02-26-2014, 04:20 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2135477 Status: Offline Thanks Meter: 0 | SGH-M919 fail i did *#9090# but no "USB" option. Platform: Samsung Android Selected port: COM3 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM3 Phone connection failed |
02-26-2014, 04:39 | #2 (permalink) |
Member: 2135477 Status: Offline Thanks Meter: 0 | phone is rooted, debugging is on. first time i linked it up it read the phone and said "emergency use only" using UART cable and SAM3303K. neither one working. not reading phone |
02-26-2014, 05:06 | #3 (permalink) |
Member: 2135477 Status: Offline Thanks Meter: 0 | Connecting with only USB, this is message: Platform: Samsung Android Selected port: COM3 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM5 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SGH-M919 Mode: Emergency Unlock for SGH-M919 phone in emergency mode can’t be done |
02-26-2014, 05:45 | #4 (permalink) |
Member: 2135477 Status: Offline Thanks Meter: 0 | Platform: Samsung Android Selected port: COM8 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Sep 30 2013 Firmware compiled time: 05:00:00 Firmware released date: Nov 16 2013 Firmware released time: 15:19:25 Phone IMEI: 355537-05-417869-6 SW version: M9615A-CEFWTAZM-4.0.17122 Unlocking phone... Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86) \Octoplus\ Octoplu s_Samsung \BACKUP\NVM-SGH-M919-355537054178696-25-02-2014_22-39- 33-. nvm file Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone unlocking failed |
02-26-2014, 07:59 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Press "Read info" button at "Android / EFS manager" tab in Software to look, whether "USB Debugging" Mode is turned on and post here Software log with read phone's info. | |
02-26-2014, 15:02 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Press "Read info" button at "Android / EFS manager" tab in Software to look, whether "USB Debugging" Mode is turned on and post here Software log with read phone's info. |
02-27-2014, 08:45 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Now write back the same firmware that was in the device before. Last edited by Octopus box; 02-27-2014 at 18:31. |
03-05-2014, 18:12 | #13 (permalink) |
Member: 2135477 Status: Offline Thanks Meter: 0 | Welcome to Octoplus/Octopus Box Samsung software version 1.5.0 ----------------------------------------------------------------------------------- To connect SGH-M919 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SGH-M919 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM4 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 Phone IMEI: 355537-05-417869-6 SW version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 SW version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 355537-05-417869-6 New IMEI: 355537-05-417869-6 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SGH-M919 Mode: Normal Phone model: SGH-M919 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 26 2013 Firmware released time: 18:24:03 SW version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 355537-05-417869-6 New IMEI: 356565-05-073425-2 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\NVM-SGH-M919-355537054178696-05-03-2014_11-03- 56-.nvm file Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed |
03-05-2014, 19:40 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please turn off and on "USB Debugging" Mode, read phone's info (press "Read info" button at "Android / EFS manager" tab in Software) and post here Software log with this info. |
