02-10-2015, 07:58 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | At first, You should configure your device correctly. To connect SGH-I547, perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" at the "Main" tab in the Software. |
02-10-2015, 13:07 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Check, whether *#7284# menu is available and if it is available, do the next: 1.Set "UART" radio button to "MODEM" value. 2. Set "USB" radio button to "PDA" value. 3. Try to perform "Read Info" operation. |
02-10-2015, 14:13 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Do the next: 1. Take out SIM and SD cards from the phone. 2. Make Unlock again. To finish the Unlock operation, restart the phone via phone's menu, don't disconnect the battery, this is important. If this will not help, make Read codes and enter unlocking code. |
02-10-2015, 15:06 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Look more carefully and attentively in the Support Area - press "Go to Support" button at "Support & Options" tab in the Software and look in the folder "Samsung/SGH-I547". |
02-10-2015, 15:12 | #12 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | I CANT ****ING FIND IT ALL I SEE IS THE i547C !!! LEAST PUT THAT **** IN ALPHABETICA I CANT ****ING FIND IT ALL I SEE IS THE i547C !!! LEAST PUT THAT **** IN ALPHABETICAL ORDER |
