08-21-2016, 14:59 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Ãfgĥäñîštâй
Member: 1844204 Status: Offline Sonork: 100.1111172 Thanks Meter: 337 | SCH-I545 Can I unlock android 5.0.1 PLz Help Me This error Code: Welcome to Octoplus/Octopus Box Samsung software version 2.3.2 ----------------------------------------------------------------------------------- To connect SCH-I545 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SCH-I545 Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM33 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM14 Phone connection failed Selected action can’t be performed Performed by 2.3.2 software version |
08-22-2016, 11:11 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please make Factory Reset then perform all of the following actions: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Connect the phone directly to PC. 11. Press "Read Info" on Main tab of the Software. When phone info will be read fully and correctly - proceed with "Unlock" operation. |
