12-11-2013, 18:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1288575 Status: Offline Thanks Meter: 36 | sght889 imei 000000000 [Solved] Welcome to Octoplus/Octopus Box Samsung software version 1.4.1 ----------------------------------------------------------------------------------- To connect SGH-T889 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Close window. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-T889 To put SGH-T889 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-T889 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM29 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM29 Selected model: SGH-T889 Mode: Emergency NVM can’t be repaired for SGH-T889 phone in emergency mode Yes debugging is on, yes uart is set to modem, yes diag is set to dm over hs-usb always come up in emerency |
12-11-2013, 18:47 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Try to reflash the phone again after You have performed Repair EFS operation and try to connect the phone again via both - Micro USB and Samsung Micro UART C3300k/C3303k cable. |
12-11-2013, 19:05 | #3 (permalink) | |
Member: 1288575 Status: Offline Thanks Meter: 36 | Quote:
Octoplus Box Full Set | |
