samsunsg i9190 imei repair error Firmware Build Date: Jun 04, 2013 Firmware Build time: 17:00:00 Firmware Released date: Jun 21, 2013 Firmware Check-out time: 15:02:22 SW Version: M8930B-AAAATAZM-3.2.27030 Old IMEI: 004400-15-202000-0 New IMEI: 355853111111111 Firmware Build Date: Fri Jun 21 13:43:21 CST 2013 Phone SN: RV1D692MMWW Android version: 4.2.2 (JDQ39) Root cheking Old IMEI Deleting Please wait ... This may take some time The device will restart. Do not disconnect the cable!. Firmware Build Date: Jun 04, 2013 Firmware Build time: 17:00:00 Firmware Released date: Jun 21, 2013 Firmware Check-out time: 15:02:22 SW Version: M8930B-AAAATAZM-3.2.27030 Found phone on COM49 GT-I9190 phone for repair NVM ... NVM repair completed successfully New IMEI successfully written. To apply the changes, restart the phone but imei 0/01 was please help |
Hello. Please install the latest software version and do the next actions to make Repair IMEI: 1. Root your phone manualy. 2. Connect powered-on phone to PC via Micro USB cable. 3. Enter correct IMEI. 4. Click "IMEI fix" button. 5. Follow software instructions (prompts). To root the phone, please perform the next steps: 1. Put the phone into Download Mode. 2. Connect the phone to PC via Micro USB cable. 3. Install required driver. 4. Select "Root_GT-I9190.oct" firmware file. 5. Click "Write firmware" button. 6. Copy the file "GT-I9190_RootKit_v1.zip" to the root folder of your memory card. 7. Shutdown your device. 8. Put your device into Recovery mode. 9. Select "apply update from sdcard" and choose "GT-I9190_RootKit_v1.zip". 10. Select "reboot system now". 11. After rebooting yor phone will be rooted. Note, after Repair IMEI operation will be successfully completed You should re-start your phone via phone's menu (don't disconnect the battery!). |
