12-20-2014, 01:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | SGH-T599N still stuck on searching after successful unlock ----------------------------------------------------------------------------------- To connect SGH-T999N phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#7284#" number. 12. Set "UART" to "PDA" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-T599N phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "PDA" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SGH-T599N Port is busy Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SGH-T599N Port is busy Searching for a phone. Please wait... ADB server killed. Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM19 Searching for a phone. Please wait... Phone found. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed No diagnostic ports found! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: Selected model: SGH-T599N Port is busy Searching for a phone. Please wait... ADB server killed. Phone found. Firmware compiled date: Fri Apr 12 02:23:38 KST 2013 PDA version: T599NUVAMD4 CSC version: T599NTMBAMD4 SW version: T599NUVAMD4 Phone IMEI: 351938069330500 Phone SN: R21F391MGFJ Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SGH-T599N Searching for a phone. Please wait... Phone found. Firmware compiled date: Fri Apr 12 02:23:38 KST 2013 PDA version: T599NUVAMD4 CSC version: T599NTMBAMD4 SW version: T599NUVAMD4 Phone IMEI: 351938069330500 Phone SN: R21F391MGFJ Android version: 4.1.2 (JZO54K) Unlocking phone... Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... Phone found. Unlocking phone. This can take some time. Please wait... Please insert card into phone, if phone is locked, then type 00000000 Phone is successfully unlocked Last edited by Octopus box; 12-20-2014 at 08:30. |
