08-28-2014, 13:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1390215 Status: Offline Thanks Meter: 11 | SGH-I357 Sasmug S4 Active, Imei Lost is 4.4.2 andorid, how i can root it? How i can repair de imei? Octopus can unlock this phone? Thnaks so mutch. |
08-28-2014, 14:01 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. SGH-I357 is currently not supported. |
08-28-2014, 14:05 | #3 (permalink) |
Member: 1390215 Status: Offline Thanks Meter: 11 | SGH-I537 Sasmug S4 Active, Imei Lost "Sorry for the last posr i have a mistake. is I537" please delete my last thread. hello i try to unlock a S4 Active and when i try to un lock it lost the imei. is 4.4.2 andorid, how i can root it? How i can repair de imei? Octopus can unlock this phone? Thnaks so mutch. |
08-28-2014, 14:16 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | To root the device, try to use the latest versions of VRoot and Kingo Root Softwares. Also try to use TowelRoot. Currently we have no other rooting Software/exploit for this device. |
08-28-2014, 17:04 | #5 (permalink) |
Member: 1390215 Status: Offline Thanks Meter: 11 | Hi i root the device an cant fix imei, have this log: Code: Plataforma: Samsung Android Puerto seleccionado: COM202 Modelo seleccionado: SGH-I537 Reading info, please wait... Modelo del teléfono detectado: SGH-I537 Fecha de creación del firmware: Fri May 16 14:53:09 KST 2014 PDA version: I537UCUCNE3 CSC version: I537ATTCNE3 Versión del SW: Unknown IMEI del teléfono: Unknown Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM202 Modelo seleccionado: SGH-I537 Modo: Emergencia Write IMEI failed |
08-28-2014, 17:09 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see from your Software log, phone's modem part is damaged: Quote:
It is not possible to repair IMEI, if phone's modem part is damaged. Re-flash the phone with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct), connect the device correctly and make Repair IMEI. | |
08-28-2014, 17:53 | #7 (permalink) |
Member: 1390215 Status: Offline Thanks Meter: 11 | i try to flash "PIT_I537UBUBML3_I537TCEBML3_TCE_Mexico(Telcel)_An droid_4.3" donwloaded form support but in the phone have a red textLike this: SECURE CHECK FAIL: SystemL : boot SECURE MAGICCODE CHECK FAIL: recovery SECURE CHECK FAIL: system SECURE CHECK FAIL: system SECURE CHECK FAIL: system SECURE CHECK FAIL: system SECURE CHECK FAIL: system SECURE CHECK FAIL: system Octopus log: Code: Plataforma: Samsung Android Puerto seleccionado: COM62 Modelo seleccionado: SGH-I537 Modo: Emergencia No se puede hacer la liberación para el teléfono SGH-I537 en el modo emergencia Seleccione el archivo de firmware: PIT_I537UBUBML3_I537TCEBML3_TCE_Mexico(Telcel)_Android_4.3.oct Please put the phone into Download Mode and connect USB cable. To put SGH-I537 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Escribiendo la sección PIT... L a sección PIT ha sido escrita con éxito Escribiendo la sección BOOT... L a sección BOOT ha sido escrita con éxito Escribiendo la sección RECOVERY... L a sección RECOVERY ha sido escrita con éxito Escribiendo la sección SYSTEM... |
08-28-2014, 18:12 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Most likely this problem is caused by attempt to downgrade firmware version. Try to re-flash the phone with 4.4.2 firmware. |
08-28-2014, 20:38 | #9 (permalink) |
Member: 1390215 Status: Offline Thanks Meter: 11 | Hello i reflash whit 4.4.2 donwloaded from support, and root. In the steps to conect i can do the *#0808# but qhen punt *#9090# have a screen whit ServiceMode but dont show any option, i press menu and Back but dont show nothing. When i try to conecct have this log: Code: Plataforma: Samsung Android Puerto seleccionado: COM200 Modelo seleccionado: SGH-I537 Modo: Normal Modelo del teléfono: SGH-I537 Fecha de creación del firmware: Tiempo de compilación del firmware: Fecha de salida del firmware: -ù~ Tiempo de salida del firmware: Versión del SW: Code: Plataforma: Samsung Android Puerto seleccionado: COM200 Modelo seleccionado: SGH-I537 Modo: Normal Modelo del teléfono: SGH-I537 Fecha de creación del firmware: Tiempo de compilación del firmware: Fecha de salida del firmware: -ù~ Tiempo de salida del firmware: Versión del SW: IMEI antiguo: Desconocido IMEI nuevo: 356554-05-269653-7 Realizando el backup de NVM ¡La lectura de NVM está terminada! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\NVM-SGH-I537-28-08-2014_21-28-50-.nvm file ADB server killed. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed |
08-29-2014, 06:35 | #10 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see from your Software log, You have not connected the device correctly. Phone's info should be read out fully and correctly, not as in the log: Quote:
1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. And only then (when phone's info will be read out fully and correctly), make Repair IMEI. | |
08-29-2014, 09:53 | #11 (permalink) |
Member: 1390215 Status: Offline Thanks Meter: 11 | Thanks i restart computer and phone and conect ok, but have an error repairing imei: Code: Plataforma: Samsung Android Puerto seleccionado: COM200 Modelo seleccionado: SGH-I537 Reading info, please wait... Modelo del teléfono detectado: SGH-I537 Fecha de creación del firmware: Fri May 16 14:53:09 KST 2014 PDA version: I537UCUCNE3 CSC version: I537ATTCNE3 Versión del SW: Unknown IMEI del teléfono: Unknown Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM200 Modelo seleccionado: SGH-I537 Modo: Normal Modelo del teléfono: SGH-I537 Fecha de creación del firmware: Tiempo de compilación del firmware: Fecha de salida del firmware: -ù~ Tiempo de salida del firmware: Versión del SW: IMEI antiguo: Unknown IMEI nuevo: 356554-05-269653-7 Realizando el backup de NVM ¡La lectura de NVM está terminada! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\NVM-SGH-I537-Unknown-29-08-2014_10-49-31-.nvm file Fecha de creación del firmware: Fri May 16 14:53:09 KST 2014 PDA version: I537UCUCNE3 CSC version: I537ATTCNE3 Versión del SW: Unknown IMEI del teléfono: Unknown Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SGH-I537-Unknown-29-08-2014_10-50-11-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Fecha de creación del firmware: Jan 28 2014 Tiempo de compilación del firmware: 02:00:00 Fecha de salida del firmware: May 16 2014 Tiempo de salida del firmware: 15:36:39 Versión del SW: M9615A-CEFWTAZM-4.0.17138 Found phone on COM202 Reparando el NVM para el teléfono SGH-I537... Write IMEI failed |
08-29-2014, 09:55 | #12 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Read the post above: Quote:
08-29-2014, 11:30 | #13 (permalink) |
Member: 1390215 Status: Offline Thanks Meter: 11 | Thanks i try new time an can see de SW version: Versión del SW: M9615A-CEFWTAZM-4.0.17138 Code: Plataforma: Samsung Android Puerto seleccionado: COM202 Modelo seleccionado: SGH-I537 Modo: Normal Modelo del teléfono: SGH-I537 Fecha de creación del firmware: Jan 28 2014 Tiempo de compilación del firmware: 02:00:00 Fecha de salida del firmware: May 16 2014 Tiempo de salida del firmware: 15:36:39 IMEI incorrecto Versión del SW: M9615A-CEFWTAZM-4.0.17138 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM202 Modelo seleccionado: SGH-I537 Modo: Normal Modelo del teléfono: SGH-I537 Fecha de creación del firmware: Jan 28 2014 Tiempo de compilación del firmware: 02:00:00 Fecha de salida del firmware: May 16 2014 Tiempo de salida del firmware: 15:36:39 Versión del SW: M9615A-CEFWTAZM-4.0.17138 IMEI antiguo: 004400-15-202000-0 IMEI nuevo: 356554-05-269653-7 Realizando el backup de NVM ¡La lectura de NVM está terminada! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\NVM-SGH-I537-004400152020000-29-08-2014_11-54-21-.nvm file Fecha de creación del firmware: Fri May 16 14:53:09 KST 2014 PDA version: I537UCUCNE3 CSC version: I537ATTCNE3 Versión del SW: I537UCUCNE3 IMEI del teléfono: Unknown Phone SN: R31D803K99A Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SGH-I537-Unknown-29-08-2014_11-56-39-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Fecha de creación del firmware: Jan 28 2014 Tiempo de compilación del firmware: 02:00:00 Fecha de salida del firmware: May 16 2014 Tiempo de salida del firmware: 15:36:39 Versión del SW: M9615A-CEFWTAZM-4.0.17138 Found phone on COM202 Reparando el NVM para el teléfono SGH-I537... Write IMEI failed |
09-01-2014, 10:49 | #14 (permalink) |
Member: 1390215 Status: Offline Thanks Meter: 11 | Hello i flash whit other rom an flash the modem: Code: Plataforma: Samsung Android Puerto seleccionado: COM202 Modelo seleccionado: SGH-I537 Reading info, please wait... Modelo del teléfono detectado: SGH-I537 Fecha de creación del firmware: Fri May 16 14:53:09 KST 2014 PDA version: I537UCUCNE3 CSC version: I537ATTCNE3 Versión del SW: I537UCUAMF1 IMEI del teléfono: Unknown Phone SN: R31D803K99A Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM202 Modelo seleccionado: SGH-I537 Modo: Emergencia Write IMEI failed Same problem in Windows 7 x64 and Windows xp The *#0808#: USB - AP USB Settings - DM + MODEM + ADB The *#9090#: [1] DM/DUM over HS-USB(*) [5] DBG MSG ON (*) Thone rooted with Kingo Root, and usb debuggin is enabled. |
