02-22-2017, 13:48 | #1 (permalink) |
Junior Member Join Date: May 2014 Location: gujrat pakistan
Member: 2178725 Status: Offline Sonork: 100.1625664 Thanks Meter: 7 | SGH-T989D unlock problem 4.1.2 [Solved] ----------------------------------------------------------------------------------- To connect GT-S7562 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090# or *#0808#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-T989D phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090# or *#0808#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM108 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM108 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM108 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SGH-T989D Port is busy Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Selected action can’t be performed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM18 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Port is busy No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Selected action can’t be performed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Phone was not found on the selected port! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Phone was not found on the selected port! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Phone was not found on the selected port! Selected action can’t be performed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Selected action can’t be performed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SGH-T989D Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SGH-T989D Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SGH-T989D Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM154 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SGH-T989D Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM156 Port is busy Connecting to phone on COM154 Port is busy Connecting to phone on COM155 Port is busy No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SGH-T989D Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM156 Mode: Normal Phone model: SGH-T989 Warning: Selected model (SGH-T989D) differs from the detected one (SGH-T989)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM156 Selected model: SGH-T989D Mode: Normal Phone model: SGH-T989 Warning: Selected model (SGH-T989D) differs from the detected one (SGH-T989)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Reading phone unlock codes. This can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked Reaing codes Failed! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM156 Selected model: SGH-T989D Mode: Normal Phone model: SGH-T989 Warning: Selected model (SGH-T989D) differs from the detected one (SGH-T989)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Reading phone unlock codes. This can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked Reaing codes Failed! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM156 Selected model: SGH-T989D Mode: Normal Phone model: SGH-T989 Warning: Selected model (SGH-T989D) differs from the detected one (SGH-T989)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Mode: Emergency Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Selected action can’t be performed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM153 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM154 Port is busy Connecting to phone on COM156 Port is busy Connecting to phone on COM155 Port is busy No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM154 Port is busy Connecting to phone on COM156 Port is busy Connecting to phone on COM155 Port is busy No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM153 Selected model: SGH-T989D Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM154 Port is busy Connecting to phone on COM156 Port is busy Connecting to phone on COM155 Port is busy No diagnostic ports found! Connecting to phone on COM7 Phone connection failed Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: SGH-T989D Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM156 Mode: Normal Phone model: SGH-T989 Warning: Selected model (SGH-T989D) differs from the detected one (SGH-T989)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM156 Selected model: SGH-T989D Mode: Normal Phone model: SGH-T989 Warning: Selected model (SGH-T989D) differs from the detected one (SGH-T989)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Reading phone unlock codes. This can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked Reaing codes Failed! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM156 Selected model: SGH-T989D Mode: Normal Phone model: SGH-T989 Warning: Selected model (SGH-T989D) differs from the detected one (SGH-T989)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Reading phone unlock codes. This can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked Reaing codes Failed! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- To connect SGH-T989 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090# or *#0808#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM156 Selected model: SGH-T989 Mode: Normal Phone model: SGH-T989 Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Reading phone unlock codes. This can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked Reaing codes Failed! Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- To connect SGH-T989D phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090# or *#0808#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM156 Selected model: SGH-T989D Mode: Normal Phone model: SGH-T989 Warning: Selected model (SGH-T989D) differs from the detected one (SGH-T989)! Firmware compiled date: Jul 05 2012 Firmware compiled time: 15:00:00 Firmware released date: Mar 26 2013 Firmware released time: 15:46:02 Phone IMEI: 359153-04-031066-0 SW version: M9200B-SCAQCSZD-3.4.701100 Reading phone unlock codes. This can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked Reaing codes Failed! Performed by 2.4.7 Software version. Last edited by Octopus box; 02-22-2017 at 16:00. |
