10-30-2014, 00:13 | #1 (permalink) |
Insane Poster Join Date: Aug 2014
Member: 2249425 Status: Offline Thanks Meter: 3 | sgh-i527 Bricked after wrote the firmware I used Octoplus Box Samsung Software to write the firmware and here is the problem I got into. It says successful but now the phone is showing the black screen with three lines show below when turning on the phone: Image size too large!! W:1080 H:1920 (red color) Display image fail (yellow color) Secure Fail: keanel (red color) Thanks! Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SGH-M919 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I537 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Please, select firmware file first! ----------------------------------------------------------------------------------- To connect SGH-I527 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Please, select firmware file first! Selected firmware file: I527UCUAMK2_I527ATTAMK2_I527UCUAMK2 _HOME.oct Please put the phone into Download Mode and connect USB cable. To put SGH-I527 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. |
10-30-2014, 08:02 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Quote:
Also, please say what was the reason of writing this firmware? What was the problem with your device? | |
11-03-2014, 02:21 | #3 (permalink) |
Member: 2249425 Status: Offline Thanks Meter: 3 | Hello thank for getting back with me. Here is the firmware I used to write into the phone after converted it to the Octoplus formate: I527UCUAMK2_I527ATTAMK2_I527UCUAMK2_HOME.tar.md5 It is ATT and it is the only Stock Firmware I found. Please let me know where to download the correct firmware. Thanks again for your help |
11-03-2014, 08:27 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
If this will not help, try to find another firmware and write it. Or try to write full flash from the same working device via Jtag. | |
11-03-2014, 10:04 | #7 (permalink) |
Member: 2249425 Status: Offline Thanks Meter: 3 | Hello there, Can you show me how to do Factory Data Reset & Cache Partition on this death phone? Nope, I did converted the firmware correctly) Oki, I will try Jtag at last then but please answer my first question. Thanks so much |
11-03-2014, 11:24 | #8 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Download another Fw (always same or more High version), from here: Sam mobile . com or Samsung Updates . com (remove space from link above) Try to flash with odin and after can use Octopus Box for what you want do BR allumts | |
11-04-2014, 03:28 | #9 (permalink) | |
Member: 2249425 Status: Offline Thanks Meter: 3 | Quote:
Thanks for your help but just like the Octoplus's mod said there is only on firmware for this phone is available online. I double checked the two websites you gave me and none of them has any firmware for the SGH-I527. Please share me the link if you know any. Thanks again. Octoplus Mod, I tried to flash this phone with the Octoplus Jtag box but the only model but I could not find it beside the I527M. Can i use the I527M for this ATT phone USA market? Thanks! | |
11-04-2014, 10:34 | #10 (permalink) | |
What country is this phone? | |
11-04-2014, 10:50 | #11 (permalink) | ||
I527UCUAMK2_I527ATTAMK2_I527UCUAMK2_HOME.tar.md5 and if is possible explai Why has flashed fw, for what? Note: Quote:
For Wipe Che partition same procedure. Br allumts | ||
11-10-2014, 19:41 | #12 (permalink) |
Member: 2249425 Status: Offline Thanks Meter: 3 | Aluumts, Thanks for your help. I have tried everything as you showed before and it did not work. Ocotplus's mod sent me a file last week. Let me try it the last time and let you know before returning the phone back to the customer. Y I did that? The phone act so bad so I tried Odin as you showed above but it did not work out so I tried Octoplus then it when bad. Thanks for your help! |
11-10-2014, 21:22 | #13 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, here is one procedure that has solved many I527M but i NOT KNOW if is compatible with you model, BEFORE of use ceck carefully on Google if can use. NOTE: I'M NOT RESPONSABLE IF YOU BRICK YOU DEVICE. Loock here: http://forum.gsmhosting.com/vbb/f684...ution-1825074/ Not use thanks in post, only Button Mod. ban you for an time, only thanks button if is been of help for you. Br allumts |
