01-23-2014, 18:11 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Cochabamba Age: 38
Member: 87396 Status: Offline Thanks Meter: 64 | SC-04E unlock problem Code: Welcome to Octoplus/Octopus Box Samsung software version 1.4.4 ----------------------------------------------------------------------------------- To connect GT-S6310 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SC-04E phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: SC04EOMUAMDI_SC04EDCMAMDI_SC04EOMUAMDI_HOME.oct Please switch your phone to the download mode and connect it to a PC. To put SC-04E phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-04E Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM128 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM129 Selected model: SC-04E Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM128 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NVM-SC-04E-23-01-2014_11-41-51-.nvm file Firmware compiled date: Tue Apr 23 13:39:41 KST 2013 PDA version: SC04EOMUAMDI CSC version: SC04EDCMAMDI SW version: SC04EOMUAMDI Phone IMEI: 355638050257714 Phone SN: RF1D45QY9FJ Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NVM-SC-04E-23-01-2014_11-44-20-.nvm file Proper android device not found. Make shure that "USB debug" option on the device is turned on. Cheking Root Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NVM-SC-04E-23-01-2014_11-45-08-.nvm file Firmware compiled date: Tue Apr 23 13:39:41 KST 2013 PDA version: SC04EOMUAMDI CSC version: SC04EDCMAMDI SW version: SC04EOMUAMDI Phone IMEI: 355638050257714 Phone SN: RF1D45QY9FJ Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NVM-SC-04E-23-01-2014_12-03-07-.nvm file ADB server killed. Firmware compiled date: Tue Apr 23 13:39:41 KST 2013 PDA version: SC04EOMUAMDI CSC version: SC04EDCMAMDI SW version: SC04EOMUAMDI Phone IMEI: 355638050257714 Phone SN: RF1D45QY9FJ Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NVM-SC-04E-23-01-2014_12-14-27-.nvm file Firmware compiled date: Tue Apr 23 13:39:41 KST 2013 PDA version: SC04EOMUAMDI CSC version: SC04EDCMAMDI SW version: SC04EOMUAMDI Phone IMEI: 355638050257714 Phone SN: RF1D45QY9FJ Android version: 4.2.2 (JDQ39) Cheking Root Phone is Rooted Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 23 2013 Firmware released time: 15:11:45 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17062 Found phone on COM128 Repairing NVM for SC-04E phone... Phone unlocking failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NVM-SC-04E-23-01-2014_12-17-19-.nvm file Firmware compiled date: Tue Apr 23 13:39:41 KST 2013 PDA version: SC04EOMUAMDI CSC version: SC04EDCMAMDI SW version: SC04EOMUAMDI Phone IMEI: Unknown Phone SN: RF1D45QY9FJ Android version: 4.2.2 (JDQ39) Cheking Root Phone is Rooted Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! Phone unlocking was canceled ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Operation was canceled Writing security was canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Writing NVM... NVM writing completed successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Writing NVM... NVM writing completed successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: GT-I8260L Mode: Emergency Unlock for GT-I8260L phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM135 Selected model: GT-I8260L Mode: Emergency Unlock for GT-I8260L phone in emergency mode can’t be done ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM157 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 Phone IMEI: 357735-05-188227-2 SW version: 8X25-SSOSKOLYM-2035 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM157 Selected model: GT-I8260L Mode: Normal Phone model: GT-I8260L Firmware compiled date: May 07 2013 Firmware compiled time: 14:00:00 Firmware released date: Jul 18 2013 Firmware released time: 18:13:15 Phone IMEI: 357735-05-188227-2 SW version: 8X25-SSOSKOLYM-2035 Unlocking phone... Phone is successfully unlocked ----------------------------------------------------------------------------------- To connect SC-04E phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM157 Selected model: SC-04E Detected phone model: SC-04E Firmware compiled date: Tue Apr 23 13:39:41 KST 2013 PDA version: SC04EOMUAMDI CSC version: SC04EDCMAMDI SW version: SC04EOMUAMDI Phone IMEI: Unknown Phone SN: RF1D45QY9FJ Android version: 4.2.2 (JDQ39) Rebooting phone in Download mode... Phone successfully rebooted in download mode. Please switch your phone to the download mode and connect it to a PC. To put SC-04E phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SC-04E Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM128 Phone connection failed Connecting to phone on COM127 Phone connection failed Connecting to phone on COM129 Phone connection failed No diagnostic ports found! Connecting to phone on COM4 Phone connection failed Connecting to phone on COM19 Phone connection failed Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Creating NVM backup Reading NVM done! Writing NVM... NVM writing completed successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM127 Selected model: SC-04E Mode: Normal Phone model: SC-04E Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Unlocking phone... Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NVM-SC-04E-23-01-2014_13-05-32-.nvm file Firmware compiled date: Tue Apr 23 13:39:41 KST 2013 PDA version: SC04EOMUAMDI CSC version: SC04EDCMAMDI SW version: SC04EOMUAMDI Phone IMEI: Unknown Phone SN: RF1D45QY9FJ Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted Phone unlocking failed |
01-23-2014, 18:20 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Quote:
01-23-2014, 20:22 | #3 (permalink) |
Member: 87396 Status: Offline Thanks Meter: 64 | imei was ok after flashing before unlocking i already flashed previous firmware still the same no imei and now is unable to make any call not even emergency calls |
01-24-2014, 09:32 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Your device is not connected correctly: Quote:
To connect SC-04E, You have to perform carefully the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. When phone's info will be read correctly, root the phone once again and only then perform "Repair IMEI" operation. | |
01-24-2014, 15:05 | #6 (permalink) | |
02-07-2014, 19:53 | #7 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ESPAÑA
Member: 808967 Status: Offline Thanks Meter: 155 | Bienvenido en Octoplus/Octopus Box Samsung software versión 1.4.8 ----------------------------------------------------------------------------------- To connect SC-04E phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM1 Modelo seleccionado: SC-04E Modo: Emergencia No se puede leer códigos para el teléfono SC-04E en el modo emergencia Reading codes canceled ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM6 Modelo seleccionado: SC-04E Modo: Emergencia No se puede leer códigos para el teléfono SC-04E en el modo emergencia ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM6 Modelo seleccionado: SC-04E Modo: Emergencia No se puede hacer la liberación para el teléfono SC-04E en el modo emergencia ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM111 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Tiempo de compilación del firmware: Fecha de salida del firmware: -ù~ Tiempo de salida del firmware: Versión del SW: Leyendo los códigos de liberación del teléfono. Esto puede llevarle un cierto tiempo, por favor, espere… Reading security failed La lectura de códigos ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM111 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Tiempo de compilación del firmware: Fecha de salida del firmware: -ù~ Tiempo de salida del firmware: Versión del SW: Liberando el teléfono... Realizando el backup de NVM ¡La lectura de NVM está terminada! Backup saved as C:\Archivos de programa\Octoplus \Octoplus_Samsung\BACKUP\NVM-SC-04E-07-02-2014_13-24-15-.nvm file Proper android device not found. Make shure that "USB debug" option on the device is turned on. La liberación del teléfono ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM113 Modelo seleccionado: SC-04E Modo: Emergencia No se puede leer códigos para el teléfono SC-04E en el modo emergencia Reading codes canceled ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM112 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Dec 3 2013 Tiempo de salida del firmware: 21:22:25 IMEI del teléfono: 356778-05-713244-2 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Leyendo los códigos de liberación del teléfono. Esto puede llevarle un cierto tiempo, por favor, espere… Reading security failed La lectura de códigos ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM112 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Dec 3 2013 Tiempo de salida del firmware: 21:22:25 IMEI del teléfono: 356778-05-713244-2 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Liberando el teléfono... Realizando el backup de NVM El procedimiento de lectura de NVM ha sido fallado Backup saved as C:\Archivos de programa\Octoplus \Octoplus_Samsung\BACKUP\NVM-SC-04E-356778057132442-07-02- 2014_13-27-28-.nvm file Fecha de creación del firmware: Tue Dec 3 20:27:06 KST 2013 PDA version: SC04EOMUAML2 CSC version: SC04EDCMAML2 Versión del SW: SC04EOMUAML2 IMEI del teléfono: 356778057132442 Phone SN: R31D6034M4X Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted La liberación del teléfono ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM113 Modelo seleccionado: SC-04E ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM112 La conexión con el teléfono falló Intentando a conectar el teléfono en COM111 La conexión con el teléfono falló Intentando a conectar el teléfono en COM113 La conexión con el teléfono falló ¡Puertos diagnósticos no encontrados! Intentando a conectar el teléfono en COM6 La conexión con el teléfono falló No se puede realizar la acción seleccionada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM112 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Dec 3 2013 Tiempo de salida del firmware: 21:22:25 IMEI del teléfono: 356778-05-713244-2 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Leyendo los códigos de liberación del teléfono. Esto puede llevarle un cierto tiempo, por favor, espere… Reading security failed La lectura de códigos ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM112 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Dec 3 2013 Tiempo de salida del firmware: 21:22:25 IMEI del teléfono: 356778-05-713244-2 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Leyendo los códigos de liberación del teléfono. Esto puede llevarle un cierto tiempo, por favor, espere… Reading security failed La lectura de códigos ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM112 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Dec 3 2013 Tiempo de salida del firmware: 21:22:25 IMEI del teléfono: 356778-05-713244-2 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Liberando el teléfono... Realizando el backup de NVM El procedimiento de lectura de NVM ha sido fallado Backup saved as C:\Archivos de programa\Octoplus \Octoplus_Samsung\BACKUP\NVM-SC-04E-356778057132442-07-02- 2014_13-32-52-.nvm file ADB server killed. Fecha de creación del firmware: Tue Dec 3 20:27:06 KST 2013 PDA version: SC04EOMUAML2 CSC version: SC04EDCMAML2 Versión del SW: SC04EOMUAML2 IMEI del teléfono: 356778057132442 Phone SN: R31D6034M4X Android version: 4.2.2 (JDQ39) Cheking Root Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation. Can't get root privileges. Phone is not rooted La liberación del teléfono ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM6 Modelo seleccionado: SC-04E Modo: Emergencia No se puede leer códigos para el teléfono SC-04E en el modo emergencia ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM113 Modelo seleccionado: SC-04E ¡En el puerto seleccionado el teléfono no fue detectado! Intentando a buscar el puerto USB diagnóstico... Intentando a conectar el teléfono en COM112 La conexión con el teléfono falló Intentando a conectar el teléfono en COM111 La conexión con el teléfono falló Intentando a conectar el teléfono en COM113 La conexión con el teléfono falló ¡Puertos diagnósticos no encontrados! Intentando a conectar el teléfono en COM5 La conexión con el teléfono falló Intentando a conectar el teléfono en COM6 La conexión con el teléfono falló No se puede realizar la acción seleccionada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM112 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Dec 3 2013 Tiempo de salida del firmware: 21:22:25 IMEI del teléfono: 356778-05-713244-2 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Leyendo los códigos de liberación del teléfono. Esto puede llevarle un cierto tiempo, por favor, espere… Reading security failed La lectura de códigos ha sido fallada ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM112 Modelo seleccionado: SC-04E Modo: Normal Modelo del teléfono: SC-04E Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: Dec 3 2013 Tiempo de salida del firmware: 21:22:25 IMEI del teléfono: 356778-05-713244-2 Versión del SW: M9615A-CEFWTAZM-4.0.17062 Liberando el teléfono... Realizando el backup de NVM |
02-07-2014, 20:39 | #8 (permalink) | |
Freak Poster Join Date: Nov 2009
Member: 1158416 Status: Offline Thanks Meter: 182 | I unlock 6 units of this model SC-04E without any error using octopus. If you have Version 4.2.2 you must downgrade it to SC04EOMUAMDI and then follow this: Quote:
Tips: How to flash For_Unlock_and _Repair_IMEI for I9505 1. Put the phone to download mode 2. Select model: I9505 and load the files/firmware 3. Wait till flashing is done and proceed in unlocking Read Codes is more safer than Direct unlock just put other SIM/ Invalid SIM and put NCK. Note: After Phone is totaly UNLOCK, you must Flash it again into its original STOCK ROM Tested ROM: SC04EOMUAMF2 SC04EOMUAMG2 SC04EOMUAML2 | |
08-27-2014, 14:25 | #9 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | Quote:
you can downgrade from octopus or odin? | |
