01-15-2016, 08:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Shibgonj6340
Member: 844312 Status: Offline Sonork: 100.1640471 Thanks Meter: 257 | Samsung SM-J200GU SIM Network unlock PIN 100% DOne Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200GU Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-J200GU Firmware compiled date: Fri Nov 6 12:48:30 KST 2015 PDA version: J200GUDXU1AOK1 CSC version: J200GUOLB1AOK1 SW version: J200GUDXU1AOK1 Phone SN: R28GC0SJ8ME Android version: 5.1.1 (LMY47X) Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200GU Reading info, please wait... ADB server killed. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-J200GU Firmware compiled date: Fri Nov 6 12:48:30 KST 2015 PDA version: J200GUDXU1AOK1 CSC version: J200GUOLB1AOK1 SW version: J200GUDXU1AOK1 Phone SN: R28GC0SJ8ME Android version: 5.1.1 (LMY47X) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200GU Detected phone model: SM-J200GU Firmware compiled date: Fri Nov 6 12:48:30 KST 2015 PDA version: J200GUDXU1AOK1 CSC version: J200GUOLB1AOK1 SW version: J200GUDXU1AOK1 Phone SN: R28GC0SJ8ME Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-J200GU-Unknown15-01-2016_13-39-23-.asec file Deactivating MSL... Please remove SIM card if it is inserted and try again! Read codes failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200GU Searching for a phone. Please wait... ADB server killed. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM271 Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Connecting to phone on COM9 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200GU Detected phone model: SM-J200GU Firmware compiled date: Fri Nov 6 12:48:30 KST 2015 PDA version: J200GUDXU1AOK1 CSC version: J200GUOLB1AOK1 SW version: J200GUDXU1AOK1 Phone SN: R28GC0SJ8ME Android version: 5.1.1 (LMY47X) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-J200GU-Unknown15-01-2016_13-45-35-.asec file Deactivating MSL... Exploit has been executed successfully MSL deactivate successfully Reading phone unlock codes. It can take some time, please wait... FREEZE unlock code: 92515861 NET LOCK unlock code: 17536479 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 http://forum.gsmhosting.com/vbb/newt...ewthread&f=684 Work time: 0:02:15 |
The Following User Says Thank You to sohidul For This Useful Post: |
