04-02-2015, 18:58 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1756668 Status: Offline Thanks Meter: 4 | Samsung SM-N910T issue ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM101 Selected model: SM-N910T Reading info, please wait... ADB server killed. Warning: Selected model (SM-N910T) differs from the detected one (SGH-T889)! If you want select (SGH-T889) as (SM-N910T) model, please check "manual select". ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM101 Selected model: SM-N910T Selected file: C:\Users\Impact Wireless Inc\Downloads\Cert-SM-N910T_ 3xxxxxxxxxxxxxx_RF8F91MA29.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM101 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Writing Certificate failed |
04-02-2015, 20:06 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to perform "Wipe Security EFS" procedure via phone's menu: 1. Reflash the phone with any firmware (don't root the phone after, this is important!). 2. Type *#9090#. 3. Type at rigth corner MENU + select "Back". 4. Typy at rigth corner MENU + input Q. 5. Type at rigth croner MENU + input 0000. https://www.youtube.com/watch?v=1DtPT2MmNhg. Also look here: http://forum.gsmhosting.com/vbb/f684...olved-1933635/ http://forum.gsmhosting.com/vbb/f684...olved-1933394/ |
04-02-2015, 21:06 | #5 (permalink) | |
Member: 1756668 Status: Offline Thanks Meter: 4 | Quote:
04-03-2015, 06:15 | #6 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
04-03-2015, 19:28 | #8 (permalink) | |
I used this method to root. http://androidxda.com/root-samsung-g...ote-4-sm-n910t | |
04-07-2015, 01:01 | #9 (permalink) |
Member: 1756668 Status: Offline Thanks Meter: 4 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.1 ----------------------------------------------------------------------------------- To connect SM-N910T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N910T Selected file: C:\Users\Simple Wireless\Downloads\Cert-SM-N910T_ 3XXXXXXXXXXXXXX.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM10 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Writing Certificate failed |
04-07-2015, 02:38 | #10 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | Quote:
Hopefully this will help.. | |
04-07-2015, 20:06 | #14 (permalink) |
Member: 1756668 Status: Offline Thanks Meter: 4 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.1 ----------------------------------------------------------------------------------- To connect SM-N910T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N910T Detected phone model: SM-N910T Firmware compiled date: Thu Nov 13 17:59:11 KST 2014 PDA version: N910TUVU1ANK4 CSC version: N910TTMB1ANK4 SW version: N910TUVU1ANK4 Phone IMEI: 3xxxxxxxxxxxxx0 Phone SN: RF8FA0B3MHY Android version: 4.4.4 (KTU84P) Reading info... Mode: Normal Firmware compiled date: Oct 17 2014 Firmware compiled time: 17:00:00 Firmware released date: Nov 11 2014 Firmware released time: 19:36:24 SW Version: MPSS.DI.3.0.c5-00300-M9625TAARANAZM-1.7386.2 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N910T-3xxxxxxxxxxxxx0-07-04-2015_13-47- 12-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N910T-3xxxxxxxxxxxxx0-07-04-2015_13-51- 30-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Oct 17 2014 Firmware compiled time: 17:00:00 Firmware released date: Nov 11 2014 Firmware released time: 19:36:24 SW Version: MPSS.DI.3.0.c5-00300-M9625TAARANAZM-1.7386.2 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N910T Selected file: C:\Users\Simple Wireless\Downloads\Cert-SM-N910T_ 356095062611983_RF8F91MA29.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N910T Selected file: C:\Users\Simple Wireless\Downloads\Cert-SM-N910T_ 356095062611983_RF8F91MA29.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM10 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Writing Certificate failed |
04-07-2015, 20:25 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If after "Wipe Security" operation phone's IMEI remains the same - reflash the phone with any firmware and don't root the phone after, this is important! After reflashing perform "Wipe Security EFS" procedure via phone's menu: 1. Type *#9090#. 2. Type at rigth corner MENU + select "Back". 3. Typy at rigth corner MENU + input Q. 4. Type at rigth croner MENU + input 0000. https://www.youtube.com/watch?v=1DtPT2MmNhg If after "Wipe Security EFS" procedure via phone's menu IMEI remains the same - currently no solution for such phones. |
