Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-30-2013, 17:08   #1 (permalink)
Member: 1866961
Sonork: 100.165473
Thanks Meter: 2
samsunsg i9190 imei repair error
Firmware Build Date: Jun 04, 2013
Firmware Build time: 17:00:00
Firmware Released date: Jun 21, 2013
Firmware Check-out time: 15:02:22
SW Version: M8930B-AAAATAZM-3.2.27030
Old IMEI: 004400-15-202000-0
New IMEI: 355853111111111
Firmware Build Date: Fri Jun 21 13:43:21 CST 2013
Phone SN: RV1D692MMWW
Android version: 4.2.2 (JDQ39)
Root cheking
Old IMEI Deleting Please wait ... This may take some time
The device will restart. Do not disconnect the cable!.
Found phone on COM49
GT-I9190 phone for repair NVM ...
NVM repair completed successfully
New IMEI successfully written.
To apply the changes, restart the phone
but imei 0/01 was please help
The Following User Says Thank You to osman3363 For This Useful Post:
Old 08-31-2013, 09:34   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Hello.
Please install the latest software version and do the next actions to make Repair IMEI:
1. Root your phone manualy.
2. Connect powered-on phone to PC via Micro USB cable.
3. Enter correct IMEI.
4. Click "IMEI fix" button.
5. Follow software instructions (prompts).
To root the phone, please perform the next steps:
1. Put the phone into Download Mode.
2. Connect the phone to PC via Micro USB cable.
3. Install required driver.
4. Select "Root_GT-I9190.oct" firmware file.
5. Click "Write firmware" button.
6. Copy the file "GT-I9190_RootKit_v1.zip" to the root folder of your memory card.
7. Shutdown your device.
8. Put your device into Recovery mode.
9. Select "apply update from sdcard" and choose "GT-I9190_RootKit_v1.zip".
10. Select "reboot system now".
11. After rebooting yor phone will be rooted.
Note, after Repair IMEI operation will be successfully completed You should re-start your phone via phone's menu (don't disconnect the battery!).
Page generated in 0.13119 seconds with 8 queries
