12-11-2017, 13:07 | #1 (permalink) |
Insane Poster Join Date: May 2013 Location: Earth
Member: 1948180 Status: Offline Thanks Meter: 36 | Samsung SM-J510FN - Reset FRP done To connect SM-J510FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. Platform: Samsung Android Selected port: COM3 Selected model: SM-J510FN Reset FRP/ Reactivation lock operation for SM-J510FN will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J510FN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.3 Software version. Last edited by Octopus box; 12-11-2017 at 13:13. |
The Following User Says Thank You to exploit69 For This Useful Post: |
