12-18-2014, 10:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | SHV-E110S unlock problem Platform: Samsung Anycall Selected port: COM3 Selected model: SHV-E110S Mode: Normal Phone model: SHV-E110S Firmware compiled date: May 03 2012 Firmware compiled time: 10:00:00 Firmware released date: Dec 21 2012 Firmware released time: 17:14:50 Phone IMEI: 357980-04-628248-1 WiFi MAC: 38:0A:94:E96:52 SW version: M9200B-SCAQCSZD-3.4.706035T Reading phone unlock codes. It can take some time, please wait... ----------------------------------------------------------------------------------- Phone unlock code: To finish the operation you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Select "USIM Settings" menu item. 5. Select "Network personalizaion" menu item. 6. Enter the phone unlock code. 7. "Success" notification must appear. 8. Restart the phone. no unlock code |
12-18-2014, 11:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please connect the phone directly to PC and repeat "Read Codes" operation. Try to perform "Read Codes" operations on different COM ports. |
12-18-2014, 12:13 | #3 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
Platform: Samsung Anycall Selected port: COM54 Selected model: SHV-E110S Detected phone model: SHV-E110S HW Version: SKT Phone IMEI: 357980-04-628248-1 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM54 Detected phone model: SHV-E110S HW Version: SKT Phone IMEI: 357980-04-628248-1 Phone connection failed No diagnostic ports found! Connecting to phone on COM13 Phone connection failed Connecting to phone on COM3 Phone connection failed Selected action can’t be performed | |
12-18-2014, 13:45 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Post here full Software log of "Write Firmware" and "Read Codes" operations, which You tried to perform on different COM ports, after "Write Firmware" operation. To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Connect the phone directly to PC. 11. Press "Read Info" in software. If You are not able to enter "Diag Config" menu (*#7284#) - try to use Samsung C3300k/C3303k micro UART cable with 523-525kOm resistor for connection. |
12-18-2014, 14:20 | #7 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | Platform: Samsung Anycall Selected port: COM53 Selected model: SHV-E110S Mode: Normal Phone model: SHV-E110S Firmware compiled date: Sep 02 2011 Firmware compiled time: 00:00:00 Firmware released date: Jan 31 2012 Firmware released time: 10:43:42 Phone IMEI: 357980-04-628248-1 WiFi MAC: 2C:44:01:E1:83:4A SW version: M9200B-SCAQCSZD-3.4.501036 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM53 Selected model: SHV-E110S Mode: Normal Phone model: SHV-E110S Firmware compiled date: Sep 02 2011 Firmware compiled time: 00:00:00 Firmware released date: Jan 31 2012 Firmware released time: 10:43:42 Phone IMEI: 357980-04-628248-1 WiFi MAC: 2C:44:01:E1:83:4A SW version: M9200B-SCAQCSZD-3.4.501036 Reading phone unlock codes. It can take some time, please wait... ----------------------------------------------------------------------------------- Phone unlock code: To finish the operation you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Select "USIM Settings" menu item. 5. Select "Network personalizaion" menu item. 6. Enter the phone unlock code. 7. "Success" notification must appear. 8. Restart the phone. |
12-18-2014, 14:31 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
12-18-2014, 14:32 | #9 (permalink) |
Member: 1418524 Status: Offline Thanks Meter: 186 | Platform: Samsung Anycall Selected port: COM53 Selected model: SHV-E110S Mode: Normal Phone model: SHV-E110S Firmware compiled date: Sep 02 2011 Firmware compiled time: 00:00:00 Firmware released date: Jan 31 2012 Firmware released time: 10:43:42 Phone IMEI: 357980-04-628248-1 WiFi MAC: 2C:44:01:E1:83:4A SW version: M9200B-SCAQCSZD-3.4.501036 |
12-18-2014, 14:35 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to make Repair NVM and then Read Codes again. Post here the result. Which the code exactly request your phone, 4-digits or 8-digits? Also, You can contact us right now to Skype, Yahoo! Messenger or ICQ, we will look remotely, where can be the problem with your device. |
