02-11-2018, 18:37 | #1 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1073769 Status: Offline Thanks Meter: 34 | Samsung SM-J730GM network not registered [Solved] Last edited by Octopus box; 02-15-2018 at 16:14. |
02-11-2018, 19:09 | #2 (permalink) |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Type *#0011# then select sim1 See there imei or cert pass or failed Sent from my Redmi 4X using Tapatalk |
The Following User Says Thank You to farukpdm For This Useful Post: |
02-13-2018, 14:25 | #6 (permalink) |
Member: 1073769 Status: Offline Thanks Meter: 34 | agen flash 2file but problem not solve 1st flash 2018-01-14 India 7.0 J730GMDXU2AQL1 2nd flash 2018-01-08 Singapore 7.0 J730GMDXU2AQK1 repair netwark done but problem not solve need hlp teem |
02-14-2018, 21:16 | #9 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | try that and prove that if i have reason Quote:
1.flash phone with stock rom https://mega.nz/#!uskyjRLS!NCRi6HXB0...9e1s3UMJTmnP7I 2. after patch imei 3.all info its here https://forum.xda-developers.com/gal...j730f-t3730638 4.after u will pay me for fix | |
The Following User Says Thank You to ghacks For This Useful Post: |
02-15-2018, 14:20 | #11 (permalink) |
Freak Poster Join Date: Dec 2014
Member: 2310475 Status: Offline Thanks Meter: 64 | new security (14-1-2018) downgrade and network repair done AGAIN WORLD FIRST IS HERE Welcome to Octoplus Box Samsung software version 2.6.4 ----------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected BOOT file: F:\samsung flash file\j730gm\BL_J730GMDXU1AQF9_CL11551611_QB1394319 8_REV00_user_low_ship.tar.md5 Selected AP file: F:\samsung flash file\j730gm\AP_J730GMDXU1AQF9_CL11551611_QB1394319 8_REV00_user_low_ship_meta.tar.md5 Selected CP file: F:\samsung flash file\j730gm\CP_J730GMDXU1AQF6_CL556392_QB6807986_S IGNED.tar.md5 Selected CSC file: F:\samsung flash file\j730gm\CSC_ODD_J730GMODD1AQF7_CL11551611_QB14 064463_REV00_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J730GM into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing SYSTEM section... Writing Firmware Failed Performed by 2.6.4 Software version. Selected BOOT file: C:\Users\ideal institute\Downloads\Compressed\u2\BL_J730GMUBU2AQI 3_CL12312267_QB15045772_REV00_user_low_ship.tar.md 5 Selected AP file: C:\Users\ideal institute\Downloads\Compressed\u2\AP_J730GMUBU2AQI 3_CL12312267_QB15045772_REV00_user_low_ship_meta.t ar.md5 Selected CP file: C:\Users\ideal institute\Downloads\Compressed\u2\CP_J730GMUBU2AQI 3_CP7557069_CL12312267_QB15045772_REV00_user_low_s hip.tar.md5 Selected CSC file: C:\Users\ideal institute\Downloads\Compressed\u2\CSC_PNT_J730GMPN T2AQI2_CL12285027_QB14985405_REV00_user_low_ship.t ar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J730GM into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.6.4 Software version. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-J730FM Please, press "OK" button on the phone to allow USB debugging. Warning: Selected model (SM-J730FM) differs from the detected one (SM-J730GM)! If you want select (SM-J730GM) as (SM-J730FM) model, please check "manual select". Write IMEI failed Performed by 2.6.4 Software version. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-J730FM Warning: Selected model (SM-J730FM) differs from the detected one (SM-J730GM)! If you want select (SM-J730GM) as (SM-J730FM) model, please check "manual select". Write IMEI failed Performed by 2.6.4 Software version. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-J730FM Detected phone model: SM-J730GM Firmware compiled date: Wed Sep 20 06:04:39 KST 2017 PDA version: J730GMUBU2AQI3 CSC version: J730GMPNT2AQI2 SW version: J730GMUBU2AQI3 Phone SN: RZ8J91F2SBJ Android version: 7.0 (NRD90M) Sales code: PNT Country: PERU HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j7y17lteubm Checking Root: Write IMEI failed Performed by 2.6.4 Software version. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-J730FM Please, press "OK" button on the phone to allow USB debugging. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 2.6.4 Software version. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-J730FM Detected phone model: SM-J730GM Firmware compiled date: Wed Sep 20 06:04:39 KST 2017 PDA version: J730GMUBU2AQI3 CSC version: J730GMPNT2AQI2 SW version: J730GMUBU2AQI3 Phone SN: RZ8J91F2SBJ Android version: 7.0 (NRD90M) Sales code: PNT Country: PERU HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j7y17lteubm Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-J730FM-RZ8J91F2SBJ-15-02-2018_17-10-49-.asec file Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Exploit has been executed successfully New IMEI: xxxxxxxxxxxxxxx Writing new phone IMEI... Please make "Repair Network" operation after reboot! IMEI successfully repaired. Performed by 2.6.4 Software version. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-J730FM Detected phone model: SM-J730GM Firmware compiled date: Wed Sep 20 06:04:39 KST 2017 PDA version: J730GMUBU2AQI3 CSC version: J730GMPNT2AQI2 SW version: J730GMUBU2AQI3 Phone SN: RZ8J91F2SBJ Android version: 7.0 (NRD90M) Sales code: PNT Country: PERU HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j7y17lteubm Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-J730FM-RZ8J91F2SBJ-15-02-2018_17-15-31-.asec file Initializing exploit... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Executing exploit... Exploit has been executed successfully New IMEI: xxxxxxxxxxxxxxxxx Writing new phone IMEI... Please make "Repair Network" operation after reboot! IMEI successfully repaired. Performed by 2.6.4 Software version. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-J730FM Detected phone model: SM-J730GM Firmware compiled date: Wed Sep 20 06:04:39 KST 2017 PDA version: J730GMUBU2AQI3 CSC version: J730GMPNT2AQI2 SW version: J730GMUBU2AQI3 Phone SN: RZ8J91F2SBJ Android version: 7.0 (NRD90M) Sales code: PNT Country: PERU HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j7y17lteubm Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Uploading service app.. Repairing network failed. Performed by 2.6.4 Software version. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM30 Selected model: SM-J730FM Detected phone model: SM-J730GM Firmware compiled date: Wed Sep 20 06:04:39 KST 2017 PDA version: J730GMUBU2AQI3 CSC version: J730GMPNT2AQI2 SW version: J730GMUBU2AQI3 Phone SN: RZ8J91F2SBJ Android version: 7.0 (NRD90M) Sales code: PNT Country: PERU HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j7y17lteubm Checking Root: Phone is Rooted. Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Phone found. Uploading service app..OK Installing service app...OK Please press "Allow" button on the phone when superuser dialog appears! Network is successfully repaired. Performed by 2.6.4 Software version. |
The Following User Says Thank You to gulfamkhan For This Useful Post: |
02-15-2018, 15:25 | #12 (permalink) |
Member: 1073769 Status: Offline Thanks Meter: 34 | my problem solve flash this rom and repair netwark https://mega.nz/#!ptdESSAR!gmBzEkef6...UyKnVcK_XZHst0 |
The Following User Says Thank You to cchajmu For This Useful Post: |
