06-06-2018, 14:21 | #1 (permalink) |
Junior Member Join Date: Aug 2012 Location: Sydney
Member: 1798230 Status: Offline Thanks Meter: 4 | Samsung SM-J250G read code 01234567 [Solved] See there's a similar case in forum http://forum.gsmhosting.com/vbb/f684...olved-2383531/ and seems successfully got code on repeat reading. So tried to read again, but it ask another 50 credits for read again and not sure it would work? could you please help to solve it? Last edited by Octopus box; 06-06-2018 at 15:22. |
06-06-2018, 14:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. What code (type of code) does your device request exactly? Please post here photo, we will check. We have refunded 5 credits to your account. You can try to re-flash the phone with another firmware, then repeat Read Codes operation again, then post here full Software log. |
06-06-2018, 14:50 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | At first You can try to re-boot the device and try to perform "Read Codes" again with the same (v.2.6.9) Software version. Post here the result. |
06-06-2018, 15:03 | #4 (permalink) |
Member: 1798230 Status: Offline Thanks Meter: 4 | SUCCESS this time ! thanks for help But somewhat worry for future unlock. Hope reason can be located and fixed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM282 Selected model: SM-J250G Operation: Read Codes "Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform “Read Codes” operation!" Continue? Searching for a phone. Please wait... Detected phone model: SM-J250G Firmware compiled date: Thu Jan 25 16:54:05 KST 2018 PDA version: J250GDXU1ARA4 CSC version: J250GVAP1ARC1 SW version: J250GDXU1AQL4 Phone SN: R28K526T6AT Android version: 7.1.1 (NMF26X) Sales code: VAP Country: Australia HW platform: msm8937 HW Chip: MSM8937 HW Modem: MSM8917 Security patch level: 2018-01-01 SIM 1 status: network locked Codename: j2y18ltextc ----------------------------------------------------------------------------------- Connecting to server .. Username: liuzhengleo Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 50 credits. ----------------------------------------------------------------------------------- Rebooting phone in Upload Mode... Searching for a phone. Please wait...OK Reading data...OK Searching for signatures...OK Sending request...OK Calculating codes. Please wait... FREEZE: 82727172 NET LOCK: 79309706 SUB LOCK: 00000000 SP LOCK: 00000000 CP LOCK: 00000000 Performed by 2.6.9 Software version. |
06-06-2018, 15:21 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Then problem in phone, not in Software version. Not all firmwares upload codes, if some cases it is necessary to re-flash the device with another firmware, in some cases it is enough to re-boot the device. It is recommended to always re-boot the device before to perform "Read Codes" operation. |
12-05-2018, 02:09 | #6 (permalink) |
Insane Poster Join Date: Mar 2015 Location: Solomon Islands, Honiara
Member: 2361039 Status: Offline Thanks Meter: 15 | I'm facing similar issue with this Firmware version type. Unlock Code for Network not successful. Can i also have my credit back to try reset and read code again with this Phone i got Welcome to Octoplus Box Samsung software version 2.7.5 -------------------------------------------------------------------- --------------- To connect SM-G930S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. -------------------------------------------------------------------- --------------- Connecting to server... Username: solzak01 Authorizing... Checking balance... Your balance: 185 credits. Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J250G Operation: Read Codes "Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform “Read Codes” operation!" Continue? Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J250G Firmware compiled date: Mon Jun 25 21:12:22 KST 2018 PDA version: J250GDXU2ARF2 CSC version: J250GTLP2ARG1 SW version: J250GDXU2ARF2 Phone SN: R28K818W5WW Android version: 7.1.1 (NMF26X) Sales code: TLP Country: Australia HW platform: msm8937 HW Chip: MSM8937 HW Modem: MSM8917 Security patch level: 2018-06-01 Warranty Void: 0 SIM 1 status: network locked Codename: j2y18ltextc -------------------------------------------------------------------- --------------- Connecting to server .. Username: solzak01 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 185 credits. -------------------------------------------------------------------- --------------- Rebooting phone Searching for a phone. Please wait...OK Rebooting phone Searching for a phone. Please wait...OK Rebooting phone in Upload Mode... Searching for a phone. Please wait...OK Reading data...OK Detecting security type...(1) Searching for signatures...OK Sending request...OK Calculating codes. Please wait... FREEZE: not found NET LOCK: not found SUB LOCK: not found SP LOCK: not found CP LOCK: not found Codes were not found. Please do Factory data reset and repeat "Read Codes" operation. Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Connecting to server... Could not connect to the server! Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Connecting to server... Username: solzak01 Authorizing... Checking balance... Your balance: 185 credits. Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J250G Operation: Read Codes "Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform “Read Codes” operation!" Continue? Searching for a phone. Please wait... Detected phone model: SM-J250G Firmware compiled date: Mon Jun 25 21:12:22 KST 2018 PDA version: J250GDXU2ARF2 CSC version: J250GTLP2ARG1 SW version: J250GDXU2ARF2 Phone SN: R28K818W5WW Android version: 7.1.1 (NMF26X) Sales code: TLP Country: Australia HW platform: msm8937 HW Chip: MSM8937 HW Modem: MSM8917 Security patch level: 2018-06-01 Warranty Void: 0 SIM 1 status: network locked Codename: j2y18ltextc -------------------------------------------------------------------- --------------- Connecting to server .. Username: solzak01 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 185 credits. -------------------------------------------------------------------- --------------- Rebooting phone in Upload Mode... Searching for a phone. Please wait...OK Reading data...OK Detecting security type...(1) Searching for signatures...OK Sending request...OK Calculating codes. Please wait... FREEZE: 07485747 NET LOCK: 96180819 SUB LOCK: 85136974 SP LOCK: 00000000 CP LOCK: 00000000 Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Connecting to server... Could not connect to the server! Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Connecting to server... Could not connect to the server! Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Connecting to server... Username: solzak01 Authorizing... Checking balance... Your balance: 135 credits. Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J250G Operation: Read Codes "Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform “Read Codes” operation!" Continue? Searching for a phone. Please wait... Proper android device not found. Make sure that "USB debug" option on the device is turned on. Read codes failed Performed by 2.7.5 Software version. -------------------------------------------------------------------- --------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J250G Operation: Read Codes "Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform “Read Codes” operation!" Continue? Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J250G Firmware compiled date: Mon Jun 25 21:12:22 KST 2018 PDA version: J250GDXU2ARF2 CSC version: J250GVFJ2ARF2 SW version: J250GDXU2ARF2 Phone SN: R28K53E4MFZ Android version: 7.1.1 (NMF26X) Sales code: VFJ Country: Fiji HW platform: msm8937 HW Chip: MSM8937 HW Modem: MSM8917 Security patch level: 2018-06-01 Warranty Void: 0 SIM 1 status: network locked Codename: j2y18ltextc -------------------------------------------------------------------- --------------- Connecting to server .. Username: solzak01 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 135 credits. -------------------------------------------------------------------- --------------- Rebooting phone Searching for a phone. Please wait...OK Rebooting phone Searching for a phone. Please wait...OK Rebooting phone in Upload Mode... Searching for a phone. Please wait...OK Reading data...OK Detecting security type...(1) Searching for signatures...OK Sending request...OK Calculating codes. Please wait... FREEZE: 48529720 NET LOCK: 73038638 SUB LOCK: 00000000 SP LOCK: 00000000 CP LOCK: 00000000 Performed by 2.7.5 Software version. |
12-05-2018, 06:02 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Codes, which Software have read out form the device is correct. Then problem is with your phone's firmware, it doesn't allow to enter code. Please re-flash the phone with the firmware J250GDXS3ARG1 from the Support Area and enter code again. |
12-14-2018, 01:37 | #9 (permalink) |
Member: 2361039 Status: Offline Thanks Meter: 15 | Hi I have yet another SM-J250G and did flash with J250GDXS3ARG1 but now no code cant be listed. I tried Factory reset but still no code shown. Can anyone help with this issue Welcome to Octoplus Box Samsung software version 2.7.5 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J250G Operation: Read Codes "Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform “Read Codes” operation!" Continue? Searching for a phone. Please wait... Detected phone model: SM-J250G Firmware compiled date: Mon Jul 2 10:30:45 KST 2018 PDA version: J250GDXS3ARG1 CSC version: J250GOLC3ARG1 SW version: J250GDXS3ARG3 Phone SN: R28K82RNEJN Android version: 7.1.1 (NMF26X) Sales code: XTC Country: PHILIPPINES HW platform: msm8937 HW Chip: MSM8937 HW Modem: MSM8917 Security patch level: 2018-07-01 Warranty Void: 0 SIM 1 status: absent Codename: j2y18ltextc ----------------------------------------------------------------------------------- Connecting to server .. Username: solzak01 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 85 credits. ----------------------------------------------------------------------------------- Rebooting phone in Upload Mode... Searching for a phone. Please wait...OK Reading data...OK Detecting security type...(1) Searching for signatures... error 0x0003 Reboot phone and try once again! Read codes failed Performed by 2.7.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J250G Operation: Read Codes "Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform “Read Codes” operation!" Continue? Searching for a phone. Please wait... Please, press "OK" button on the phone to allow USB debugging. Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J250G Firmware compiled date: Mon Jul 2 10:30:45 KST 2018 PDA version: J250GDXS3ARG1 CSC version: J250GOLC3ARG1 SW version: J250GDXS3ARG3 Phone SN: R28K82RNEJN Android version: 7.1.1 (NMF26X) Sales code: XTC Country: PHILIPPINES HW platform: msm8937 HW Chip: MSM8937 HW Modem: MSM8917 Security patch level: 2018-07-01 Warranty Void: 0 SIM 1 status: absent Codename: j2y18ltextc ----------------------------------------------------------------------------------- Connecting to server .. Username: solzak01 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 85 credits. ----------------------------------------------------------------------------------- Rebooting phone Searching for a phone. Please wait...OK Rebooting phone Searching for a phone. Please wait...OK Rebooting phone in Upload Mode... Searching for a phone. Please wait...OK Reading data...OK Detecting security type...(1) Searching for signatures...OK Sending request...OK Calculating codes. Please wait... FREEZE: not found NET LOCK: not found SUB LOCK: not found SP LOCK: not found CP LOCK: not found Codes were not found. Please do Factory data reset and repeat "Read Codes" operation. Performed by 2.7.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J250G Operation: Read Codes "Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform “Read Codes” operation!" Continue? Searching for a phone. Please wait... Detected phone model: SM-J250G Firmware compiled date: Mon Jul 2 10:30:45 KST 2018 PDA version: J250GDXS3ARG1 CSC version: J250GOLC3ARG1 SW version: J250GDXS3ARG3 Phone SN: R28K82RNEJN Android version: 7.1.1 (NMF26X) Sales code: XTC Country: PHILIPPINES HW platform: msm8937 HW Chip: MSM8937 HW Modem: MSM8917 Security patch level: 2018-07-01 Warranty Void: 0 SIM 1 status: absent Codename: j2y18ltextc ----------------------------------------------------------------------------------- Connecting to server .. Username: solzak01 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 85 credits. ----------------------------------------------------------------------------------- Rebooting phone in Upload Mode... Searching for a phone. Please wait...OK Reading data...OK Detecting security type...(1) Searching for signatures...OK Sending request...OK Calculating codes. Please wait... FREEZE: not found NET LOCK: not found SUB LOCK: not found SP LOCK: not found CP LOCK: not found Codes were not found. Please do Factory data reset and repeat "Read Codes" operation. Performed by 2.7.5 Software version. |
12-14-2018, 05:56 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hi. Try to re-flash the phone with another firmware and repeat "Read Codes" operation again. Post here the result. |
12-17-2018, 05:45 | #11 (permalink) |
Member: 2361039 Status: Offline Thanks Meter: 15 | Thanks. Unlocked done Hi After changing the firmware i got correct codes reading with Octopus. Another issue was the code was not accepted with other firmware's i tried flashing to get it accepted . However by flashing Combination File and entering the unlock codes solved the issue of entering the Network Lock code. After doing Combination file to enter code successfully and again flashing with original firmware my issue was solved. Hope this might help some similar to my case. |
The Following User Says Thank You to Solo p For This Useful Post: |
