02-22-2014, 08:39 | #1 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Pampanga, Philippines
Member: 1871628 Status: Offline Thanks Meter: 22 | SGH-i337 (Galaxy S4) Unlocking Problem Im having an Unlocking Problem Issue with This Phone SGH-i337 (Galaxy S4). Here's The Logs... Welcome to Octoplus/Octopus Box Samsung software version 1.4.9 ----------------------------------------------------------------------------------- To connect SGH-I337 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM17 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM17 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SGH-I337 Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM6 Phone connection failed Ive'd Used Micro UART (RJ45/3303 Cable). Ive'd also tried using CA-101/USB cable but still i can't connect Phone or Software can't read the Phone. Checking it on Device Manager Phone was regognize or connected properly. Please do help me Team. Thanks so much in advance. |
02-22-2014, 09:15 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,406 | Hello. To unlock this device, at first You need to connect it device correctly. To connect SGH-I337 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Then, when phone's info will be read, You need to press "Unlock" button. The result should be like here: smausng i337m 4.3 unlock done. Also, please look here: http://forum.gsmhosting.com/vbb/f684.../#post10030330, http://forum.gsmhosting.com/vbb/f684.../#post10014757, http://forum.gsmhosting.com/vbb/f684.../#post10009041, http://forum.gsmhosting.com/vbb/f684...5/#post9979144, http://forum.gsmhosting.com/vbb/9960410-post1293.html, http://forum.gsmhosting.com/vbb/f684.../#post10079684. |
02-22-2014, 10:33 | #3 (permalink) |
Member: 1871628 Status: Offline Thanks Meter: 22 | Update: Welcome to Octoplus/Octopus Box Samsung software version 1.4.9 ----------------------------------------------------------------------------------- To connect SGH-I337 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM20 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM20 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM20 Mode: Emergency - Phone Already Rooted (Downloaded From Octopus Support) - Drivers properly Installed Still not Unlocked (Phone/Software Version is 4.2.2) |
