04-04-2015, 21:11 | #2 (permalink) |
Junior Member Join Date: Mar 2015 Location: Tokyo, Japan
Member: 2356430 Status: Offline Thanks Meter: 7 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.1 ----------------------------------------------------------------------------------- To connect SC-01G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Detected phone model: SC-01G Firmware compiled date: Sat Oct 4 20:51:37 KST 2014 PDA version: SC01GOMU1ANJ3 CSC version: SC01GDCM1ANJ3 SW version: SC01GOMU1ANJ3 Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Detected phone model: SC-01G Firmware compiled date: Sat Oct 4 20:51:37 KST 2014 PDA version: SC01GOMU1ANJ3 CSC version: SC01GDCM1ANJ3 SW version: SC01GOMU1ANJ3 Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) Reading info... Mode: Normal Firmware compiled date: Sep 15 2014 Firmware compiled time: 17:00:00 Firmware released date: Oct 3 2014 Firmware released time: 23:25:46 SW Version: MPSS.DI.3.0.c5-00272-M9625TAARANAZM-1 Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SC-01G-05-04-2015_01-15-30-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SC-01G-05-04-2015_01-15-31-.asec file Wiping EFS... ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- To connect SM-N915D phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N915D Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N915D Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N910-354483061000006.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- To connect SC-01G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N910-354483061000006.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- To connect SM-N910A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N910A Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N910A Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N910A Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- To connect SC-01G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N910-354483061000006.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915T-355024060231017.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- To connect SM-N915G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N915G Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N915G Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- To connect SM-N915T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N915T Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915T-355024060231017.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N915T Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SM-N915T Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- To connect SC-01G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Reading info, please wait... Detected phone model: SC-01G Firmware compiled date: Sat Oct 4 20:51:37 KST 2014 PDA version: SC01GOMU1ANJ3 CSC version: SC01GDCM1ANJ3 SW version: SC01GOMU1ANJ3 Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915T-355024060231017.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM401 Selected model: SC-01G Reading info, please wait... Detected phone model: SC-01G Firmware compiled date: Sat Oct 4 20:51:37 KST 2014 PDA version: SC01GOMU1ANJ3 CSC version: SC01GDCM1ANJ3 SW version: SC01GOMU1ANJ3 Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM401 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM401 Selected model: SC-01G Reading info, please wait... Detected phone model: SC-01G Firmware compiled date: Sat Oct 4 20:51:37 KST 2014 PDA version: SC01GOMU1ANJ3 CSC version: SC01GDCM1ANJ3 SW version: SC01GOMU1ANJ3 Phone IMEI: Unknown Android version: 4.4.4 (KTU84P) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM401 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- To connect SC-06D phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "PDA" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+Modem+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Set "Diag config" to "UART" value. 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SC-03E phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+MODEM+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HSIC". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SC-01G phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM401 Mode: Normal Phone model: SC-01G Firmware compiled date: Sep 15 2014 Firmware compiled time: 17:00:00 Firmware released date: Oct 3 2014 Firmware released time: 23:25:46 Incorrect IMEI SW version: MPSS.DI.3.0.c5-00272-M9625TAARANAZM-1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM401 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM10 Selected model: SC-01G Selected file: C:\Users\Yehey Japan! IT PC\Desktop\honda tmx alpha \Cert-SM-N915_355072060300852.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM10 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes |
The Following User Says Thank You to myk143 For This Useful Post: |
