03-23-2014, 20:07 | #1 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2153654 Status: Offline Thanks Meter: 1 | SGH-M919 IMEI Write INFO : 3/23/2014 2:56:47 PM > Platform: Samsung Android INFO : 3/23/2014 2:56:47 PM > Selected port: COM11 INFO : 3/23/2014 2:56:47 PM > Selected model: SGH-M919 INFO : 3/23/2014 2:56:48 PM > Mode: Normal INFO : 3/23/2014 2:56:48 PM > Phone model: SGH-M919 INFO : 3/23/2014 2:56:48 PM > Firmware compiled date: Dec 24 2013 INFO : 3/23/2014 2:56:48 PM > Firmware compiled time: 00:00:00 INFO : 3/23/2014 2:56:48 PM > Firmware released date: Feb 14 2014 INFO : 3/23/2014 2:56:48 PM > Firmware released time: 15:28:19 INFO : 3/23/2014 2:56:48 PM > SW version: M9615A-CEFWTAZM-4.0.17135 INFO : 3/23/2014 2:56:48 PM > Old IMEI: 004400-15-202000-0 INFO : 3/23/2014 2:56:48 PM > New IMEI: 012571-00-270608-9 INFO : 3/23/2014 2:56:48 PM > Creating NVM backup INFO : 3/23/2014 2:59:59 PM > Reading NVM done! INFO : 3/23/2014 3:00:01 PM > Firmware compiled date: Fri Feb 14 14:44:35 KST 2014 INFO : 3/23/2014 3:00:02 PM > PDA version: M919UVUFNB4 INFO : 3/23/2014 3:00:03 PM > CSC version: M919TMBFNB4 INFO : 3/23/2014 3:00:03 PM > SW version: M919UVUFNB4 INFO : 3/23/2014 3:00:04 PM > Phone IMEI: Unknown INFO : 3/23/2014 3:00:05 PM > Phone SN: RV1D72HSA9T INFO : 3/23/2014 3:00:05 PM > Android version: 4.4.2 (KOT49H) INFO : 3/23/2014 3:00:05 PM > Cheking Root INFO : 3/23/2014 3:00:07 PM > Phone is Rooted INFO : 3/23/2014 3:00:07 PM > Erasing old IMEI. It can take some time. Please wait... WARN : 3/23/2014 3:00:28 PM > Phone will restart now. Please don't disconnect cable! INFO : 3/23/2014 3:01:05 PM > Firmware compiled date: Dec 24 2013 INFO : 3/23/2014 3:01:05 PM > Firmware compiled time: 00:00:00 INFO : 3/23/2014 3:01:05 PM > Firmware released date: Feb 14 2014 INFO : 3/23/2014 3:01:05 PM > Firmware released time: 15:28:19 INFO : 3/23/2014 3:01:05 PM > SW version: M9615A-CEFWTAZM-4.0.17135 INFO : 3/23/2014 3:01:05 PM > Found phone on COM11 INFO : 3/23/2014 3:01:06 PM > Repairing NVM for SGH-M919 phone... ERROR : 3/23/2014 3:01:18 PM > Write IMEI failed Last edited by Octopus box; 03-25-2014 at 07:23. |
03-24-2014, 07:59 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the IMEI in your phone exactly by "*#06#"? Try to do the next: 1. Install the latest Software version (http://octoplusbox.com/en/download/software/). 2. Make "Repair EFS". 3. Write modem firmware "SGH-M919_modem_CWM_UVUAMDL". 4. Make "Repair NVM". 5. Perform "Repair IMEI" operation. 6. Post here the result. |
03-24-2014, 21:24 | #3 (permalink) | |
Insane Poster Join Date: Oct 2013
Member: 2048078 Status: Offline Thanks Meter: 2 | Quote:
03-27-2014, 21:48 | #5 (permalink) | |
Member: 2153654 Status: Offline Thanks Meter: 1 | Quote:
This is what happens when I try to Repair EFS Platform: Samsung Android Selected port: COM18 Selected model: SGH-M919 To put SGH-M919 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... Phone found. Repair EFS failed | |
05-22-2014, 00:15 | #10 (permalink) |
Insane Poster Join Date: May 2014
Member: 2190785 Status: Offline Thanks Meter: 29 | hello i have some problem to unlock/change imei on this M919 4.4.2 (M919UVUFNB4) First i root the phone using CF-Auto-Root And try to unlock that way but its say faild and it change my IMEI Then i down grade the phone FirmWare using octoplus to 4.2.2 (M919UVUAMDL) but the baseband keeps the same (M919UVUFNB4) i root again the phone and try to fox the IMEI but keep telling me faild this my log: Firmware compiled date: Fri Apr 26 17:15:31 KST 2013 PDA version: M919UVUAMDL CSC version: M919TMBAMDL SW version: M919UVUFNB4 Phone IMEI: Unknown Phone SN: RF1D478W82J Android version: 4.2.2 (JDQ39) Cheking Root Phone is Rooted Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Firmware compiled time: Firmware released date: -ù~ Firmware released time: SW version: Found phone on COM8 Repairing NVM for SGH-M919 phone... Writing NVM failed Write IMEI failed I noticed something when the phone reboot to write the nvm/imei it change the com port from 7 to 8 (my usally port for samsung) can you help me on this? |
05-22-2014, 06:44 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | At first, You should connect the phone correctly. To connect SGH-M919, You have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. When info will be read correctly and fully, only then perform Repair IMEI operation. |
05-23-2014, 18:34 | #12 (permalink) |
Member: 2190785 Status: Offline Thanks Meter: 29 | when i do that i get a different options like this: DIAG CONFIG [1]DM/DUM over HS-USB() [2]DM/DUM over HSIC[*] [3]DM/DUN/RmNET over HSUSB[] [4]DM over UART[] [5]DBG MSG ON (*) [6]DBG MSG OFF() |
