07-07-2014, 17:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1288575 Status: Offline Thanks Meter: 36 | Sgh-i317 imei repair complete using sgh-t889 in samsung software Found perfect solution. using sgh-i317 on 4.3 rooted with knox disabled. *#7284# select PDA ; *#0808# select DM + MODEM + ADB ; *#9090# Select DM...HSIC USB DEBUGGING ENABLED AND SUPERUSER SET TO GRANT ALWAYS. NOW IN OCTOPLUS SAMSUNG SOFTWARE I SELECT SGH-T889 MODEL INSTEAD. READ INFO, OKAY. TRIED FAST IMEI REPAIR METHOD BUT NOT COMPLETE. TRY AGAIN REGULAR IMEI REPAIR METHOD AND SUCCESS NEW IMEI REPAIR COMPLETE ON SGH-I317 USING SGH-T889 IN SOFTWARE. Welcome to Octoplus/Octopus Box Samsung software version 1.6.1 ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I317 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-I317 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM33 Mode: Normal Phone model: ACEFWMAZ Phone model is not supported Mode: Normal Phone model: ACEFWMAZ Phone model is not supported Phone connection failed ----------------------------------------------------------------------------------- To connect SGH-I317 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-I317 Mode: Normal Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Incorrect IMEI SW version: M9615ACEHWMAZD179707 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Old IMEI: 004400-15-202000-0 New IMEI: *-75-966241-8 Creating NVM backup Reading NVM done! Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SGH-I317 Mode: Normal Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Incorrect IMEI SW version: M9615ACEHWMAZD179707 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM33 Mode: Normal Mode: Normal Phone model: ACEFWMAZ Phone model is not supported Phone connection failed Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM33 Selected model: 707SC Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM12 Phone connection failed Connecting to phone on COM14 Phone connection failed No diagnostic ports found! Connecting to phone on COM33 Phone connection failed ----------------------------------------------------------------------------------- To connect SGH-I317 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: SGH-I317 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM12 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-I317 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM12 Mode: Emergency ----------------------------------------------------------------------------------- To connect SGH-T899 phone you have to perform the following steps: 1. Disconnect cable from phone. 2. Go to dial window. 3. Enter "##634#" number. 4. Input *#7284# code. 5. Select "QC RmNetComposite" option. 6. Press "OK" button. 7. Wait until phone restart. 8. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-T889 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Incorrect IMEI SW version: M9615ACEHWMAZD179707 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Old IMEI: 004400-15-202000-0 New IMEI: *****-75-966241-8 Creating NVM backup NVM reading process canceled IMEI write canceled. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Old IMEI: 004400-15-202000-0 New IMEI: ******75-966241-8 Creating NVM backup Reading NVM done! Firmware compiled date: Tue Nov 19 16:53:36 KST 2013 PDA version: I317UCUBMK6 CSC version: I317ATTBMK6 SW version: I317UCUBMK6 Phone IMEI: Unknown Phone SN: R31D90MZDDF Android version: 4.3 (JSS15J) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-T889-07-07-2014_12-18-49-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Found phone on COM12 Repairing NVM for SGH-T889 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Phone IMEI: ******-75-966241-8 SW version: M9615ACEHWMAZD179707 Creating NVM backup NVM reading process canceled Repairing NVM for SGH-T889 phone... Writing NVM canceled NVM repair completed successfully Phone will restart now ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Phone IMEI: ******-75-966241-8 SW version: M9615ACEHWMAZD179707 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Phone IMEI: ******-75-966241-8 SW version: M9615ACEHWMAZD179707 Creating NVM backup Reading NVM done! Repairing NVM for SGH-T889 phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Phone IMEI: ******-05-205703-3 SW version: M9615ACEHWMAZD179707 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Old IMEI: ******-05-205703-3 New IMEI: ******-75-966241-8 Creating NVM backup Reading NVM done! Firmware compiled date: Tue Nov 19 16:53:36 KST 2013 PDA version: I317UCUBMK6 CSC version: I317ATTBMK6 SW version: I317UCUBMK6 Phone IMEI: 354340052057033 Phone SN: R31D90MZDDF Android version: 4.3 (JSS15J) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-T889-354340052057033-07-07-2014_12-32- 01-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Found phone on COM12 Repairing NVM for SGH-T889 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SGH-T889 Mode: Normal Phone model: SGH-T889 Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Phone IMEI: ******-75-966241-8 SW version: M9615ACEHWMAZD179707 |
07-08-2014, 10:42 | #2 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2162605 Status: Offline Thanks Meter: 3 | Clippy165 could please explain the setting you entered in the phone, because doesn't matter what I do and what setting I chose in the phone I always get unknown device. the only way I am able to connect to the box and read the info when I enter *#7284# and set "USB" Radio button to "MODEM" value and "DM/DUM over HS-USB". but when I try to repair the IMEI I get this message : Proper android device not found. Make Shure that "USB debug" option on the device is turned on. Write IMEI failed even when I change the model to sgh-t889, so please explain the steps for the setting in the phone. Welcome to Octoplus/Octopus Box Samsung software version 1.6.1 ----------------------------------------------------------------------------------- To connect SGH-I317 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I317 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM34 Phone connection failed ----------------------------------------------------------------------------------- *Now it shows unknown device then I change to manual and chose the port my self ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I317 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM34 Selected model: SGH-I317 Phone was not found on the selected port! ----------------------------------------------------------------------------------- *Now I disconnect the device and enter *#7284# then in step 7 I change the USB to MODEM then 2 devices show in device manager as " CDMA Qualcomm technologies msm " and I go and install the drivers then connect the device to the BOX Welcome to Octoplus/Octopus Box Samsung software version 1.6.1 ----------------------------------------------------------------------------------- To connect SGH-I317 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. Welcome to Octoplus/Octopus Box Samsung software version 1.6.1 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM34 Selected model: SGH-I317 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM42 Mode: Emergency ----------------------------------------------------------------------------------- *now I change to manual and chose the port ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I317 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM34 Selected model: SGH-I317 Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM41 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Phone IMEI: 353800-05-143491-4 SW version: M9615ACEHWMAZD179707 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM41 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Old IMEI: 353800-05-143491-4 New IMEI: 351912-03-049252-5 Creating NVM backup Reading NVM done! Proper android device not found. Make Shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM41 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Phone IMEI: 353800-05-143491-4 SW version: M9615ACEHWMAZD179707 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM41 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Old IMEI: 353800-05-143491-4 New IMEI: 351912-03-049252-5 Creating NVM backup Reading NVM done! Proper android device not found. Make Shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM41 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 Phone IMEI: 353800-05-143491-4 SW version: M9615ACEHWMAZD179707 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM41 Selected model: SGH-I317 Mode: Normal Phone model: ACEFWMAZ Warning: Selected model (SGH-I317) differs from the detected one (ACEFWMAZ)! Firmware compiled date: Oct 09 2013 Firmware compiled time: 09:00:00 Firmware released date: Nov 18 2013 Firmware released time: 23:31:16 SW version: M9615ACEHWMAZD179707 Old IMEI: 353800-05-143491-4 New IMEI: 351912-03-049252-5 Creating NVM backup Reading NVM done! Proper android device not found. Make Shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- thanks Last edited by aburyaan1; 07-08-2014 at 10:49. |
07-08-2014, 15:55 | #3 (permalink) | |
Member: 1288575 Status: Offline Thanks Meter: 36 | Quote:
your second mistake, you are changing the mode of the usb in *#7284# menu, do not do this under | UART | leave it checked to PDA ; under | USB | leave it checked on PDA aswell. Under qualcomm usb settings select | DM + MODEM + ADB | also make sure usb debugging option is checked. Step 3 dial *#9090# and check the first option DIAG CONFIG [1]DM/DUM over HS-USB[*] then phone will restart after select model sgh-t889 in samsung software and read info. if read successfully you have adb connection and usb debug good after read then you can make repair imei. if the above does not work i would advise upgrading the phone firmware to 4.3 | |
