01-03-2014, 17:38 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2098219 Status: Offline Sonork: 1651168:Trymi_ Thanks Meter: 0 | SGH a667 help Selected model: SGH-A667 Selected port: COM3 Baud rate: 115200 Plase, connect phone to UART cable, insert battery and press shortly power button Connecting... ---------------------------------------------------------------------------------------------------- it stays like that and does not move |
01-03-2014, 17:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To perform "Read codes" operation please do the next: 1. Fully charge phone's battery. 2. Select correct (Box) COM port. 3. Connect your phone to the Box via Samsung Micro UART cable. 4. Press "Read codes" button in Software. 5. Insert the battery. 6. Shortly press "Power ON" button on phone. |
01-03-2014, 17:57 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Do You use Samsung Micro UART C3300k/C3303k cable or standart Micro UART cable? You need to use Samsung Micro UART C3300k/C3303k cable. Try to use another cable. The phone shouldn't starts to turn on without pressing the "Power ON" button. Log should be like here: http://forum.gsmhosting.com/vbb/9624310-post1.html. |
01-03-2014, 18:38 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please try to do the next: 1. Fully charge phone's battery. 2. Select correct (Box) COM port. 3. Connect your phone to the Box via Samsung Micro UART cable. 4. Press "Read codes" button in Software. 5. Insert the battery. 6. Shortly press "Power ON" button on phone 10-20 times (one after the other). |
01-16-2014, 18:40 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | On step 6, please shortly press "Power ON" button on phone 10-20 times (one after the other, fast). Tomorrow we will prepare Video Manual for You. |
