tried to write another cert with IMEI, it could be that you have written a cert with the IMEI code in the blacklist and for that the network does not work If you wrote that certificate you posted see that the Imei is IMEI: 359362060124295 Brand: Samsung Phone model: Galaxy S6 G920T Blacklist status*: BLACKLISTED | |
05-13-2018, 14:42 | #5 (permalink) | |
my sim card put other samsung set is outgoing call is working Fine | |
05-13-2018, 14:46 | #6 (permalink) | |
Only with your SIM does not work the call from what you wrote, with other Sims works from what you wrote the call works | |
05-13-2018, 15:22 | #7 (permalink) | |
Change imei repair Network Show Network Name Network Signal is ok *#0011# Dial imei Status Show ok But call serves is not ok Dial number but call not going | |
