01-17-2015, 13:48 | #1 (permalink) |
Freak Poster Join Date: Nov 2007 Location: karachi,pakistan Age: 40
Member: 625563 Status: Offline Sonork: Niceguy Thanks Meter: 40 | sc-02c unlock problem here is log ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SC-02C Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM36 Detected phone model: SC-02C HW Version: SGH-N033XXXDCM Phone IMEI: 356881-04-641066-1 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed No diagnostic ports found! Connecting to phone on COM4 Phone connection failed |
01-17-2015, 13:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To connect SC-02C, perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. Also, try to select another COM port manually. |
01-17-2015, 14:21 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Contact us to Skype right now, we will check remotely, where can be the problem. Our contacts You can find in our profile. |
01-17-2015, 15:15 | #5 (permalink) |
Member: 625563 Status: Offline Sonork: Niceguy Thanks Meter: 40 | downgrade firmware but problem is same here is log ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM37 Selected model: SC-02C Detected phone model: SC-02C HW Version: SGH-N033XXXDCM Phone IMEI: 356881-04-641066-1 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM37 Detected phone model: SC-02C HW Version: SGH-N033XXXDCM Phone IMEI: 356881-04-641066-1 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed No diagnostic ports found! Connecting to phone on COM4 Phone connection failed |
01-18-2015, 05:43 | #6 (permalink) |
Member: 625563 Status: Offline Sonork: Niceguy Thanks Meter: 40 | write firmware 2.3.6 or write firmware 4.0. but same problem i can,t understand how can i unlock this phone show result log Selected firmware file: SC02COMKL2_SC02CDCMKL2_DCM_Android_ 2.3.6.oct Please put the phone into Download Mode and connect USB cable. To put SC-02C into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PARAM section... PARAM section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing FACTORYFS section... FACTORYFS section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SC-02C Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM24 Selected model: SC-02C Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM37 Detected phone model: SC-02C HW Version: SGH-N033XXXDCM Phone IMEI: 356881-04-641066-1 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed No diagnostic ports found! Connecting to phone on COM4 Phone connection failed |
