Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-10-2018, 18:02   #1 (permalink)
Member: 477842
Thanks Meter: 80
Smile Samsung SM-G950F Reset FRP lock [Solved]
Hi Brothers
I have Samsung G950F with firmware G950FXXU1AQK7
It`s possible to reset FRP with writed firmware COMBINATION_FA70_G950FXXU1AQJ2_CL12326046_QB154162 12_REV00.OCT
via octoplus ?
Old 08-10-2018, 18:37   #2 (permalink)
Member: 477842
Thanks Meter: 80
When I write combination file (only boot.img) I have
Initializing...
Initializing smartcard...
Serial: 00xxxx
Connecting to server...
Downloading "COMBINATION_FA70_G950FXXU1AQJ2_CL12326046_QB15416 212_REV00_user_mid_noship.oct"...
File "COMBINATION_FA70_G950FXXU1AQJ2_CL12326046_QB15416 212_REV00_user_mid_noship.oct" successfull downloaded
Selected firmware file: COMBINATION_FA70_G950FXXU1AQJ2_CL12326046_QB154162 12_REV00_user_mid_noship.oct
Platform: SAMSUNG
Selected model: SM-G950F
Please put the phone into Download Mode and connect USB cable.
To put SM-G950F into Download Mode, You have to perform the following steps:
1. Power off the phone.
2. Press and hold "Volume-" + "Bixby" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Found phone on
Advanced mode!
Firmware write started.
Writing BOOT section...
BOOT section has been written successfully.
Firmware writing successfully completed.
Performed by 1.3.7.1 Software version.
now, only hang on logo...
Old 08-10-2018, 18:47   #3 (permalink)
Member: 2642393
Thanks Meter: 34
you must flash the whole Combination flash file. The flash stock firmaware except Cp. "Choose Home-CSC".
Old 08-10-2018, 18:47   #4 (permalink)
Member: 2642393
Thanks Meter: 34
look at this video:
https://www.youtube.com/watch?v=AToUCOJuJmM
Old 08-11-2018, 08:12   #5 (permalink)
Member: 477842
Thanks Meter: 80
Originally Posted by 4com View Post
still locked google account
Old 08-11-2018, 08:15   #6 (permalink)
MOBICLASIC's Avatar
Member: 136800
Thanks Meter: 26
You need to flash combination, after that flash from normal firmware only system+sboot+boot+recovery+cache.
The phone need 15 min to boot up then only click next-next-next or swipe from up the notification bar and go to setting then to enable OEM and make hard reset.
If your phone still boot hang on logo just re-flash sboot + boot from normal firmware.
The Following User Says Thank You to MOBICLASIC For This Useful Post:
Old 08-12-2018, 10:02   #7 (permalink)
Member: 477842
Thanks Meter: 80
where I get the "Enable ADB from settings" and " Enable OEM" from settings ?
Old 08-12-2018, 10:18   #8 (permalink)
Member: 169896
Thanks Meter: 323
Easiest method
1. Install full combination
2. Factory reset from combination
3. It will turn off FRP
4. Install complete Stock firmware
5. If OEM lock is off then it done. If ON then go to settings enable usb debug and enable oem unlocking. Reboot then phone and it will be Off
Done.
Sent from my SM-G960W using Tapatalk
Old 08-12-2018, 10:42   #9 (permalink)
Member: 481774
Thanks Meter: 174
check this solution
http://forum.gsmhosting.com/vbb/f103...-done-2447608/
The Following User Says Thank You to zineelhada For This Useful Post:
Old 08-12-2018, 20:48   #10 (permalink)
Member: 477842
Thanks Meter: 80
Originally Posted by ashahzad_pk View Post
Easiest method
Done.
I do 1-4. but when flash complete stock firmware, and second time do the factory reset , then I have still google account ;/
Old 08-12-2018, 21:50   #11 (permalink)
Member: 477842
Thanks Meter: 80
I Write full combination flash file from octopus, reset phone from android settings , then full flash without user data, when phone power on i tick Reset All User data from samsung android settings, and now phone work with reset frp . thanks guys for your honesty
The Following User Says Thank You to at-kom For This Useful Post:
Page generated in 0.16930 seconds with 8 queries
