07-22-2014, 19:45 | #1 (permalink) |
Freak Poster Join Date: May 2010
Member: 1298793 Status: Offline Thanks Meter: 21 | sgh-m819n need test software |
The Following User Says Thank You to rakataka1989 For This Useful Post: |
07-22-2014, 21:52 | #3 (permalink) | |
Freak Poster Join Date: Aug 2006
Member: 327489 Status: Offline Thanks Meter: 56 | Quote:
Just using oficial samsung Octopus suite but manual select sgh-i527 model *repair original imei *repair NVM & ur DONE full strength & stabble Signal 3G H, H+ 4G Working good Thanks Octoplus Team Beatyfull Tool! Code: Bienvenido en Octoplus/Octopus Box Samsung software versión 1.6.1 ----------------------------------------------------------------------------------- To connect SGH-I527 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM258 Modelo seleccionado: SGH-I527 Modo: Normal Modelo del teléfono: SGH-I527 Fecha de creación del firmware: Oct 01 2013 Tiempo de compilación del firmware: 03:00:00 Fecha de salida del firmware: Oct 26 2013 Tiempo de salida del firmware: 17:17:44 IMEI incorrecto Versión del SW: M8930B-AAAATAZM-5.0.060147 ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM258 Modelo seleccionado: SGH-I527 Modo: Normal Modelo del teléfono: SGH-I527 Fecha de creación del firmware: Oct 01 2013 Tiempo de compilación del firmware: 03:00:00 Fecha de salida del firmware: Oct 26 2013 Tiempo de salida del firmware: 17:17:44 Versión del SW: M8930B-AAAATAZM-5.0.060147 IMEI antiguo: 004400-15-202000-0 IMEI nuevo: 358865-05-ORIG-IMEI Realizando el backup de NVM ¡La lectura de NVM está terminada! Fecha de creación del firmware: Sat Oct 26 16:25:01 KST 2013 PDA version: M819NUVUAMJ5 CSC version: M819NTMBAMJ5 Versión del SW: M819NUVUAMJ5 IMEI del teléfono: Unknown Phone SN: RV1DA8KNTCX Android version: 4.2.2 (JDQ39) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-I527-Unknown-22-07-2014_15-41-01-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Fecha de creación del firmware: Oct 01 2013 Tiempo de compilación del firmware: 03:00:00 Fecha de salida del firmware: Oct 26 2013 Tiempo de salida del firmware: 17:17:44 Versión del SW: M8930B-AAAATAZM-5.0.060147 Found phone on COM258 Reparando el NVM para el teléfono SGH-I527... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM258 Modelo seleccionado: SGH-I527 Modo: Normal Modelo del teléfono: SGH-I527 Fecha de creación del firmware: Oct 01 2013 Tiempo de compilación del firmware: 03:00:00 Fecha de salida del firmware: Oct 26 2013 Tiempo de salida del firmware: 17:17:44 IMEI del teléfono: 358865-05-ORIG-IMEI Versión del SW: M8930B-AAAATAZM-5.0.060147 Realizando el backup de NVM ¡La lectura de NVM está terminada! Reparando el NVM para el teléfono SGH-I527... La reparación de NVM ha sido terminada con éxito To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) Last edited by frankerebus; 07-22-2014 at 22:01. | |
The Following User Says Thank You to frankerebus For This Useful Post: |
07-23-2014, 21:58 | #4 (permalink) |
Member: 327489 Status: Offline Thanks Meter: 56 | if still have problems maybe for shoddy work, and inherited always can use this file qcn restoration (qpst restoration file). restore and then do the repair NVM with octopus .. if still problem persists you can try the version i527m 100% full & checked |
