06-26-2017, 19:16 | #1 (permalink) |
Major Poster Join Date: Apr 2016
Member: 2565568 Status: Offline Thanks Meter: 8 | Samsung SM-G935U 6.0 qc1 - how to reset FRP? Enviado desde mi iPhone utilizando Tapatalk Last edited by Octopus box; 06-27-2017 at 07:58. |
06-27-2017, 07:56 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. Please post here full Software log of performed operations. Also read these rules: http://forum.gsmhosting.com/vbb/f62/...rules-1591101/, http://forum.gsmhosting.com/vbb/f684...leted-2165824/. |
06-27-2017, 15:26 | #4 (permalink) |
Member: 2565568 Status: Offline Thanks Meter: 8 | baseband: G935UUES4AQC1 operation: Reset FRP/Reactivation Lock the support combation for this model not let me flash on this baseband INFO : 26/06/2017 10:29:25 a.m. > Platform: Samsung Android INFO : 26/06/2017 10:29:25 a.m. > Selected port: COM3 INFO : 26/06/2017 10:29:25 a.m. > Selected model: SM-G935U WARN : 26/06/2017 10:29:25 a.m. > Connecting to server... INFO : 26/06/2017 10:29:28 a.m. > Connecting to server...Ok! INFO : 26/06/2017 10:29:28 a.m. > Checking resource files... INFO : 26/06/2017 10:29:30 a.m. > Resource files already downloaded. WARN : 26/06/2017 10:29:30 a.m. > Please put the phone into Download Mode and connect USB cable. WARN : 26/06/2017 10:29:30 a.m. > To put SM-G935U into Download Mode, You have to perform the following steps: WARN : 26/06/2017 10:29:30 a.m. > 1. Reconnect the battery. WARN : 26/06/2017 10:29:30 a.m. > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 26/06/2017 10:29:30 a.m. > 3. When phone turns on, press "Volume+" key. INFO : 26/06/2017 10:29:30 a.m. > Waiting for phone... INFO : 26/06/2017 10:29:30 a.m. > Firmware write started. INFO : 26/06/2017 10:29:30 a.m. > Writing Boot section... INFO : 26/06/2017 10:29:34 a.m. > Boot section has been written successfully. INFO : 26/06/2017 10:29:34 a.m. > Searching for a phone. Please wait... INFO : 26/06/2017 10:30:03 a.m. > Performed by 2.5.5 Software version. and still in bootloop restar |
06-27-2017, 16:15 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | If phone stuck in boot loop after writing of a boot section - boot.img that is being used is not compatible with current firmware of the phone. You can try to write older by release date firmware, then repeat "Reset FRP/Reactivation/EE" operation. Also You can manually write boot.img of compatible combination firmware (http://forum.gsmhosting.com/vbb/f684...rrors-2189001/), then make "Reset FRP". |
06-27-2017, 17:21 | #6 (permalink) |
Member: 2565568 Status: Offline Thanks Meter: 8 | For this reason was my first box (((amazing octoplus))) 1.easy and automatic 2.support good and fast i flash baseband G935UUEU4APL4 = P=2016 L= decembre revision 4 Plataforma: Samsung Android Puerto seleccionado: COM3 Modelo seleccionado: SM-G935U Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G935U into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Escribiendo la sección Boot... L a sección Boot ha sido escrita con éxito Searching for a phone. Please wait... Phone found. Resetting FRP lock.. Reset operation completed! Performed by 2.5.5 Software version. |
The Following User Says Thank You to snydertecnology For This Useful Post: |
06-27-2017, 17:48 | #7 (permalink) |
No Life Poster Join Date: Nov 2008
Member: 904826 Status: Offline Sonork: 100.1603284 GeorgeEcuador Thanks Meter: 580 | Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: SM-G935U Connecting to server... Could not connect to the server! Checking resource files... Resource files were not found. Please, connect to Internet or try to download files manually! Performed by 2.5.5 Software version. |
06-28-2017, 07:46 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Quote:
Also You can manually download resource files from "Samsung/Resources" folder of the Support Area. | |
